單片機(jī)控制點(diǎn)陣矩形收縮閃爍源程序
作者:寒竹子   來源:本站原創(chuàng)   點(diǎn)擊數(shù):  更新時(shí)間:2014年03月21日   【字體:
本程序所用的原理圖下載: 點(diǎn)這里 ,單片機(jī)芯片使用的stc89c52;找到點(diǎn)陣部分的原理圖即可.這是一整個(gè)單片機(jī)開發(fā)板的電路圖其他的忽略
以下是程序源碼:
*功能:矩形收縮閃爍
*作者:徐冉
*日期:2013-06-26-22:13
*備注:程序調(diào)試成功
/********AT89C52-RC MCU****************/
/*************51hei開發(fā)板**************/
#include <reg52.h>
typedef unsigned int uint;
typedef unsigned char uchar;
sbit din = P2^0;
sbit cs = P2^1;
sbit clk = P2^2;
uchar code dis[][8] ={
       {0xFF,0x81,0x81,0x81,0x81,0x81,0x81,0xFF},
          {0x00,0x7E,0x42,0x42,0x42,0x42,0x7E,0x00},
       {0x00,0x00,0x3C,0x24,0x24,0x3C,0x00,0x00},
       {0x00,0x00,0x00,0x18,0x18,0x00,0x00,0x00}
//延時(shí)xms
void delay(uint xms)
 uint x, y;
 for(x = xms; x > 0; x--)
  for(y = 110; y > 0; y--);
//寫一個(gè)字節(jié)
void write_byte(uchar date)
 uchar i, temp;
 temp = date;
 cs = 0; //選通MAX7219
 for(i = 0; i < 8; i++)
  clk = 0;
  din = temp & 0x80;
  temp <<= 1;
  clk = 1; //時(shí)鐘上升沿脈沖
//寫MAX7219
void write_max7219(uchar address, uchar date)
 cs = 0;//選通MAX7219
 write_byte(address);
 write_byte(date);
 cs = 1;
//MAX7219初始化
void max7219_init()
 write_max7219(0x0c, 0x01);
 write_max7219(0x09, 0x00);
 write_max7219(0x0a, 0x05);
 write_max7219(0x0b, 0x07);
 write_max7219(0x0f, 0x00);
//主程序
void main(void)
 uchar i, j;
 delay(50);//稍作延時(shí)
 max7219_init();
  for(i = 0; i < 4; i++)
   for(j = 0; j < 8; j++)
    write_max7219(j+1, dis[i][j]);//寫入MAX7219數(shù)據(jù)
   delay(100); //延時(shí)100ms
