此程序已經(jīng)應用在本人的一個項目中非常穩(wěn)定,編寫過程中參考了51hei網(wǎng)站里面的 http://www.torrancerestoration.com/mcu/1541.html 這篇文章.部分子程序節(jié)選于此.
#include "reg52.h"
#include "intrins.h"
#include "math.h"
#include "stdio.h"
sbit BT_SND =P1^5;
sbit BT_REC =P1^6;
sbit LED =P1^7;
bit LED_flage=1;
//單片機IO 口模擬232串口通訊程序
//使用兩種方式的C程序 占用定時器0
#define MODE_QUICK
#define F_TM F0
#define TIMER0_ENABLE TL0=TH0; TR0=1;
#define TIMER0_DISABLE TR0=0;
sbit ACC0= ACC^0;
sbit ACC1= ACC^1;
sbit ACC2= ACC^2;
sbit ACC3= ACC^3;
sbit ACC4= ACC^4;
sbit ACC5= ACC^5;
sbit ACC6= ACC^6;
sbit ACC7= ACC^7;
void IntTimer0() interrupt 1
F_TM=1;
//發(fā)送一個字符
void PSendChar(unsigned char inch)
#ifdef MODE_QUICK
ACC=inch;
F_TM=0;
BT_SND=0; //start bit
TIMER0_ENABLE; //啟動
while(!F_TM);
BT_SND=ACC0; //先送出低位
F_TM=0;
while(!F_TM);
BT_SND=ACC1;
F_TM=0;
while(!F_TM);
BT_SND=ACC2;
F_TM=0;
while(!F_TM);
BT_SND=ACC3;
F_TM=0;
while(!F_TM);
BT_SND=ACC4;
F_TM=0;
while(!F_TM);
BT_SND=ACC5;
F_TM=0;
while(!F_TM);
BT_SND=ACC6;
F_TM=0;
while(!F_TM);
BT_SND=ACC7;
F_TM=0;
while(!F_TM);
BT_SND=1;
F_TM=0;
while(!F_TM);
TIMER0_DISABLE; //停止timer
#else
unsigned char ii;
ii=0;
F_TM=0;
TIMER0_ENABLE; //啟動
while(!F_TM);
while(ii<8)
if(inch&1)
BT_SND=1;
BT_SND=0;
F_TM=0;
while(!F_TM);
ii++;
inch>>=1;
BT_SND=1;
F_TM=0;
while(!F_TM);
#endif
//接收一個字符
unsigned char PGetChar()
#ifdef MODE_QUICK
TIMER0_ENABLE;
F_TM=0;
while(!F_TM); //等過起始位
ACC0=BT_REC;
TL0=TH0;
F_TM=0;
while(!F_TM);
ACC1=BT_REC;
F_TM=0;
while(!F_TM);
ACC2=BT_REC;
F_TM=0;
while(!F_TM);
ACC3=BT_REC;
F_TM=0;
while(!F_TM);
ACC4=BT_REC;
F_TM=0;
while(!F_TM);
ACC5=BT_REC;
F_TM=0;
while(!F_TM);
ACC6=BT_REC;
F_TM=0;
while(!F_TM);
ACC7=BT_REC;
F_TM=0;
while(!F_TM)
if(BT_REC)
break;
return ACC;
#else
unsigned char rch,ii;
TIMER0_ENABLE;
F_TM=0;
ii=0;
rch=0;
while(ii<8)
rch>>=1;
if(BT_REC)
rch|=0x80;
ii++;
F_TM=0;
while(!F_TM);
F_TM=0;
while(!F_TM)
if(BT_REC)
break;
return rch;
#endif
//檢查是不是有起始位
bit StartBitOn()
return (BT_REC==0);
//定時器1初始化
void Time1_Init(void)
TMOD=0x22; //定時器1為工作模式2(8位自動重裝),0為模式2(8位自動重裝)
PCON=00;
TR0=0; //在發(fā)送或接收才開始使用
TF0=0;
TH0=(256-96); //9600bps 就是 1000000/9600=104.167微秒 執(zhí)行的timer//104.167*11.0592/12= 96
TL0=TH0;
ET0=1;
EA=1;
//發(fā)送字符串
void Send_Char(char *byte)
int i=0;
for(i=0;*(byte+i)!='\0';i++)
PSendChar(*(byte+i));
//void delay(int x)
// int a,b;
// for(a=x;a>0;a--)
// for(b=10;b>0;b--);
//void main()
// unsigned char gch;
// Time1_Init();
// LED=0;
// // Send_Char("S00.0C00.0%E00.0C00.0%L00000lx");
// while(1)
// PSendChar('1');
// delay(1000);
//// if(StartBitOn())
//// gch=PGetChar();
//// if(gch=='1')
//// LED=LED_flage;
//// delay(1000);
//// LED_flage=~LED_flage;
