專注電子技術(shù)學習與研究
基于MSP430單片機驅(qū)動NRF24L01無線模塊接收C語言程序
作者:佚名   來源:本站原創(chuàng)   點擊數(shù):  更新時間:2013年04月23日   【字體:
        NRF24L01無線模塊在此程序中可以直接與MSP430單片機直接相連,單片機的電壓和無線模塊的電壓都是3.3V,
無需加阻流電阻。通信接口為單片機模擬的SP口,LC12864液晶屏主要是用作把接收到數(shù)據(jù)通過其顯示出來。
程序測試通過,可用!
//p4口為液晶屏
//p1口中斷
//nRF24L01無線通信
//p5.0  csn
//p5.1  mosi
//p5.3  sck
//p5.2  miso
//p1.2  irq
//p5.7  ce
//ST7920串行控制128*64液晶
//rst  p4.3   復位
//rs   p4.0   片選
//rw   p4.1    數(shù)據(jù)
//E    p4.2    時鐘
#include <msp430x16x.h>
#include <string.h>
#define ulong unsigned long
#define LCD_CLK_1   (P4OUT |=  BIT2)
#define LCD_CLK_0   (P4OUT &=~ BIT2)
#define LCD_D_1   (P4OUT |=  BIT1)
#define LCD_D_0   (P4OUT &=~ BIT1)
#define LCD_RST_1  (P4OUT |=  BIT3)
#define LCD_RST_0  (P4OUT &=~ BIT3)
#define LCD_CS_1 (P4OUT |= BIT0)
#define LCD_CS_0 (P4OUT &= ~BIT0)
#define TMP121_CS_1 (P5OUT |= BIT7)
#define TMP121_CS_0 (P5OUT &= ~BIT7)
#define TMP121_CLK_1 (P5OUT |= BIT3)
#define TMP121_CLK_0 (P5OUT &= ~BIT3)
#define send_1 (P2OUT |= BIT0)
#define send_0 (P2OUT &= ~BIT0)
#define CPU_F ((double)1000000) // MCLK=1MHZ主頻
#define Delayus_us(x) __Delayus_cycles((long)(CPU_F*(double)x/1000000.0))
#define Delayus_ms(x) __Delayus_cycles((long)(CPU_F*(double)x/1000.0))
#define Delayus_s(x) __Delayus_cycles((long)(CPU_F*(double)x/1.0))
uint  alldata[32],keyflg;
uchar char11[16]={'0','1','2','3','4','5','6','7','8','9','a','b','c','d','e','f'};
uchar busy='A',hang,lie,flash_flag,bostart;
uchar key0=0,key1='T',key2,boflg,flg,key2flg=0,tab1=1,newsflag1,newsflag2;
uchar key11,key12;
uint LCDL;
uchar tu[32][32]={0x00};
uint Rdata[8]={0},botu[98]={0x0000};
unsigned char Rx_Address[5]={100,101,102,103,104};//本機地址
unsigned char Rx_Buff[32]={7,8,9};
void Delayus(ulong ilinshi)
{ ulong ii;
 for(ii=0;ii<=ilinshi;ii++)
  key0=key0;
#define nRF24L01_CE_1   (P5OUT|= BIT7)
#define nRF24L01_CE_0   (P5OUT&=~BIT7)
#define nRF24L01_CSN_1  (P5OUT|= BIT0)
#define nRF24L01_CSN_0  (P5OUT&=~BIT0)
#define nRF24L01_SCK_1  (P5OUT|= BIT3)
#define nRF24L01_SCK_0  (P5OUT&=~BIT3)
#define nRF24L01_MOSI_1 (P5OUT|= BIT1)
#define nRF24L01_MOSI_0 (P5OUT&=~BIT1)
//SPI Commands
#define nRF24L01_R_REGISTER    0x00
#define nRF24L01_W_REGISTER    0x20
#define nRF24L01_R_RX_PAYLOAD  0x61
#define nRF24L01_W_TX_PAYLOAD  0xA0
#define nRF24L01_FLUSH_TX      0xE1
