三通道12位模數(shù)轉(zhuǎn)換MAX1241串口傳輸單片機(jī)C程序
作者:佚名   來(lái)源:本站原創(chuàng)   點(diǎn)擊數(shù):  更新時(shí)間:2013年11月12日   【字體:
今天完成數(shù)據(jù)傳輸硬件程序,才用8位傳輸,位數(shù)太多就拆開(kāi),分高8位和低8位,電路圖在這里:http://www.torrancerestoration.com/mcu/2273.html 程序可以參考使用:
#include<reg51.h>
#define uint  unsigned int
#define High 1
#define Low 0
int t1,t2,t3,t4,t5,t6,t7,t11,t12,t21,t22,t31,t32;
int t;
sbit cs=P2^7;
sbit sclk=P2^6;
sbit dout=P2^5;
sbit cs2=P2^4;
sbit sclk2=P2^3;
sbit dout2=P2^2;
sbit cs3=P2^1;
sbit sclk3=P2^0;
sbit dout3=P0^7;
uint dushuju() //定義為可以返回的參數(shù)
 uint voltage_temp=0;
 uchar ucloop=12;
 cs=High;
 sclk=Low;
 cs=Low;
 while(dout==0);//EOC信號(hào)為高表示轉(zhuǎn)換結(jié)束
 sclk=High;
 sclk=Low;
 while(ucloop--)
 sclk=High;//上升沿?cái)?shù)據(jù)穩(wěn)定并讀出
 voltage_temp<<=1;
 if(dout==1)
 voltage_temp+=1;
 sclk=Low;
 cs=High;
 return voltage_temp;   //返回?cái)?shù)據(jù)
uint dushuju2() //定義為可以返回的參數(shù)
 uint voltage_temp2=0;
 uchar ucloop=12;
 cs2=High;
 sclk2=Low;
 cs2=Low;
 while(dout2==0);//EOC信號(hào)為高表示轉(zhuǎn)換結(jié)束
 sclk2=High;
 sclk2=Low;
 while(ucloop--)
 sclk2=High;//上升沿?cái)?shù)據(jù)穩(wěn)定并讀出
 voltage_temp2<<=1;
 if(dout2==1)
 voltage_temp2+=1;
 sclk2=Low;
 cs2=High;
 return voltage_temp2;   //返回?cái)?shù)據(jù)
uint dushuju3() //定義為可以返回的參數(shù)
 uint voltage_temp3=0;
 uchar ucloop=12;
 cs3=High;
 sclk3=Low;
 cs3=Low;
 while(dout3==0);//EOC信號(hào)為高表示轉(zhuǎn)換結(jié)束
 sclk3=High;
 sclk3=Low;
 while(ucloop--)
 sclk3=High;//上升沿?cái)?shù)據(jù)穩(wěn)定并讀出
 voltage_temp3<<=1;
 if(dout3==1)
 voltage_temp3+=1;
 sclk3=Low;
 cs3=High;
 return voltage_temp3;   //返回?cái)?shù)據(jù)
uint dushuju4() //定義為可以返回的參數(shù)
 uint voltage_temp4=0;
 uchar ucloop=12;
 cs=High;
 sclk=Low;
 cs=Low;
 sclk=High;
 sclk=Low;
 while(ucloop--)
 voltage_temp4<<=1;
 if(dout==1)
 voltage_temp4+=1;
 sclk=Low;
 cs=High;
 return voltage_temp4;   //返回?cái)?shù)據(jù)
 void shuju(void)
 t4=dushuju();
 t5=dushuju2();
 t6=dushuju3();
 t12=t4%256; //將數(shù)據(jù)轉(zhuǎn)換為高8位和低8位
 t11=t4/256%256;
 t22=t5%256;
 t21=t5/256%256;
 t32=t6%256;
 t31=t6/256%256;
 void shujul(void)
 t7=dushuju4();
void csh(void)
 SM0=0;
 SM1=1;
 REN=1;
 TI=0;
 RI=0;
 PCON=0;
 TH1=0xF3;
 TL1=0XF3;
 TMOD=0X20;
 EA=1;
 ET1=0;
 ES=1;
 TR1=1;
 TI=0;
 SBUF=1;
 while(!TI);
 TI=0;
 SBUF=t11;
 while(!TI);
 TI=0;
 SBUF=t12;
 while(!TI);
 TI=0;
 SBUF=2;
 while(!TI);
 TI=0;
 SBUF=t21;
 while(!TI);
 TI=0;
 SBUF=t22;
 while(!TI);
 TI=0;
 SBUF=3;
 while(!TI);
 TI=0;
 SBUF=t31;
 while(!TI);
 TI=0;
 SBUF=t32;
 while(!TI);
 TI=0;
void main(void)
 shuju();
 csh();
 loop:
 shujul();
 if ((t7-t4)>=10)
 shuju();
 csh();
 goto loop ;
 goto loop ;
