MCU:MSP430F16X系列,RF無線模塊:NRF24L01,液晶顯示:ST7920串行控制128*64液晶,發(fā)送數(shù)據(jù)是把4X4矩陣鍵盤對應(yīng)的鍵值發(fā)送出去。IRQ是采用中斷查詢法,具體的可以參考下面代碼: //p4口為液晶屏 //p1口中斷 //nRF24L01無線通信 //p5.0 csn //p5.1 mosi //p5.3 sck //p5.2 miso //p1.2 irq //p5.7 ce //ST7920串行控制128*64液晶 //rst p4.3 復(fù)位 //rs p4.0 片選 //rw p4.1 數(shù)據(jù) //E p4.2 時鐘 #include <msp430x16x.h> #include <string.h> #define uchar unsigned char #define uint unsigned int #define ulong unsigned long #define LCD_CLK_1 (P4OUT |= BIT2) #define LCD_CLK_0 (P4OUT &=~ BIT2) #define LCD_D_1 (P4OUT |= BIT1) #define LCD_D_0 (P4OUT &=~ BIT1) #define LCD_RST_1 (P4OUT |= BIT3) #define LCD_RST_0 (P4OUT &=~ BIT3) #define LCD_CS_1 (P4OUT |= BIT0) #define LCD_CS_0 (P4OUT &= ~BIT0) #define TMP121_CS_1 (P5OUT |= BIT7) #define TMP121_CS_0 (P5OUT &= ~BIT7) #define TMP121_CLK_1 (P5OUT |= BIT3) #define TMP121_CLK_0 (P5OUT &= ~BIT3) #define send_1 (P2OUT |= BIT0) #define send_0 (P2OUT &= ~BIT0) #define CPU_F ((double)1000000) // MCLK=1MHZ主頻 #define Delayus_us(x) __Delayus_cycles((long)(CPU_F*(double)x/1000000.0)) #define Delayus_ms(x) __Delayus_cycles((long)(CPU_F*(double)x/1000.0)) #define Delayus_s(x) __Delayus_cycles((long)(CPU_F*(double)x/1.0)) uint alldata[32],keyflg; uchar char11[16]={'0','1','2','3','4','5','6','7','8','9','a','b','c','d','e','f'}; uchar busy='A',hang,lie,flash_flag,bostart; uchar key0=0,key1='T',key2,boflg,flg,key2flg=0,tab1=1,newsflag1,newsflag2; uchar key11,key12; uint LCDL; uchar tu[32][32]={0x00}; uint Rdata[8]={0},botu[98]={0x0000}; uchar Tx_Payload[32]={4,1,9}; uchar Tx_Address[5]={100,101,102,103,104}; void Delayus(ulong ilinshi) { ulong ii; for(ii=0;ii<=ilinshi;ii++) { key0=key0; } } #define nRF24L01_CE_1 (P5OUT|= BIT7) #define nRF24L01_CE_0 (P5OUT&=~BIT7) #define nRF24L01_CSN_1 (P5OUT|= BIT0) #define nRF24L01_CSN_0 (P5OUT&=~BIT0) #define nRF24L01_SCK_1 (P5OUT|= BIT3) #define nRF24L01_SCK_0 (P5OUT&=~BIT3) #define nRF24L01_MOSI_1 (P5OUT|= BIT1) #define nRF24L01_MOSI_0 (P5OUT&=~BIT1) //SPI Commands #define nRF24L01_R_REGISTER 0x00 #define nRF24L01_W_REGISTER 0x20 #define nRF24L01_R_RX_PAYLOAD 0x61 #define nRF24L01_W_TX_PAYLOAD 0xA0 #define nRF24L01_FLUSH_TX 0xE1 #define nRF24L01_FLUSH_RX 0xE2 #define nRF24L01_REUSE_TX_PL 0xE3 #define nRF24L01_NOP 0xFF //NRF24L01寄存器地址 #define nRF24L01_CONFIG 0x00 #define nRF24L01_EN_AA 0x01 #define nRF24L01_EN_RXADDR 0x02 #define nRF24L01_SETUP_AW 0x03 #define nRF24L01_SETUP_RETR 0x04 #define nRF24L01_RF_CH 0x05 #define nRF24L01_RF_SETUP 0x06 #define nRF24L01_STATUS 0x07 #define nRF24L01_OBSERVE_TX 0x08 #define nRF24L01_CD 0x09 #define nRF24L01_RX_ADDR_P0 0x0A #define nRF24L01_RX_ADDR_P1 0x0B #define nRF24L01_RX_ADDR_P2 0x0C #define