#define nRF24L01_FLUSH_RX      0xE2
#define nRF24L01_REUSE_TX_PL   0xE3
#define nRF24L01_NOP           0xFF
//NRF24L01寄存器地址
#define nRF24L01_CONFIG        0x00
#define nRF24L01_EN_AA         0x01
#define nRF24L01_EN_RXADDR     0x02
#define nRF24L01_SETUP_AW      0x03
#define nRF24L01_SETUP_RETR    0x04
#define nRF24L01_RF_CH         0x05
#define nRF24L01_RF_SETUP      0x06
#define nRF24L01_STATUS        0x07
#define nRF24L01_OBSERVE_TX    0x08
#define nRF24L01_CD            0x09
#define nRF24L01_RX_ADDR_P0    0x0A
#define nRF24L01_RX_ADDR_P1    0x0B
#define nRF24L01_RX_ADDR_P2    0x0C
#define nRF24L01_RX_ADDR_P3    0x0D
#define nRF24L01_RX_ADDR_P4    0x0E
#define nRF24L01_RX_ADDR_P5    0x0F
#define nRF24L01_TX_ADDR       0x10
#define nRF24L01_RX_PW_P0      0x11
#define nRF24L01_RX_PW_P1      0x12
#define nRF24L01_RX_PW_P2      0x13
#define nRF24L01_RX_PW_P3      0x14
#define nRF24L01_RX_PW_P4      0x15
#define nRF24L01_RX_PW_P5      0x16
#define nRF24L01_FIFO_STATUS   0x17
void IO_Init(void)   //初始化端口
 P2SEL = 0;
 P3SEL = 0;
 P4SEL = 0;
 P4DIR|=0x0f;              //P4.0,1,2,3=OUT
 P4OUT|=0x0f;
 P2DIR=0xfd;              //P2.1=in    qita=OUT
 P3DIR&=0xf7;              //p3.3=in
void Init_Port1(void)   //P1.0、P1.1為中斷,下降沿觸發(fā)
   P1SEL=0;                         //設置為普通I/O口功能
   P1DIR=0;                         //設置為輸入方向
   P1IE=0;
   P1IES=0;
   P1IE|=BIT2;                           //打開中斷允許
   P1IES|=BIT2;                          //下降沿觸發(fā)
   P1IFG=0;                              //P1IES的切換可能使P1IFG置位,需清除
//無線通信
void Init_nRF24L01_IO()
 nRF24L01_CE_0;
 nRF24L01_CSN_1;
 nRF24L01_SCK_0;
 nRF24L01_MOSI_0;
//NRF24L01的SPI寫時序
void nRF24L01SpiWrite(unsigned char byte)
unsigned char i;
nRF24L01_SCK_0;
Delayus(1);
for (i=0;i<8;i++) // Setup byte circulation bits
if ((byte&BIT7)==BIT7) // Put DATA_BUF.7 on data line
nRF24L01_MOSI_1; //MOSI=1;
nRF24L01_MOSI_0; //MOSI=0;
nRF24L01_SCK_1; // Set clock line high
Delayus(2);
byte=byte<<1;
nRF24L01_SCK_0; // Set clock line low
Delayus(2);
Delayus(1);
//NRF24L01的SPI讀時序
unsigned char nRF24L01SpiRead(void)
unsigned char i;
unsigned char temp=0;
nRF24L01_SCK_0;
Delayus(2);
Delayus(2);
temp=temp<<1; // Right shift DATA_BUF
if ((P5IN&BIT2)==BIT2)
{temp|=1;} // Read data
Delayus(2);
Delayus(2);
return temp;
void nRF24L01_Flush_TX_FIFO(void)//Clear TX FIFO
