這是一個(gè)用于實(shí)際產(chǎn)品的stc單片機(jī)按鍵處理程序頭文件和原理圖可從原帖下載: http://www.torrancerestoration.com/bbs/dpj-19294-1.html
#include "STC12C5620AD.H" #include "Key_Scan.H" #include "Key_Handle.H" #include "DS1302.H" #include "Radio.H" #include "Channel_Handle.H" #include "Volume_Handle.H" /********************** 聲明外部變量**************************/ extern uchar Volume; //Volume_Handle.c extern uint PLL; //From Radio.c extern bit Flag_40ms; //From Main.c extern uchar Work_Mode; //From Main.c extern uchar data Sec; //From DS1302.c extern uchar data Min; //From DS1302.c extern uchar data Hour; //From DS1302.c extern uchar data Date; //From DS1302.c extern uchar data Month; //From DS1302.c extern uchar data Day; //From DS1302.c extern uchar data Year; //From DS1302.c extern uchar Display_Channel[]; //From Main.c /********************** 定義變量**************************/ uchar Radio_Index; //預(yù)置電臺(tái)切換計(jì)數(shù),0-15,8用于記錄最后一次的電臺(tái) uchar Key_Flag=0x00; //按鍵計(jì)時(shí),有按鍵時(shí)清零,無按鍵10S左右使Woke_Mode=0; /********************** 按鍵處理**************************/ void Key_Handle() { uchar Time_Write_Temp; //調(diào)整用的緩存 uchar Key_Value; Radio_Index=EEPROM_Get_Index(); //獲取頻道序號(hào) Display_Channel[3]=(Radio_Index/10)|0x30; Display_Channel[4]=(Radio_Index%10)|0x30; //顯示頻道序號(hào) if(Flag_40ms) { Key_Value=Key_Scan(); //40ms進(jìn)行一次掃描 Flag_40ms=0; Key_Flag++; if(Key_Flag>=250) { Key_Flag=250; LCD_BLK=0; Work_Mode=0; //無按鍵10s后,自動(dòng)回到模式0 } else LCD_BLK=1; } switch (Key_Value) { case 0x0e: //按下MENU switch (Work_Mode) { case 0: Work_Mode=1; //進(jìn)入電臺(tái)搜索 break; case 1: Work_Mode=2; //進(jìn)入調(diào)節(jié)年份 break; case 2: Work_Mode=3; //進(jìn)入調(diào)節(jié)月份 break; case 3: Work_Mode=4; //進(jìn)入調(diào)節(jié)日 break; case 4: Work_Mode=5; //進(jìn)入調(diào)節(jié)星期 break; case 5: Work_Mode=6; //進(jìn)入調(diào)節(jié)時(shí) break; case 6: Work_Mode=7; //進(jìn)入調(diào)節(jié)分 break; case 7: DS1302_Write_Data(0x8e,0x00); // 禁止寫保護(hù) DS1302_Write_Data(0x80,0x00); //秒置0 DS1302_Write_Data(0x8e,0x80); // 開啟寫保護(hù) Work_Mode=0; //回到正常顯示 break; default: break; } Key_Flag=0; //清除按鍵計(jì)時(shí) break; case 0x0d: //按下|<< switch (Work_Mode) { case 0: //正常狀態(tài) Radio_Index--; //上一個(gè)預(yù)置電臺(tái) if(Radio_Index<1) Radio_Index=15; EEPROM_Write_Index(Radio_Index); //更新新電臺(tái)序號(hào) PLL=EEPROM_Get_PLL(Radio_Index); //更新新電臺(tái)PLL TEA5767_Update_PLL(); //寫入PLL break; case 1: TEA5767_User_Search(0); //向下手動(dòng)搜索 break; case 2: //年減少 Time_Write_Temp=(Year>>4)*10+(Year&0x0f); //裝換成十進(jìn)制數(shù) if(Time_Write_Temp==0) {Time_Write_Temp=99;} else {Time_Write_Temp--;} Year=(Time_Write_Temp/10)<<4|(Time_Write_Temp%10); //裝換成BCD DS1302_Write_Data(0x8e,0x00); // 禁止寫保護(hù) DS1302_Write_Data(0x8c,Year); //寫入 DS1302_Write_Data(0x8e,0x80); // 開啟寫保護(hù) break; case 3: //月減少 Time_Write_Temp=(Month>>4)*10+(Month&0x0f); //裝換成十進(jìn)制數(shù) if(Time_Write_Temp==1) {Time_Write_Temp=12;} else {Time_Write_Temp--;} Month=(Time_Write_Temp/10)<<4|(Time_Write_Temp%10); //裝換成BCD DS1302_Write_Data(0x8e,0x00); // 禁止寫保護(hù) DS1302_Write_Data(0x88,Month); //寫入 DS1302_Write_Data(0x8e,0x80); // 開啟寫保護(hù) break; case 4: //日減少 Time_Write_Temp=(Date>>4)*10+(Date&0x0f); //裝換成十進(jìn)制數(shù) if(Time_Write_Temp==1) {Time_Write_Temp=31;} else {Time_Write_Temp--;} Date=(Time_Write_Temp/10)<<4|(Time_Write_Temp%10); //裝換成BCD DS1302_Write_Data(0x8e,0x00); // 禁止寫保護(hù) DS1302_Write_Data(0x86,Date); //寫入 DS1302_Write_Data(0x8e,0x80); // 開啟寫保護(hù) break; case 5: //星期減少 Time_Write_Temp=(Day>>4)*10+(Day&0x0f); //裝換成十進(jìn)制數(shù) if(Time_Write_Temp==1) {Time_Write_Temp=7;} else {Time_Write_Temp--;} Day=(Time_Write_Temp/10)<<4|(Time_Write_Temp%10); //裝換成BCD DS1302_Write_Data(0x8e,0x00); // 禁止寫保護(hù) DS1302_Write_Data(0x8a,Day); //寫入 DS1302_Write_Data(0x8e,0x80); // 開啟寫保護(hù) break; case 6: //時(shí)減少 Time_Write_Temp=(Hour>>4)*10+(Hour&0x0f); //裝換成十進(jìn)制數(shù) if(Time_Write_Temp==0) {Time_Write_Temp=23;} else {Time_Write_Temp--;} Hour=(Time_Write_Temp/10)<<4|(Time_Write_Temp%10); //裝換成BCD DS1302_Write_Data(0x8e,0x00); // 禁止寫保護(hù) DS1302_Write_Data(0x84,Hour); //寫入 DS1302_Write_Data(0x8e,0x80); // 開啟寫保護(hù) break; case 7: //分減少 Time_Write_Temp=(Min>>4)*10+(Min&0x0f); //裝換成十進(jìn)制數(shù) if(Time_Write_Temp==0) {Time_Write_Temp=59;} else {Time_Write_Temp--;} Min=(Time_Write_Temp/10)<<4|(Time_Write_Temp%10); //裝換成BCD DS1302_Write_Data(0x8e,0x00); // 禁止寫保護(hù) DS1302_Write_Data(0x82,Min); //寫入 DS1302_Write_Data(0x8e,0x80); // 開啟寫保護(hù) break; case 8: //音量調(diào)節(jié) Volume+=5; //音量減小5dB if(Volume>=35) Volume=35; Volume_Write(Volume); //寫入聲音參數(shù) break; default: break; } Key_Flag=0; //清除按鍵計(jì)時(shí) break; case 0x0b: //按下>>| switch (Work_Mode) { case 0: //正常狀態(tài) Radio_Index++; //下一個(gè)預(yù)置電臺(tái) if(Radio_Index==16) Radio_Index=1; EEPROM_Write_Index(Radio_Index); //更新新電臺(tái)序號(hào) PLL=EEPROM_Get_PLL(Radio_Index); //更新新電臺(tái)PLL TEA5767_Update_PLL(); //寫入PLL break; case 1: TEA5767_User_Search(1); //向上手動(dòng)搜索 break; case 2: //年增加 Time_Write_Temp=(Year>>4)*10+(Year&0x0f); //裝換成十進(jìn)制數(shù) if(Time_Write_Temp==99) {Time_Write_Temp=0;} else {Time_Write_Temp++;} Year=(Time_Write_Temp/10)<<4|(Time_Write_Temp%10); //裝換成BCD DS1302_Write_Data(0x8e,0x00); // 禁止寫保護(hù) DS1302_Write_Data(0x8c,Year); //寫入 DS1302_Write_Data(0x8e,0x80); // 開啟寫保護(hù) break; case 3: //月增加 Time_Write_Temp=(Month>>4)*10+(Month&0x0f); //裝換成十進(jìn)制數(shù) if(Time_Write_Temp==12) {Time_Write_Temp=1;} else {Time_Write_Temp++;} Month=(Time_Write_Temp/10)<<4|(Time_Write_Temp%10); //裝換成BCD DS1302_Write_Data(0x8e,0x00); // 禁止寫保護(hù) DS1302_Write_Data(0x88,Month); //寫入 DS1302_Write_Data(0x8e,0x80); // 開啟寫保護(hù) break; case 4: //日增加 Time_Write_Temp=(Date>>4)*10+(Date&0x0f); //裝換成十進(jìn)制數(shù) if(Time_Write_Temp==31) {Time_Write_Temp=1;} else {Time_Write_Temp++;} Date=(Time_Write_Temp/10)<<4|(Time_Write_Temp%10); //裝換成BCD DS1302_Write_Data(0x8e,0x00); // 禁止寫保護(hù) DS1302_Write_Data(0x86,Date); //寫入 DS1302_Write_Data(0x8e,0x80); // 開啟寫保護(hù) break; case 5: //星期增加 Time_Write_Temp=(Day>>4)*10+(Day&0x0f); //裝換成十進(jìn)制數(shù) if(Time_Write_Temp==7) {Time_Write_Temp=1;} else {Time_Write_Temp++;} Day=(Time_Write_Temp/10)<<4|(Time_Write_Temp%10); //裝換成BCD DS1302_Write_Data(0x8e,0x00); // 禁止寫保護(hù) DS1302_Write_Data(0x8a,Day); //寫入 DS1302_Write_Data(0x8e,0x80); // 開啟寫保護(hù) break; case 6: //時(shí)增加 Time_Write_Temp=(Hour>>4)*10+(Hour&0x0f); //裝換成十進(jìn)制數(shù) if(Time_Write_Temp==23) {Time_Write_Temp=0;} else {Time_Write_Temp++;} Hour=(Time_Write_Temp/10)<<4|(Time_Write_Temp%10); //裝換成BCD DS1302_Write_Data(0x8e,0x00); // 禁止寫保護(hù) DS1302_Write_Data(0x84,Hour); //寫入 DS1302_Write_Data(0x8e,0x80); // 開啟寫保護(hù) break; case 7: //分增加 Time_Write_Temp=(Min>>4)*10+(Min&0x0f); //裝換成十進(jìn)制數(shù) if(Time_Write_Temp==59) {Time_Write_Temp=0;} else {Time_Write_Temp++;} Min=(Time_Write_Temp/10)<<4|(Time_Write_Temp%10); //裝換成BCD DS1302_Write_Data(0x8e,0x00); // 禁止寫保護(hù) DS1302_Write_Data(0x82,Min); //寫入 DS1302_Write_Data(0x8e,0x80); // 開啟寫保護(hù) break; case 8: //音量調(diào)節(jié) if(Volume<=0) Volume=0; else Volume-=5; //音量增加5dB Volume_Write(Volume); //寫入聲音參數(shù) break; default: break; } Key_Flag=0; //清除按鍵計(jì)時(shí) break; case 0x07: //按下SET { switch (Work_Mode) { case 0: //正常狀態(tài) Work_Mode=8; //轉(zhuǎn)到音量調(diào)節(jié)狀態(tài) break; case 1: //電臺(tái)搜索 EEPROM_Save_PLL(Radio_Index,PLL); //存入新收到的電臺(tái) Work_Mode=0; break; case 8: //音量調(diào)節(jié)狀態(tài) Work_Mode=0; //轉(zhuǎn)到正常狀態(tài) break; default: DS1302_Write_Data(0x8e,0x00); // 禁止寫保護(hù) DS1302_Write_Data(0x80,0x00); //置秒為00,并啟動(dòng)時(shí)鐘 DS1302_Write_Data(0x8e,0x80); // 開啟寫保護(hù) Work_Mode=0; break; } } Key_Flag=0; //清除按鍵計(jì)時(shí) break; default: break; } }