nRF24L01_RX_ADDR_P3 0x0D #define nRF24L01_RX_ADDR_P4 0x0E #define nRF24L01_RX_ADDR_P5 0x0F #define nRF24L01_TX_ADDR 0x10 #define nRF24L01_RX_PW_P0 0x11 #define nRF24L01_RX_PW_P1 0x12 #define nRF24L01_RX_PW_P2 0x13 #define nRF24L01_RX_PW_P3 0x14 #define nRF24L01_RX_PW_P4 0x15 #define nRF24L01_RX_PW_P5 0x16 #define nRF24L01_FIFO_STATUS 0x17 void IO_Init(void) //初始化端口 { P2SEL = 0; P3SEL = 0; P4SEL = 0; P4DIR|=0x0f; //P4.0,1,2,3=OUT P4OUT|=0x0f; P2DIR=0xfd; //P2.1=in qita=OUT P3DIR&=0xf7; //p3.3=in } void Init_Port1(void) //P1.0、P1.1為中斷,下降沿觸發(fā) { P1SEL=0; //設(shè)置為普通I/O口功能 P1DIR=0; //設(shè)置為輸入方向 P1IE=0; P1IES=0; P1IE|=BIT2; //打開中斷允許 P1IES|=BIT2; //下降沿觸發(fā) P1IFG=0; //P1IES的切換可能使P1IFG置位,需清除 } /*******************************************************************************/ //無線通信 void Init_nRF24L01_IO() { nRF24L01_CE_0; nRF24L01_CSN_1; nRF24L01_SCK_0; nRF24L01_MOSI_0; } //NRF24L01的SPI寫時序 void nRF24L01SpiWrite(unsigned char byte) { unsigned char i; nRF24L01_SCK_0; Delayus(1); for (i=0;i<8;i++) // Setup byte circulation bits { if ((byte&BIT7)==BIT7) // Put DATA_BUF.7 on data line nRF24L01_MOSI_1; //MOSI=1; else nRF24L01_MOSI_0; //MOSI=0; nRF24L01_SCK_1; // Set clock line high Delayus(2); byte=byte<<1; nRF24L01_SCK_0; // Set clock line low Delayus(2); } Delayus(1); } //NRF24L01的SPI讀時序 unsigned char nRF24L01SpiRead(void) { unsigned char i; unsigned char temp=0; nRF24L01_SCK_0; Delayus(2); for (i=0;i<8;i++) // Setup byte circulation bits { nRF24L01_SCK_1; // Set clock line high Delayus(2); temp=temp<<1; // Right shift DATA_BUF if ((P5IN&BIT2==BIT2)) {temp|=1;} // Read data nRF24L01_SCK_0; // Set clock line low Delayus(2); } Delayus(2); return temp; } // void nRF24L01_Flush_TX_FIFO(void)//Clear TX FIFO { nRF24L01_CSN_1; nRF24L01_CSN_0; nRF24L01SpiWrite(nRF24L01_FLUSH_TX); nRF24L01_CSN_1; } // void nRF24L01_Flush_RX_FIFO(void)//Clear RX FIFO { nRF24L01_CSN_1; nRF24L01_CSN_0; nRF24L01SpiWrite(nRF24L01_FLUSH_RX); nRF24L01_CSN_1; } // void nRF24L01SpiWriteReg(unsigned char SpiCommand,unsigned char Content) { nRF24L01_CSN_1; nRF24L01_CSN_0; nRF24L01SpiWrite(SpiCommand); nRF24L01SpiWrite(Content); nRF24L01_CSN_1; } // void nRF24L01_Set_Rx_Address(unsigned char RX_Address_Pipex,unsigned char *Address,unsigned char Length)//Local //Address { unsigned char i=0; nRF24L01_CSN_1; nRF24L01_CSN_0; nRF24L01SpiWrite(RX_Address_Pipex); for(i=0;i<Length;i++) { nRF24L01SpiWrite(*Address); Address++; } nRF24L01_CSN_1; } // void nRF24L01_Set_Tx_Address(unsigned char TX_AddressReg10,unsigned char *Address,unsigned char Length)//Remote //Address { unsigned char