nRF24L01_CSN_1;
nRF24L01_CSN_0;
nRF24L01SpiWrite(nRF24L01_FLUSH_TX);
nRF24L01_CSN_1;
void nRF24L01_Flush_RX_FIFO(void)//Clear RX FIFO
nRF24L01_CSN_1;
nRF24L01_CSN_0;
nRF24L01SpiWrite(nRF24L01_FLUSH_RX);
nRF24L01_CSN_1;
void nRF24L01SpiWriteReg(unsigned char SpiCommand,unsigned char Content)
nRF24L01_CSN_1;
nRF24L01_CSN_0;
nRF24L01SpiWrite(SpiCommand);
nRF24L01SpiWrite(Content);
nRF24L01_CSN_1;
void nRF24L01_Set_Rx_Address(unsigned char RX_Address_Pipex,unsigned char *Address,unsigned char Length)//Local
//Address
unsigned char i=0;
nRF24L01_CSN_1;
nRF24L01_CSN_0;
nRF24L01SpiWrite(RX_Address_Pipex);
for(i=0;i<Length;i++)
nRF24L01SpiWrite(*Address);
Address++;
nRF24L01_CSN_1;
void nRF24L01_Set_Tx_Address(unsigned char TX_AddressReg10,unsigned char *Address,unsigned char Length)//Remote
//Address
unsigned char i=0;
nRF24L01_CSN_1;
nRF24L01_CSN_0;
nRF24L01SpiWrite(TX_AddressReg10);
Address++;
nRF24L01_CSN_1;
void nRF24L01_Read_Rx_Payload(unsigned char *DataBuff,unsigned char Length)//Payload Out
unsigned char i=0;
nRF24L01_CSN_1;
nRF24L01_CSN_0;
nRF24L01SpiWrite(nRF24L01_R_RX_PAYLOAD);
*DataBuff=nRF24L01SpiRead();
DataBuff++;
nRF24L01_CSN_1;
void nRF24L01_Write_Tx_Payload(unsigned char *DataByte, unsigned char Length)//Payload IN
unsigned char i=0;
nRF24L01_CSN_1;
nRF24L01_CSN_0;
nRF24L01SpiWrite(nRF24L01_W_TX_PAYLOAD);
nRF24L01SpiWrite(*DataByte);
DataByte++;
nRF24L01_CSN_1;
void nRF24L01_Transmit_Data(void)//Transmit Pulse
Delayus(10);
nRF24L01_CE_1;
Delayus(8000);
nRF24L01_CE_0;
void nRF24L01_RX_MODE(void)
nRF24L01SpiWriteReg(nRF24L01_W_REGISTER+nRF24L01_CONFIG,0x3f);//Reflect DX_DR
nRF24L01SpiWriteReg(nRF24L01_W_REGISTER+nRF24L01_EN_AA,0x00);////Disable auto_acknowledgment,6 pipes
nRF24L01SpiWriteReg(nRF24L01_W_REGISTER+nRF24L01_EN_RXADDR,0x01);//Enabled RX Addresses.Enable data pipe 0
nRF24L01SpiWriteReg(nRF24L01_W_REGISTER+nRF24L01_SETUP_AW,0x03);//RX/TX Address field width 5 bytes.
nRF24L01SpiWriteReg(nRF24L01_W_REGISTER+nRF24L01_SETUP_RETR,0x00);//Re-Transmit disabled.
nRF24L01SpiWriteReg(nRF24L01_W_REGISTER+nRF24L01_RF_CH,0x02);//RF Channel.
nRF24L01SpiWriteReg(nRF24L01_W_REGISTER+nRF24L01_RF_SETUP,0x06);//Air Data Rate 1Mbps.RF_PWR:0dBm.LNA Gain 0.
nRF24L01SpiWriteReg(nRF24L01_W_REGISTER+nRF24L01_RX_PW_P0,0x03);//Pipe0 1 Bytes Payload.
