指針的一種用法(優(yōu)化代碼)
作者:佚名   來源:本站原創(chuàng)   點(diǎn)擊數(shù):  更新時(shí)間:2012年11月28日   【字體:
 函數(shù)名 :unsigned char CAN_Send_dat(CAN_DAT *can_tmp,unsigned char pir)
 功能 。篶an發(fā)送
 參數(shù) 。*can_tmp 數(shù)據(jù)包 pir: 優(yōu)先級 0~3
 返回 。1->緩沖池滿需要等待下次裝入發(fā)送緩沖池 0->成功放入緩沖池
 unsigned char n,flag;
 unsigned char temp;
 unsigned char *P_addr,*P_addr_temp;
 flag = 0;
 if((TXB0CON&0x08)==0)
   P_addr = (unsigned char*)(&TXB0CON);
   flag = 1;
 if((TXB1CON&0x08)==0)
   P_addr = (unsigned char*)(&TXB1CON);
   flag = 1;
 if((TXB2CON&0x08)==0)
   P_addr = (unsigned char*)(&TXB2CON);
   flag = 1;
if(flag==1)
       P_addr_temp = P_addr;
      *P_addr = pir;
       P_addr++;
      if(can_tmp->IDR_RTR&0x02)//擴(kuò)展標(biāo)識符
       *P_addr = ((can_tmp->ID[2]>>5)|(can_tmp->ID[3]<<3));
       temp = can_tmp->ID[2]&0x03;
       temp|=((can_tmp->ID[2]&0x1C)<<3);
       temp|= 0x08;
       P_addr++;
       *P_addr = temp;
       P_addr++;
       *P_addr = can_tmp->ID[1];
       P_addr++;
       *P_addr = can_tmp->ID[0];
       P_addr++;
        *P_addr = ((can_tmp->ID[1]<<5)|(can_tmp->ID[0]>>3));;
         P_addr++;
        *P_addr = (can_tmp->ID[0]<<5);
         P_addr+=3;
        *P_addr = can_tmp->length;
        P_addr++;
       for(n=0;n<can_tmp->length;n++)
        *P_addr =can_tmp->DATA[n];
        P_addr++;
       *P_addr_temp |= 0x08;
      return 0;
  return 1;
 功能 。篶an發(fā)送
 參數(shù)  :*can_tmp 數(shù)據(jù)包 pir: 優(yōu)先級 0~3
 unsigned char n;
 unsigned char temp;
 unsigned char *P_addr;
   // TXB0CON&=0xfc;
   //bit3=0標(biāo)準(zhǔn)標(biāo)識符,bit3=1擴(kuò)展標(biāo)識符,bit7-5:標(biāo)準(zhǔn)標(biāo)識符2-0位,bit7-5 擴(kuò)展ID[16-17]
    TXB0CON = pir;//|= pir;           //設(shè)置TXB0為最高優(yōu)先級3
 TXB0EIDL  = can_tmp->ID[0];//擴(kuò)展ID[0-7]
 TXB0EIDH  = can_tmp->ID[1];//擴(kuò)展ID[8-15]
 TXB0SIDL  = can_tmp->ID[2]&0x03;//擴(kuò)展ID[16-17]
    temp= ((can_tmp->ID[2]&0x1C)<<3);
    TXB0SIDL |= temp;//標(biāo)準(zhǔn)[0-3]
    TXB0SIDL |= 0x08;
 TXB0SIDH=((can_tmp->ID[2]>>5)|(can_tmp->ID[3]<<3));//標(biāo)準(zhǔn)標(biāo)識符的10-3位
    TXB0SIDL = (can_tmp->ID[0]<<5);//標(biāo)準(zhǔn)[0-3]
    TXB0SIDH = ((can_tmp->ID[1]<<5)|(can_tmp->ID[0]>>3));
//if(can_tmp->IDR_RTR&0x01)can_tmp->length|=0x40;
 TXB0DLC=can_tmp->length;
    P_addr = &TXB0D0;
      P_addr++;
    TXB0CON=TXB0CON|0x08; /* bit3(TXREQ)=1請求發(fā)送 */
    return 0;
   // TXB1CON&=0xfc;
    TXB1CON = pir;//|= pir;
 TXB1EIDL  = can_tmp->ID[0];//擴(kuò)展ID[0-7]
 TXB1EIDH  = can_tmp->ID[1];//擴(kuò)展ID[8-15]
 TXB1SIDL  = can_tmp->ID[2]&0x03;//擴(kuò)展ID[16-17]
    TXB1SIDL |= temp;//標(biāo)準(zhǔn)[0-3]
    TXB1SIDL |= 0x08;
 TXB1SIDH=((can_tmp->ID[2]>>5)|(can_tmp->ID[3]<<3));//標(biāo)準(zhǔn)標(biāo)識符的10-3位
    TXB1SIDL = (can_tmp->ID[0]<<5);//標(biāo)準(zhǔn)[0-3]
    TXB1SIDH = ((can_tmp->ID[1]<<5)|(can_tmp->ID[0]>>3));
 TXB1DLC=can_tmp->length;
    P_addr = &TXB1D0;
      P_addr++;
    TXB1CON=TXB1CON|0x08;
return 0;
    //TXB2CON&=0xfc;
    TXB2CON = pir;
 TXB2EIDL  = can_tmp->ID[0];//擴(kuò)展ID[0-7]
 TXB2EIDH  = can_tmp->ID[1];//擴(kuò)展ID[8-15]
 TXB2SIDL  = can_tmp->ID[2]&0x03;//擴(kuò)展ID[16-17]
    TXB2SIDL |= temp;//標(biāo)準(zhǔn)[0-3]
    TXB2SIDL |= 0x08;
 TXB2SIDH=((can_tmp->ID[2]>>5)|(can_tmp->ID[3]<<3));//標(biāo)準(zhǔn)標(biāo)識符的10-3位
    TXB2SIDL = (can_tmp->ID[0]<<5);//標(biāo)準(zhǔn)[0-3]
    TXB2SIDH = (can_tmp->ID[1]<<5|(can_tmp->ID[0]>>3));
// if(can_tmp->IDR_RTR&0x01)can_tmp->length|=0x40;
 TXB2DLC=can_tmp->length;
    P_addr = &TXB2D0;
      P_addr++;
    TXB2CON=TXB2CON|0x08;
return 0;
return 1;