i=0; nRF24L01_CSN_1; nRF24L01_CSN_0; nRF24L01SpiWrite(TX_AddressReg10); for(i=0;i<Length;i++) { nRF24L01SpiWrite(*Address); Address++; } nRF24L01_CSN_1; } // void nRF24L01_Read_Rx_Payload(unsigned char *DataBuff,unsigned char Length)//Payload Out { unsigned char i=0; nRF24L01_CSN_1; nRF24L01_CSN_0; nRF24L01SpiWrite(nRF24L01_R_RX_PAYLOAD); for(i=0;i<Length;i++) { *DataBuff=nRF24L01SpiRead(); DataBuff++; } nRF24L01_CSN_1; } // void nRF24L01_Write_Tx_Payload(unsigned char *DataByte, unsigned char Length)//Payload IN { unsigned char i=0; nRF24L01_CSN_1; nRF24L01_CSN_0; nRF24L01SpiWrite(nRF24L01_W_TX_PAYLOAD); for(i=0;i<Length;i++) { nRF24L01SpiWrite(*DataByte); DataByte++; } nRF24L01_CSN_1; } // void nRF24L01_Transmit_Data(void)//Transmit Pulse { Delayus(10); nRF24L01_CE_1; Delayus(8000); nRF24L01_CE_0; } void nRF24L01_Reset_Rx_DS(void) { nRF24L01SpiWriteReg(nRF24L01_W_REGISTER+nRF24L01_STATUS,0x4e);// } // void nRF24L01_TX_MODE(void) { nRF24L01SpiWriteReg(nRF24L01_W_REGISTER+nRF24L01_CONFIG,0x5e);//Reflect TX_DR nRF24L01SpiWriteReg(nRF24L01_W_REGISTER+nRF24L01_EN_AA,0x00);////Disable auto_acknowledgment,6 pipes nRF24L01SpiWriteReg(nRF24L01_W_REGISTER+nRF24L01_EN_RXADDR,0x01);//Enabled RX Addresses.Enable data pipe 0 nRF24L01SpiWriteReg(nRF24L01_W_REGISTER+nRF24L01_SETUP_AW,0x03);//RX/TX Address field width 5 bytes. nRF24L01SpiWriteReg(nRF24L01_W_REGISTER+nRF24L01_SETUP_RETR,0x00);//Re-Transmit disabled. nRF24L01SpiWriteReg(nRF24L01_W_REGISTER+nRF24L01_RF_CH,0x02);//RF Channel. nRF24L01SpiWriteReg(nRF24L01_W_REGISTER+nRF24L01_RF_SETUP,0x06);//Air Data Rate 1Mbps.RF_PWR:0dBm.LNA Gain 0. nRF24L01SpiWriteReg(nRF24L01_W_REGISTER+nRF24L01_RX_PW_P0,0x05);//Pipe0 1 Bytes Payload. nRF24L01SpiWriteReg(nRF24L01_W_REGISTER+nRF24L01_STATUS,0x2e);//Reset_Tx_DS } /******************************************************************************************************************/ //以下是液晶屏顯示程序 void Write_command(uchar x) { uchar b,i=0; Delayus(3); b=x; LCD_CS_1; //cs=1; LCD_D_1; //data=1; for(i=0;i<5;i++) //5 個連續(xù)1 '11111' { LCD_CLK_0; //clk=0 LCD_CLK_1; ; //clk=1 } LCD_CLK_0; //clk=0 LCD_D_0; //data=0; for(i=0;i<3;i++) //RS,RW,0 Rs="Rw"=0 //寫命令 { LCD_CLK_0; //clk=0 LCD_CLK_1; ; //clk=1 } ////////////////////////////////////上面是發(fā)送一個完整的啟動數(shù)據(jù)'11111000' for(i=0;i<4;i++) //發(fā)送高4位 { if((x&0x80)?1:0) //1 LCD_D_1; //data=1; else LCD_D_0; //data=0; LCD_CLK_0; //clk=0 LCD_CLK_1; ; //clk=1 x=x<<1; } LCD_D_0; //data=0; for(i=0;i<4;i++) //RS,RW,0 發(fā)送4個0; { LCD_CLK_0; //clk=0 LCD_CLK_1; ; //clk=1 } ////////////////////////////////////////////// for(i=0;i<4;i++) //發(fā)送低4位 { if((b&0x08)?1:0) //1 LCD_D_1; //data=1; else LCD_D_0; //data=0; LCD_CLK_0; //clk=0 LCD_CLK_1; ; //clk=1 