nRF24L01SpiWriteReg(nRF24L01_W_REGISTER+nRF24L01_STATUS,0x4e);//Reset_Rx_DS
//以下是液晶屏顯示程序
void Write_command(uchar x)
   uchar b,i=0;
   Delayus(3);
   b=x;
   LCD_CS_1;  //cs=1;
   LCD_D_1;  //data=1;
   for(i=0;i<5;i++)   //5 個連續(xù)1 '11111'
       LCD_CLK_0;  //clk=0
       LCD_CLK_1; ;  //clk=1
   LCD_CLK_0;  //clk=0
   LCD_D_0;  //data=0;
   for(i=0;i<3;i++)  //RS,RW,0           Rs="Rw"=0   //寫命令
       LCD_CLK_0;  //clk=0
   ////////////////////////////////////上面是發(fā)送一個完整的啟動數(shù)據(jù)'11111000'
   for(i=0;i<4;i++)      //發(fā)送高4位
      if((x&0x80)?1:0)   //1
        LCD_D_1;  //data=1;
        LCD_D_0;  //data=0;
       LCD_CLK_0;  //clk=0
      x=x<<1;
    LCD_D_0;  //data=0;
   for(i=0;i<4;i++)  //RS,RW,0    發(fā)送4個0;
       LCD_CLK_0;  //clk=0
   for(i=0;i<4;i++)      //發(fā)送低4位
      if((b&0x08)?1:0)   //1
        LCD_D_1;  //data=1;
        LCD_D_0;  //data=0;
      LCD_CLK_0;  //clk=0
      b=b<<1;
   LCD_D_0;  //data=0;
      LCD_CLK_0;  //clk=0
   LCD_CS_1;  //cs=1;
   Delayus(15);
void Write_data(uchar x)
   uchar b,i=0;
   Delayus(3);
   b=x;
   LCD_CS_1;  //cs=1;
   LCD_D_1;  //data=1;
       LCD_CLK_0;  //clk=0
   LCD_CLK_0;  //clk=0    //RW=0
   LCD_D_0;  //data=0;
   LCD_CLK_1;   //clk=1
   LCD_CLK_0;  //clk=0    //RS=1
   LCD_D_1;  //data=0;
   LCD_CLK_1;   //clk=1
   LCD_CLK_0;  //clk=0    //0
   LCD_D_0;  //data=0;
   LCD_CLK_1;   //clk=1
////////////////////////////////////上面是發(fā)送一個完整的啟動數(shù)據(jù)'11111010'
        LCD_D_1;  //data=1;
        LCD_D_0;  //data=0;
      LCD_CLK_0;  //clk=0
      LCD_CLK_1;   //clk=1
      x=x<<1;
    LCD_D_0;  //data=0;
      LCD_CLK_0;  //clk=0
        LCD_D_1;  //data=1;
        LCD_D_0;  //data=0;
      LCD_CLK_0;  //clk=0
      b=b<<1;
   LCD_D_0;  //data=0;
      LCD_CLK_0;  //clk=0
   LCD_CS_1;  //cs=1;
   Delayus(15);
void CLEAR()
 Write_command(0x30);
 Write_command(0x01);
 Write_command(0x34);
void drclear(void)
//以下是清繪畫RAM
 uchar i,j;
   for(j=0;j<32;j++)
    for(i=0;i<32;i++)
       tu[i][j]=0x00;
   for(j=0;j<32;j++)
    for(i=0;i<16;i++)
       tu[i][j]=0x00;
       Write_command(0x80+j);  //設定垂直坐標
       Write_command(0x80+i);  //設定水平坐標
       Write_data(0x00);  //放入數(shù)據(jù)高字節(jié)
       Write_data(0x00);  //放入數(shù)據(jù)低字節(jié)
void LCD_Init()
LCD_RST_0;    //rst=0
Delayus(100);
LCD_RST_1;    //rst=1
Delayus(100);
Delayus(20);
Delayus(20);
Write_command(0x0c);
//Write_command(0x0C);
Delayus(10);
Delayus(20);
Write_command(0x06);
//以下是清繪畫RAM
 uchar i,j;
   for(j=0;j<32;j++)
    for(i=0;i<16;i++)
void writechar(uchar x, uint chinese)
Write_command(x);
Write_data(chinese);
