MSP430單片機(jī)串行四線驅(qū)動1602液晶程序
作者:佚名   來源:本站原創(chuàng)   點(diǎn)擊數(shù):  更新時間:2013年08月06日   【字體:
#include "msp430g2553.h"
#define RS_1 P1OUT|=BIT3;//輸入數(shù)據(jù)
#define RS_0 P1OUT&=~BIT3;//輸入指令
#define RW_1 P1OUT|=BIT4;//寫入指令或者數(shù)據(jù)
#define RW_0 P1OUT&=~BIT4;//從lcd里面讀取數(shù)據(jù)
#define EN_1 P1OUT|=BIT5;//讀取信息
#define EN_0 P1OUT&=~BIT5;//下降沿時候執(zhí)行指令
#define datt P2OUT;
uchar temp=0;
uchar  table1[]={"hello"};
uchar  table2[]={"hello"};
 * 延時程序
void delay(uint i)
uint j;
while(--i!=0)
for(j=0;j<255;j++);
 * 忙信號檢查
uchar chkbusy()
uchar busy;
P2OUT=0xf0;
EN_0;//讀取數(shù)據(jù)
RS_0;//輸入指令
RW_1;//寫入指令或者數(shù)據(jù)
EN_1;//讀取信息
busy=P2OUT&0x80;
delay(1);
EN_0;//下降沿執(zhí)行指令
return(busy);
 * 寫指令
void writecom(uchar x,uchar comm)
//if(x) while(chkbusy());
EN_0;
RS_0;
RW_0;
EN_1;
P2OUT=(comm&0xf0);
delay(5);
EN_0;
delay(5);
EN_1;
P2OUT=(comm&0x0f)<<4;
delay(5);
EN_0;
 * 寫數(shù)據(jù)
void writedata(uchar dat)
//while(chkbusy()); //檢查忙信號
EN_0;
RS_1;
RW_0;
EN_1;
P2OUT=(dat&0xf0); //送高四位數(shù)據(jù)到P2口
delay(5);
EN_0;
delay(5);
EN_1;
P2OUT=(dat&0x0f)<<4; //送低四位數(shù)據(jù)到P2口
delay(5);
EN_0;
P2OUT=P2OUT|0x0f; //置低四位為1
 * lcd初始化程序
void lcdinit()
delay(30);
writecom(0,0x02);//數(shù)據(jù)指針清零
delay(5);
writecom(1,0x28);//
writecom(1,0x0c);//顯示光標(biāo)開及設(shè)置
writecom(1,0x06);//顯示光標(biāo)移動設(shè)置
writecom(1,0x01);//顯示清屏
delay(10);
 * 在指定位置顯示一個字符,x為行,Y為列
void displayone(uchar x,uchar y,uchar *n)
uchar add;
if (x == 1) add=0x80+y;
//writecom(1,add);
else add=0xc0+y;
writecom(1,add);
writedata(*n);
 * 顯示字符串
void displayleng(uchar x,uchar y,uchar *s)
y=y&0x0f;
while(*s)
displayone(x,y,s);
y++;
s++;
 * 主函數(shù)
 WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
    P2SEL=0x00;
    P2DIR = 0xff;
    P1DIR = 0x38;
lcdinit();
//lcdcls();
P2OUT=0xff;
writecom(1,0x01);
//writedata(0x01);
displayleng(1,0,table1);
delay(100);
displayleng(2,1,table2);