b=b<<1; } LCD_D_0; //data=0; for(i=0;i<4;i++) //RS,RW,0 發(fā)送4個0; { LCD_CLK_0; //clk=0 LCD_CLK_1; ; //clk=1 } LCD_CS_1; //cs=1; Delayus(15); } void Write_data(uchar x) { uchar b,i=0; Delayus(3); b=x; LCD_CS_1; //cs=1; LCD_D_1; //data=1; for(i=0;i<5;i++) //5 個連續(xù)1 '11111' { LCD_CLK_0; //clk=0 LCD_CLK_1; ; //clk=1 } LCD_CLK_0; //clk=0 //RW=0 LCD_D_0; //data=0; LCD_CLK_1; //clk=1 LCD_CLK_0; //clk=0 //RS=1 LCD_D_1; //data=0; LCD_CLK_1; //clk=1 LCD_CLK_0; //clk=0 //0 LCD_D_0; //data=0; LCD_CLK_1; //clk=1 ////////////////////////////////////上面是發(fā)送一個完整的啟動數(shù)據(jù)'11111010' for(i=0;i<4;i++) //發(fā)送高4位 { if((x&0x80)?1:0) //1 LCD_D_1; //data=1; else LCD_D_0; //data=0; LCD_CLK_0; //clk=0 LCD_CLK_1; //clk=1 x=x<<1; } LCD_D_0; //data=0; for(i=0;i<4;i++) //RS,RW,0 發(fā)送4個0; { LCD_CLK_0; //clk=0 LCD_CLK_1; ; //clk=1 } ////////////////////////////////////////////// for(i=0;i<4;i++) //發(fā)送低4位 { if((b&0x08)?1:0) //1 LCD_D_1; //data=1; else LCD_D_0; //data=0; LCD_CLK_0; //clk=0 LCD_CLK_1; ; //clk=1 b=b<<1; } LCD_D_0; //data=0; for(i=0;i<4;i++) //RS,RW,0 發(fā)送4個0; { LCD_CLK_0; //clk=0 LCD_CLK_1; ; //clk=1 } LCD_CS_1; //cs=1; Delayus(15); } void CLEAR() { Write_command(0x30); Write_command(0x01); Write_command(0x34); Write_command(0x30); } void drclear(void) { //以下是清繪畫RAM uchar i,j; Write_command(0x34); for(j=0;j<32;j++) { for(i=0;i<32;i++) { tu[i][j]=0x00; } } for(j=0;j<32;j++) { for(i=0;i<16;i++) { tu[i][j]=0x00; Write_command(0x80+j); //設(shè)定垂直坐標 Write_command(0x80+i); //設(shè)定水平坐標 Write_data(0x00); //放入數(shù)據(jù)高字節(jié) Write_data(0x00); //放入數(shù)據(jù)低字節(jié) } } } void LCD_Init() { LCD_RST_0; //rst=0 Delayus(100); LCD_RST_1; //rst=1 Delayus(100); Write_command(0x30); Delayus(20); Write_command(0x30); Delayus(20); Write_command(0x30); Write_command(0x30); //-------------- Write_command(0x0c); //Write_command(0x0C); Delayus(10); Write_command(0x01); Delayus(20); Write_command(0x06); /* //以下是清繪畫RAM uchar i,j; Write_command(0x34); for(j=0;j<32;j++) { for(i=0;i<16;i++) { Write_command(0x80+j); //設(shè)定垂直坐標 Write_command(0x80+i); //設(shè)定水平坐標 Write_data(0x00); //放入數(shù)據(jù)高字節(jié) Write_data(0x00); //放入數(shù)據(jù)低字節(jié) } } */ } void writechar(uchar x, uint chinese) { Write_command(0x30); Write_command(x); Write_data(chinese); } void writechinese(uchar x,const char *p) { uint i; i=strlen(p); Write_command(x); for(;i;i--) Write_data(*(p++)); } void hexdisp(uchar f1) { Write_data('0'+f1+7*(f1/10)); } void hex4(uint f2) { uchar f1; f1=(f2&0xf000)>>12; hexdisp(f1); f1=(f2&0x0f00)>>8; hexdisp(f1); f1=(f2&0xf0)>>4; hexdisp(f1); f1=f2&0x0f; hexdisp(f1); } void liney(uchar x,uchar y,uchar l) //在(x,y)向下開始顯示長度為l(<=16)的豎線 { uchar