void writechinese(uchar x,const char *p)
uint i;
i=strlen(p);
Write_command(x);
for(;i;i--)
Write_data(*(p++));
void hexdisp(uchar f1)
   Write_data('0'+f1+7*(f1/10));
void hex4(uint f2)
uchar f1;
f1=(f2&0xf000)>>12;
hexdisp(f1);
f1=(f2&0x0f00)>>8;
hexdisp(f1);
f1=(f2&0xf0)>>4;
hexdisp(f1);
f1=f2&0x0f;
hexdisp(f1);
void liney(uchar x,uchar y,uchar l)  //在(x,y)向下開始顯示長度為l(<=16)的豎線
 uchar l1,i;
 uint x1=0x00,x2=0x00,ix=x/16;
 l1=x-ix*16;
 if (l1<8)
   x1=0x80>>l1;
  x2=0x80>>(l1-8);
 for (i=0;i<l;i++)
   tu[2*ix][y+i]=x1|tu[2*ix][y+i];
   tu[2*ix+1][y+i]=x2|tu[2*ix+1][y+i];
       Write_command(0x80+y+i);  //設定垂直坐標
       Write_command(0x80+ix);  //設定水平坐標
       Write_data(tu[2*ix][y+i]);  //放入數(shù)據(jù)高字節(jié)
       Write_data(tu[2*ix+1][y+i]);  //放入數(shù)據(jù)低字節(jié)
       Delayus(100);
void linex(uchar x,uchar y,uchar l)  //在(x,y)向右開始顯示長度為l(<=16)的水平線
 uint l1,l2,x1,x2,x3=0x00,x4=0x00,ix=x/16;
 l1=x-ix*16;
 if(l+l1<=8)
  l2=8-l-l1;
 x1=0xff>>(l1+l2);
 x1=x1<<l2;
 x2=0x00;
 else if(l+l1<=16)
 if (l1<8)
 l2=16-l-l1;
 x1=0xff>>l1;
 x2=0xff<<l2;
 l2=16-l-l1;
 x1=0x00;
 x2=0xff>>(l2+l1-8);
 x2=x2<<l2;
  if (l1<8)
 x1=0xff>>l1;
 x2=0xff;
 l2=l1-8;
 x1=0x00;
 x2=0xff>>l2;
 if(l+l1<=24)
  l2=24-l-l1;
  x3=0xff<<l2;
  x4=0x00;
 l2=32-l-l1;
 x3=0xff;
 x4=0xff<<l2;
 tu[2*ix][y]=x1|tu[2*ix][y];
 tu[2*ix+1][y]=x2|tu[2*ix+1][y];
 tu[2*ix+2][y]=x3|tu[2*ix+2][y];
 tu[2*ix+3][y]=x4|tu[2*ix+3][y];
       Write_command(0x80+y);  //設定垂直坐標
       Write_data(tu[2*ix][y]);  //放入數(shù)據(jù)高字節(jié)
       Write_data(tu[2*ix+1][y]);  //放入數(shù)據(jù)低字節(jié)
       Write_data(tu[2*ix+2][y]);  //放入數(shù)據(jù)高字節(jié)
       Write_data(tu[2*ix+3][y]);  //放入數(shù)據(jù)低字節(jié)
//數(shù)據(jù)采集
//溫度讀取
unsigned long ReadOp(void)
{ ulong dat=0;
uint k=12,TEMPTMP=0;
TMP121_CS_1;
TMP121_CLK_1;
Delayus_ms(1);
TMP121_CS_0;
Delayus_ms(1);
do
TMP121_CLK_0;
dat=dat<<1;
Delayus_ms(1);
TEMPTMP=P5IN&0x04;
Delayus_ms(1);
dat|=TEMPTMP;
TMP121_CLK_1;
Delayus_ms(1);
}while(k--);
TMP121_CS_1;
dat=dat<<1;
return dat;
//光照讀取
uint light()
 uint lt;
 lt=P3IN&0x08==0x08;
 return lt;
//數(shù)據(jù)轉(zhuǎn)換
ulong convert()
{ ulong buffer,a,x;
 uint k,c,y;
 x=ReadOp();
 y=light();
 x&=0xfff8;  //取溫度前13位
 y=y<<2;       //光照信息
 a=x|y;
 buffer=a;
 for(k=16;k>0;k--)
   c^=a&0x0001;   //奇偶校驗
   a=a>>1;
 buffer=buffer|c;
 return buffer;
//收發(fā)
void send_bit1()
 send_1;
 Delayus(500);
 send_0;
 Delayus(500);
void send_bit0()
 send_0;
 Delayus(1000);
void send_data()
  int k;
  ulong buffer2;
  buffer2=convert();
  for(k=16;k>0;k--)//發(fā)送數(shù)據(jù)位
     if(buffer2&0x01==0x01)
       send_bit1();
       send_bit0();
       buffer2=buffer2>>1;
