本程序所用的原理圖下載: 點這里 ,單片機芯片使用的stc89c52;找到點陣部分的原理圖即可.這是一整個單片機開發(fā)板的電路圖其他的忽略
下面是程序源碼:
/******點陣LED刷新顯示I LVOE U**************/
*功能:點陣LED一秒刷新顯示I 心形 U(I LOVE YOU)
*作者:徐冉
*日期:2013-06-14-22:44
*備注:程序已調(diào)試成功
/*************AT89C52-RC MCU*******************/
/**************51hei開發(fā)板********************/
#include <reg52.h>
typedef unsigned int uint;
typedef unsigned char uchar;
sbit din = P2^0;
sbit cs = P2^1;
sbit clk = P2^2;
uchar code table[5][8] = {
{0x00,0x3C,0x18,0x18,0x18,0x18,0x3C,0x00}, //'I'
{0x00,0x66,0xFF,0xFF,0xFF,0x7E,0x3C,0x18}, //'心'
{0x00,0x66,0x66,0x66,0x66,0x7E,0x3C,0x00}, //'U'
uchar i, j;
uint counter;
//寫字節(jié)
void write_byte(uchar date)
uchar i;
cs = 0;
for(i = 0; i < 8; i++)
clk = 0;
din = date & 0x80;
date <<= 1;
clk = 1;
//寫MAX7219
void write_max7219(uchar add, uchar date)
cs = 0;
write_byte(add);
write_byte(date);
cs = 1;
//MAX7219初始化
void max7219_init()
write_max7219(0x0c, 0x01);//正常模式
write_max7219(0x09, 0x00);//譯碼模式
write_max7219(0x0a, 0x08);//亮度控制
write_max7219(0x0b, 0x07);//掃描模式
write_max7219(0x0f, 0x00);//顯示檢測
//定時器T0初始化
void timer0_init()
TMOD = 0x01;
TH0 = 0x94; //定時30ms
TL0 = 0x00;
TR0 = 1;
EA = 1;
ET0 = 1;
//主程序
void main(void)
max7219_init();
timer0_init();
if(i >= 8)
i = 0;
if(counter == 40)
counter = 0;
j++;
if(j >= 3)
j = 0;
write_max7219(i+1, table[j][i]);
//中斷服務(wù)程序
void timer0_int() interrupt 1
TH0 = 0x94;
TL0 = 0x00;
i++;
counter++;