l1,i; uint x1=0x00,x2=0x00,ix=x/16; l1=x-ix*16; if (l1<8) { x1=0x80>>l1; } else { x2=0x80>>(l1-8); } for (i=0;i<l;i++) { tu[2*ix][y+i]=x1|tu[2*ix][y+i]; tu[2*ix+1][y+i]=x2|tu[2*ix+1][y+i]; Write_command(0x80+y+i); //設(shè)定垂直坐標 Write_command(0x80+ix); //設(shè)定水平坐標 Write_data(tu[2*ix][y+i]); //放入數(shù)據(jù)高字節(jié) Write_data(tu[2*ix+1][y+i]); //放入數(shù)據(jù)低字節(jié) Delayus(100); } } void linex(uchar x,uchar y,uchar l) //在(x,y)向右開始顯示長度為l(<=16)的水平線 { uint l1,l2,x1,x2,x3=0x00,x4=0x00,ix=x/16; l1=x-ix*16; if(l+l1<=8) { l2=8-l-l1; x1=0xff>>(l1+l2); x1=x1<<l2; x2=0x00; } else if(l+l1<=16) { if (l1<8) { l2=16-l-l1; x1=0xff>>l1; x2=0xff<<l2; } else { l2=16-l-l1; x1=0x00; x2=0xff>>(l2+l1-8); x2=x2<<l2; } } else { if (l1<8) { x1=0xff>>l1; x2=0xff; } else { l2=l1-8; x1=0x00; x2=0xff>>l2; } if(l+l1<=24) { l2=24-l-l1; x3=0xff<<l2; x4=0x00; } else { l2=32-l-l1; x3=0xff; x4=0xff<<l2; } } tu[2*ix][y]=x1|tu[2*ix][y]; tu[2*ix+1][y]=x2|tu[2*ix+1][y]; tu[2*ix+2][y]=x3|tu[2*ix+2][y]; tu[2*ix+3][y]=x4|tu[2*ix+3][y]; Write_command(0x80+y); //設(shè)定垂直坐標 Write_command(0x80+ix); //設(shè)定水平坐標 Write_data(tu[2*ix][y]); //放入數(shù)據(jù)高字節(jié) Write_data(tu[2*ix+1][y]); //放入數(shù)據(jù)低字節(jié) Write_data(tu[2*ix+2][y]); //放入數(shù)據(jù)高字節(jié) Write_data(tu[2*ix+3][y]); //放入數(shù)據(jù)低字節(jié) } /**************************************************************************/ //數(shù)據(jù)采集 //溫度讀取 unsigned long ReadOp(void) { ulong dat=0; uint k=12,TEMPTMP=0; TMP121_CS_1; TMP121_CLK_1; Delayus_ms(1); TMP121_CS_0; Delayus_ms(1); do { TMP121_CLK_0; dat=dat<<1; Delayus_ms(1); TEMPTMP=P5IN&0x04; Delayus_ms(1); dat|=TEMPTMP; TMP121_CLK_1; Delayus_ms(1); }while(k--); TMP121_CS_1; dat=dat<<1; return dat; } //光照讀取 uint light() { uint lt; lt=P3IN&0x08==0x08; return lt; } /**************************************************************************/ //數(shù)據(jù)轉(zhuǎn)換 ulong convert() { ulong buffer,a,x; uint k,c,y; x=ReadOp(); y=light(); x&=0xfff8; //取溫度前13位 y=y<<2; //光照信息 a=x|y; buffer=a; for(k=16;k>0;k--) { c^=a&0x0001; //奇偶校驗 a=a>>1; } buffer=buffer|c; return buffer; } /******************************************************************/ //收發(fā) void send_bit1() { send_1; Delayus(500); send_0; Delayus(500); } void send_bit0() { send_0; Delayus(1000); } void send_data() { int k; ulong buffer2; buffer2=convert(); // send_bit1(); // Delayus(500); // send_bit1(); for(k=16;k>0;k--)//發(fā)送數(shù)據(jù)位 { if(buffer2&0x01==0x01) send_bit1(); else send_bit0(); buffer2=buffer2>>1; } } void send_adrs(uint z) { int k; uint buffer1=z; for(k=16;k>0;k--)//發(fā)送地址位 { if(buffer1&0x01==0x01) send_bit1(); else send_bit0(); buffer1=buffer1>>1; } } uint