void send_adrs(uint z)
{ int k;
 uint buffer1=z;
 for(k=16;k>0;k--)//發(fā)送地址位
     if(buffer1&0x01==0x01)
       send_bit1();
       send_bit0();
       buffer1=buffer1>>1;
uint recieve_adrs()
 int k,a;
 uint buffer1=0x0000,b=0x0000;
 Delayus(250);
 for(k=32;k>0;k--)
   alldata[k]=P2IN&0x02;
   Delayus(1000);
for(k=32;k>16;k--)
   a=alldata[k];
   a=a>>1;
   b=b|a;
   b=b<<15;
   buffer1=buffer1>>1;
   buffer1=buffer1|b;
 return buffer1;
ulong recieve_data()
 int k,a;
 ulong buffer2=0x0000,b=0x0000;
for(k=16;k>0;k--)
   a=alldata[k];
   a=a>>1;
   b=b|a;
   b=b<<15;
   buffer2=buffer2>>1;
   buffer2=buffer2|b;
 return buffer2;
//顯示數(shù)據(jù)
void print_tmp()
 ulong TEMP=0;
 int TEMPFLG=0;
 char TEMP1,TEMP2,TEMP3,TEMP4;
 TEMP = recieve_data()&0xfff8;
if(TEMP>0x8000)
  TEMP=TEMP>>3;
  TEMP=TEMP<<3;
  TEMP=0xffff-TEMP+1;
  TEMPFLG=1;
TEMP = TEMP*10;
TEMP = TEMP/128;
//    if( TEMP>35)
   //P1OUT &= ~BIT1;
//    Delayus_ms(700);
  TEMP1=char11[TEMP/1000];
  TEMP2=char11[TEMP%1000/100];
  TEMP3=char11[TEMP%100/10];
  TEMP4=char11[TEMP%10];
  if(TEMP1=='0')
  { if(TEMP2=='0')
      if(TEMPFLG==1)
      writechar(0x90,'-');
      writechar(0x91,TEMP3);
      writechar(0x92,'.');
      writechar(0x93,TEMP4);
     if(TEMPFLG==1)
     writechar(0x91,TEMP2);
     writechar(0x92,TEMP3);
     writechar(0x93,'.');
      writechar(0x94,TEMP4);
    if(TEMPFLG==1)
   writechar(0x91,TEMP1);
   writechar(0x92,TEMP2);
   writechar(0x93,TEMP3);
   writechar(0x94,'.');
   writechar(0x95,TEMP4);
void print_light()
 ulong lgt;
 lgt=recieve_data()&0x0004;
 lgt=lgt>>2;
if(lgt)
   writechinese(0x98,"暗");
   writechinese(0x98,"亮");
void print_data()
 uchar num;
 num=char11[Rx_Buff[0]];
 writechar(0x90,num);
 num=char11[Rx_Buff[1]];
 writechar(0x91,num);
 num=char11[Rx_Buff[2]];
 writechar(0x92,num);
//鍵盤
void key_Init()
 P5SEL = 0;
 P6SEL = 0;
 P6DIR|=0xff;              //P6=OUT
 P5DIR=0x8b;              //P5.2、4、5、6=in,P5.0、1、3、7=out
void key_read()
 //第一排掃描
 P6OUT=0x18;
 Delayus(100);
 key0=P5IN&0x70 ;
  if (key0==0x30)
   key11='1';
   if(keyflg==0)
     CLEAR();
     writechinese(0x80,"單獨探測節(jié)點");
     writechinese(0x90,"1-選擇1#節(jié)點");
     writechinese(0x88,"2-選擇2#節(jié)點");
     writechinese(0x98,"g-返回主菜單");
     keyflg=1;
   else if(keyflg==1)
     CLEAR();
     writechinese(0x80,"尋檢1#節(jié)點");
     writechinese(0x90,"d-確認,g-返回");
     keyflg=2;
   Delayus(30000);
  if (key0==0x40)
   key11='2';
   if(keyflg==0)
     CLEAR();
     writechinese(0x80,"輪尋模式");
     keyflg=4;
   if(keyflg==1)
     CLEAR();
     writechinese(0x80,"尋檢2#節(jié)點");
     keyflg=3;
 Delayus(30000);
