這里是視頻 傳到土豆網(wǎng)了:
電路圖和制作詳情請從這里下載附件: http://www.torrancerestoration.com/bbs/dpj-18970-1.html ,下面是程序源代碼
*程序說明:
*此ATmega128單片機(jī)程序
*包含功能:
*1、
*2、
*3、
*4、
*5、
*文件:main.c
*用途:系統(tǒng)主程序
*注意:系統(tǒng)時(shí)鐘8MHZ
*編譯環(huán)境:Code VisionAVR
*版本:智能循跡小車v1.0
*作者:吾ARM1
*修改時(shí)間?012年4月19日
*完成時(shí)間:2012年4月16日
#include<mega128.h>
#include "delay.h"
#define left1 PORTC.0
#define left2 PORTC.1
#define min PORTC.2
#define right1 PORTC.3
#define right2 PORTC.4
#define Turn_Left PORTC.5
#define Turn_Right PORTC.6
#define u8 unsigned char
#define u16 unsigned int
void Init_IO(void)
DDRC = DDRC&0xe0; //將C端口低5位定義為輸入,浮空
PORTC = 0xe0;//
DDRB = 0xff; //將B端口設(shè)為輸出模式
PORTB = 0xff;
PORTA = 0xff;
DDRA = 0xff;
void Adjust_Speed(u8 Left_Speed,u8 Right_Speed)
OCR1A = (u16)Right_Speed*10 ;//Left_Speed:1--100,為右電機(jī)占空比
OCR1B = (u16)Left_Speed*10;//Right_Speed:1--100,為左電機(jī)的占空比
void Init_Timer1(void)
{ u16 i,j;
i = 300; //實(shí)際測試發(fā)現(xiàn)1600時(shí)電機(jī)速度還是很快的。
j = 300;
TCCR1A = 0xa0;//相位與頻率修正PWM,TOP值為ICR1,向上計(jì)數(shù)匹配清零,向下計(jì)數(shù)匹配時(shí)置1
TCCR1B = 0x12;//系統(tǒng)時(shí)鐘8分頻,A,B同時(shí)輸出PWM
OCR1A = i; //右電機(jī)
OCR1B = j; //在電機(jī)
ICR1 = 1000;
void main(void)
Init_IO();
Init_Timer1();
if(PINC==0xfb)//只有中間循跡管檢測到黑線11011
Adjust_Speed(90,90);//前進(jìn)(35,35):一圈循跡時(shí)間16.3S (38,38)一圈循跡時(shí)間15.5s (40,40)一圈循跡時(shí)間16.34s (50,50)15.34s(60,60)14.21s
PORTA = 0xfe; //(80,80)13.68s
if(PINC==0xf9)//中間和左邊第二個(gè)循跡管檢測到黑線10011
Adjust_Speed(20,60);//左轉(zhuǎn)
// delay_ms(5);
PORTA = 0xfd;
if(PINC==0xfd)//左邊第二個(gè)循跡管檢測到黑線10111
Adjust_Speed(15,65);//左轉(zhuǎn)
//delay_ms(5);
PORTA = 0xfb;
if(PINC==0xfc)//左邊兩個(gè)同時(shí)檢測到黑線00111
Adjust_Speed(10,70);//左轉(zhuǎn)
PORTA = 0xf7;
if(PINC==0xfe)//左邊第一個(gè)循跡管檢測到黑線01111
Adjust_Speed(7,85);//左轉(zhuǎn)
// delay_ms(5);
PORTA = 0xef;
if(PINC==0xf3)//中間和右邊第二個(gè)循跡管檢測到黑線11001
Adjust_Speed(35,15);//右轉(zhuǎn)
PORTA = 0xdf;
if(PINC==0xf7)//右邊第二個(gè)循跡管檢測到黑線11101
Adjust_Speed(70,13);//右轉(zhuǎn)
PORTA = 0xbf;
if(PINC==0xe7)//右邊兩個(gè)檢測到黑線11100
Adjust_Speed(80,10);//右轉(zhuǎn)
PORTA = 0x7f;
if(PINC==0xef)//右邊第一個(gè)檢測到黑線11110
Adjust_Speed(100,10);//右轉(zhuǎn)
PORTA = 0xfc;
if(PINC==0xe3)//右側(cè)三個(gè)循跡管同時(shí)檢測到黑線(直角)11000
Adjust_Speed(40,0);//右轉(zhuǎn)
PORTA = 0xf8;
if(PINC==0xe7)//左側(cè)三個(gè)循跡管同時(shí)檢測到黑線(直角)00011左轉(zhuǎn)
Adjust_Speed(0,40);//左轉(zhuǎn)
PORTA = 0xf0;
if(PINC==0xe0)//5個(gè)循跡管同時(shí)檢測到交叉00000直走
Adjust_Speed(25,25);//直走
PORTA = 0xe0;
// if(PINC==0xff)
// Adjust_Speed(0,100);//直走
// PORTA = 0xc0;