recieve_adrs() { int k,a; uint buffer1=0x0000,b=0x0000; Delayus(250); for(k=32;k>0;k--) { alldata[k]=P2IN&0x02; Delayus(1000); } for(k=32;k>16;k--) { a=alldata[k]; a=a>>1; b=b|a; b=b<<15; buffer1=buffer1>>1; buffer1=buffer1|b; } return buffer1; } ulong recieve_data() { int k,a; ulong buffer2=0x0000,b=0x0000; for(k=16;k>0;k--) { a=alldata[k]; a=a>>1; b=b|a; b=b<<15; buffer2=buffer2>>1; buffer2=buffer2|b; } return buffer2; } /*************************************************************************/ //顯示數(shù)據(jù) void print_tmp() { ulong TEMP=0; int TEMPFLG=0; char TEMP1,TEMP2,TEMP3,TEMP4; TEMP = recieve_data()&0xfff8; if(TEMP>0x8000) { TEMP=TEMP>>3; TEMP=TEMP<<3; TEMP=0xffff-TEMP+1; TEMPFLG=1; } TEMP = TEMP*10; TEMP = TEMP/128; // if( TEMP>35) //P1OUT &= ~BIT1; // Delayus_ms(700); TEMP1=char11[TEMP/1000]; TEMP2=char11[TEMP%1000/100]; TEMP3=char11[TEMP%100/10]; TEMP4=char11[TEMP%10]; if(TEMP1=='0') { if(TEMP2=='0') { if(TEMPFLG==1) writechar(0x90,'-'); writechar(0x91,TEMP3); writechar(0x92,'.'); writechar(0x93,TEMP4); } else { if(TEMPFLG==1) writechar(0x90,'-'); writechar(0x91,TEMP2); writechar(0x92,TEMP3); writechar(0x93,'.'); writechar(0x94,TEMP4); } } else { if(TEMPFLG==1) writechar(0x90,'-'); writechar(0x91,TEMP1); writechar(0x92,TEMP2); writechar(0x93,TEMP3); writechar(0x94,'.'); writechar(0x95,TEMP4); } } void print_light() { ulong lgt; lgt=recieve_data()&0x0004; lgt=lgt>>2; if(lgt) writechinese(0x98,"暗"); else writechinese(0x98,"亮"); } void print_data() { uchar num; num=char11[Tx_Payload[0]]; writechar(0x90,num); num=char11[Tx_Payload[1]]; writechar(0x91,num); num=char11[Tx_Payload[2]]; writechar(0x92,num); } /********************************************************************************/ //鍵盤 void key_Init() { P5SEL = 0; P6SEL = 0; P6DIR|=0xff; //P6=OUT P5DIR=0x8b; //P5.2、4、5、6=in,P5.0、1、3、7=out } void key_read() { //第一排掃描 P6OUT=0x18; Delayus(100); key0=P5IN&0x70 ; if (key0==0x30) { key11='1'; if(keyflg==0) { CLEAR(); writechinese(0x80,"單獨探測節(jié)點"); writechinese(0x90,"1-選擇1#節(jié)點"); writechinese(0x88,"2-選擇2#節(jié)點"); writechinese(0x98,"g-返回主菜單"); keyflg=1; } else if(keyflg==1) { CLEAR(); writechinese(0x80,"尋檢1#節(jié)點"); writechinese(0x90,"d-確認,g-返回"); keyflg=2; } Delayus(30000); } if (key0==0x40) { key11='2'; if(keyflg==0) { CLEAR(); writechinese(0x80,"輪尋模式"); writechinese(0x90,"d-確認,g-返回"); keyflg=4; } if(keyflg==1) { CLEAR(); writechinese(0x80,"尋檢2#節(jié)點"); writechinese(0x90,"d-確認,g-返回"); keyflg=3; } Delayus(30000); } if (key0==0x50) { key11='3'; Delayus(30000); } if (key0==0x60) { Delayus(30000); key11='4'; } //第二排掃描 P6OUT=0x20; Delayus(100); key0=P5IN&0x70 ; if (key0==0x30) { key11='5'; CLEAR(); nRF24L01_TX_MODE(); nRF24L01_Set_Rx_Address(nRF24L01_W_REGISTER+nRF24L01_RX_ADDR_P0,Tx_Address,5); writechinese(0x80,"正在發(fā)送"); nRF24L01_Flush_TX_FIFO(); nRF24L01_Set_Tx_Address(nRF24L01_W_REGISTER+nRF24L01_TX_ADDR,Tx_Address,5);// 指定接收方的地址 nRF24L01_Write_Tx_Payload(Tx_Payload,3);//把1 字節(jié)數(shù)據(jù)放入FIFO nRF24L01_Transmit_Data();//啟動發(fā)送,發(fā)送完成后進入Standby-I 模式 print_data(); Delayus(30000); } if (key0==0x40) { key11='6'; Delayus(30000); } if (key0==0x50) { key11='7'; Delayus(30000); } if (key0==0x60) { key11='8'; Delayus(30000); } //第三排掃描 P6OUT=0x28; Delayus(100); key0=P5IN&0x70 ; if (key0==0x30) { key11='9'; Delayus(30000); } if (key0==0x40) { key11='A'; Delayus(30000); } if (key0==0x50) { key11='B'; Delayus(30000); } if (key0==0x60) { key11='C'; Delayus(30000); } //第四排掃描 P6OUT=0x30; Delayus(100); key0=P5IN&0x70 ; if (key0==0x30) { key11='D'; if(keyflg==2) { CLEAR(); writechinese(0x80,"發(fā)送1#節(jié)點請求"); send_bit1(); send_adrs(0x0001); _EINT(); //發(fā)送1號節(jié)點請求 } if(keyflg==3) { CLEAR(); writechinese(0x80,"發(fā)送2#節(jié)點請求"); send_bit1(); send_adrs(0x0002); _EINT(); //發(fā)送2號節(jié)點請求 } if(keyflg==4) { CLEAR(); writechinese(0x80,"發(fā)送1#節(jié)點請求"); send_bit1(); send_adrs(0x0001); keyflg=2; Delayus(20000); writechinese(0x80,"發(fā)送2#節(jié)點請求"); send_bit1(); send_adrs(0x0002); keyflg=3; _EINT(); } Delayus(30000); } if (key0==0x40) { key11='E'; Delayus(30000); } if (key0==0x50) { key11='F'; Delayus(30000); } if (key0==0x60) { key11='G'; CLEAR(); writechinese(0x80,"江南大學"); writechinese(0x90,"通信與控制工程"); writechinese(0x88,"無線監(jiān)測模擬裝置"); Delayus(100000); CLEAR(); writechinese(0x80,"選擇接受模式"); writechinese(0x90,"1-單獨探測節(jié)點"); writechinese(0x88,"2-輪巡模式"); keyflg=0; Delayus(30000); Init_nRF24L01_IO(); } } void print1(ulong x) { ulong cvt0,cvt1; int k,i; char data[10]; cvt0=x; for(k=4,i=0;k>0;k--,i++) { cvt1=cvt0&0x000f; data[i]=char11[cvt1%16]; cvt0=cvt0>>4; } writechar(0x90,data[3]); writechar(0x91,data[2]); writechar(0x92,data[1]); writechar(0x93,data[0]); } void main(void) { WDTCTL=WDTPW+WDTHOLD; _DINT(); Init_Port1(); IO_Init(); LCD_Init(); CLEAR(); key11='M'; // LCDL='安'; //漢字顯示示例 writechinese(0x80,"江南大學"); writechinese(0x90,"通信與控制工程"); writechinese(0x88,"無線監(jiān)測模擬裝置"); Delayus(100000); CLEAR(); writechinese(0x80,"選擇接受模式"); writechinese(0x90,"1-單獨探測節(jié)點"); writechinese(0x88,"2-輪巡模式"); keyflg=0; bostart=0x00; boflg=0x00; key_Init(); Init_nRF24L01_IO(); _EINT(); do { key11='w' ; key_read(); }while(1); } #pragma vector=PORT1_VECTOR __interrupt void P1_ISR(void) { _DINT(); P1IFG=0; P1IE=0; P1IES=0; Delayus(500); writechinese(0x88,"發(fā)送成功"); IO_Init(); Init_Port1(); _EINT(); }