  if (key0==0x50)
 key11='3';
 Delayus(30000);
  if (key0==0x60)
 Delayus(30000);
  key11='4';
//第二排掃描
 P6OUT=0x20;
 Delayus(100);
 key0=P5IN&0x70 ;
  if (key0==0x30)
   key11='5';
Delayus(30000);
  if (key0==0x40)
 key11='6';
Delayus(30000);
  if (key0==0x50)
 key11='7';
Delayus(30000);
  if (key0==0x60)
 key11='8';
 Delayus(30000);
//第三排掃描
 P6OUT=0x28;
 Delayus(100);
 key0=P5IN&0x70 ;
  if (key0==0x30)
 key11='9';
 Delayus(30000);
  if (key0==0x40)
 key11='A';
Delayus(30000);
  if (key0==0x50)
 key11='B';
 Delayus(30000);
  if (key0==0x60)
 key11='C';
Delayus(30000);
  //第四排掃描
 P6OUT=0x30;
 Delayus(100);
 key0=P5IN&0x70 ;
  if (key0==0x30)
 key11='D';
  if(keyflg==2)
   CLEAR();
   writechinese(0x80,"發(fā)送1#節(jié)點請求");
   send_bit1();
   send_adrs(0x0001);
   _EINT();
   //發(fā)送1號節(jié)點請求
 if(keyflg==3)
   CLEAR();
   writechinese(0x80,"發(fā)送2#節(jié)點請求");
   send_bit1();
   send_adrs(0x0002);
   _EINT();
   //發(fā)送2號節(jié)點請求
 if(keyflg==4)
   CLEAR();
   send_bit1();
   send_adrs(0x0001);
   keyflg=2;
   Delayus(20000);
   send_bit1();
   send_adrs(0x0002);
   keyflg=3;
   _EINT();
 Delayus(30000);
  if (key0==0x40)
 key11='E';
 Delayus(30000);
  if (key0==0x50)
 key11='F';
 Delayus(30000);
  if (key0==0x60)
 key11='G';
 CLEAR();
 writechinese(0x80,"江南大學");
 writechinese(0x90,"通信與控制工程");
 writechinese(0x88,"無線監(jiān)測模擬裝置");
 Delayus(100000);
 CLEAR();
 writechinese(0x80,"選擇接受模式");
 writechinese(0x90,"1-單獨探測節(jié)點");
 writechinese(0x88,"2-輪巡模式");
 keyflg=0;
 Delayus(30000);
 Init_nRF24L01_IO();
void print1(ulong x)
ulong cvt0,cvt1;
 int k,i;
 char data[10];
 cvt0=x;
   for(k=4,i=0;k>0;k--,i++)
     cvt1=cvt0&0x000f;
     data[i]=char11[cvt1%16];
     cvt0=cvt0>>4;
   writechar(0x90,data[3]);
   writechar(0x91,data[2]);
   writechar(0x92,data[1]);
   writechar(0x93,data[0]);
//主程序
void main(void)
 WDTCTL=WDTPW+WDTHOLD;
  _DINT();
  Init_Port1();
  IO_Init();
  LCD_Init();
  CLEAR();
 key11='M';
// LCDL='安';
 //漢字顯示示例
Delayus(100000);
CLEAR();
writechinese(0x80,"調(diào)試接收模式");
//writechinese(0x90,"1-單獨探測節(jié)點");
//writechinese(0x88,"2-輪巡模式");
keyflg=0;
 bostart=0x00;
 boflg=0x00;
 key_Init();
 Init_nRF24L01_IO();
 nRF24L01_RX_MODE();
 nRF24L01_Set_Rx_Address(nRF24L01_W_REGISTER+nRF24L01_RX_ADDR_P0,Rx_Address,5);
 nRF24L01_Flush_RX_FIFO();
 nRF24L01_CE_1;
 _EINT();
do
key11='w' ;
key_read();
}while(1);
#pragma vector=PORT1_VECTOR
__interrupt void P1_ISR(void)
 _DINT();
 P1IFG=0;
   P1IE=0;
   P1IES=0;
  Delayus(500);
  CLEAR();
  writechinese(0x80,"正在接收");
//  print_data();
  nRF24L01_Read_Rx_Payload(Rx_Buff,3);
  print_data();
  IO_Init();
  Init_Port1();
  _EINT();
