* 標題: 試驗數(shù)碼管上顯示數(shù)字( 單片機直接實現(xiàn)位選 共陰極) *
* 連接方法:P0與J12 用8PIN排線連接 P1與JP16 用排線連接 *
* 用573鎖存器控制和單片機腳直接位選控制(非譯碼器控制)數(shù)碼管 *
#include<reg52.h>
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=0;y<113;y++)
unsigned int code dbit[8]={0xfe,0xfd,0xfb,0xf7,0xef,0xdF,0xbF,0x7F};
unsigned int code num[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x40};
P1=dbit[4];
P0=num[9];
位定義
#include<reg52.h>
#include<intrins.h>
sbit LSA=P2^2;
sbit LSB=P2^3;
sbit LSC=P2^4;
uchar code num[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=0;y<113;y++)
LSA=0;
LSB=0;
LSC=0;
P0=num[6];
delay(2);
LSA=1;
LSB=0;
LSC=0;
P0=num[6];
delay(2);
//讓八個數(shù)碼管全部亮并且從0~9循環(huán)
#include<reg52.h>
#include<intrins.h>
uchar num;
uchar wnum=0x00;
uchar code dbit[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};//段選,選擇要顯示的數(shù)字
//uchar code wnum[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdF,0xbF,0x7F};//八位數(shù)碼管
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=0;y<113;y++)
P1=wnum;
for(num=0;num<10;num++)
P0=dbit[num];
delay(500);
