本程序所用的原理圖下載: 點這里 ,單片機芯片使用的stc89c52;找到相應部分即可.這是一整個單片機開發(fā)板的電路圖其他的忽略.
hex文件及其工程文件下載:http://www.torrancerestoration.com/f/pingfc.rar 下面是程序源碼:
*功能:使用矩陣按鍵使得按鍵按下時數(shù)碼管上顯示各自對應的數(shù)字的立方數(shù)
* 優(yōu)化顯示,只顯示有效位;
* 且使用獨立按鍵實現(xiàn)key1清零,key2加數(shù),key3減數(shù);
*日期:2013-05-07-10:20
*作者:徐冉
*特別說明:本程序代碼已經(jīng)通過調試,僅供學習使用;
/***********AT89C52-RC 單片機-51hei實驗板***********/
/*****************51hei開發(fā)板*********************/
#include <reg52.h>
typedef unsigned int uint;
typedef unsigned char uchar;
sbit wela = P2^7;
sbit dula = P2^6;
sbit key1 = P3^4;
sbit key2 = P3^5;
sbit key3 = P3^6;
sbit fm = P2^3;
uint temp;
uchar code table[] = {
0x3F, //"0"
0x06, //"1"
0x5B, //"2"
0x4F, //"3"
0x66, //"4"
0x6D, //"5"
0x7D, //"6"
0x07, //"7"
0x7F, //"8"
0x6F, //"9"
0x77, //"A"
0x7C, //"B"
0x39, //"C"
0x5E, //"D"
0x79, //"E"
0x71, //"F"
0x76, //"H"
0x38, //"L"
0x37, //"n"
0x3E, //"u"
0x73, //"P"
0x5C, //"o"
0x40, //"-"
0x00, //熄滅
0x00 //自定義
// uchar key; Error!!! 此時的key值大于258 超出了uchar 故錯誤!!
uint key;
void display(num);
void delay(uint xms);
void max_kanscan();
void keyscan();
void main(void)
keyscan();
max_kanscan();
display(key);
void display(num)
uchar qian, bai, shi, ge;
qian = num / 1000 % 10;
bai = num / 100 % 10;
shi = num / 10 % 10;
ge = num % 10;
if(num < 10)
dula = 1;
P0 =table[ge];
dula = 0;
P0 = 0xff;
wela = 1;
P0 = 0xfe;
wela = 0;
else if(num < 100)
dula = 1;
P0 =table[shi];
dula = 0;
P0 = 0xff;
wela = 1;
P0 = 0xfe;
wela = 0;
P0 = 0x00;
delay(1);
dula = 1;
P0 =table[ge];
dula = 0;
P0 = 0xff;
wela = 1;
P0 = 0xfd;
wela = 0;
P0 = 0x00;
delay(1);
else if(num < 1000)
dula = 1;
P0 =table[bai];
dula = 0;
P0 = 0xff;
wela = 1;
P0 = 0xfe;
wela = 0;
P0 = 0x00;
delay(1);
dula = 1;
P0 =table[shi];
dula = 0;
P0 = 0xff;
wela = 1;
P0 = 0xfd;
wela = 0;
P0 = 0x00;
delay(1);
dula = 1;
P0 =table[ge];
dula = 0;
P0 = 0xff;
wela = 1;
P0 = 0xfb;
wela = 0;
P0 = 0x00;
delay(1);
else if(num < 10000)
dula = 1;
P0 =table[qian];
dula = 0;
P0 = 0xff;
wela = 1;
P0 = 0xfe;
wela = 0;
P0 = 0x00;
delay(1);
dula = 1;
P0 =table[bai];
dula = 0;
P0 = 0xff;
wela = 1;
P0 = 0xfd;
wela = 0;
P0 = 0x00;
delay(1);
dula = 1;
P0 =table[shi];
dula = 0;
P0 = 0xff;
wela = 1;
P0 = 0xfb;
wela = 0;
P0 = 0x00;
delay(1);
dula = 1;
P0 =table[ge];
dula = 0;
P0 = 0xff;
wela = 1;
P0 = 0xf7;
wela = 0;
P0 = 0x00;
delay(1);
uint i, j;
for(i = xms; i > 0; i--)
for(j = 125; j > 0; j--);
void keyscan()
if(key1 == 0)
delay(5);
if(key1 == 0)
fm = 0;
key = 0;
while(!key1);
delay(5);
while(!key1);
fm = 1;
if(key2 == 0)
delay(5);
if(key2 == 0)
fm = 0;
key++;
while(!key2);
delay(5);
while(!key2);
fm = 1;
if(key3 == 0)
delay(5);
if(key3 == 0)
fm = 0;
key--;
while(!key3);
delay(5);
while(!key3);
fm = 1;
void max_kanscan()
P3 = 0xfe;
temp = P3;
temp &= 0xf0;
if(temp != 0xf0)
delay(5);
temp = P3;
temp &= 0xf0;
if(temp != 0xf0)
{ //按鍵檢測
temp = P3;
fm = 0;
switch(temp)
case 0xee: key = 1 * 1 *1;
break;
case 0xde: key = 2 * 2 *2;
break;
case 0xbe: key = 3 * 3 *3;
break;
case 0x7e: key = 4 * 4 *4;
break;
default:
break;
//按鍵釋放
while(temp != 0xf0)
temp = P3;
temp &= 0xf0;
delay(5);
while(temp != 0xf0)
temp = P3;
temp &= 0xf0;
fm = 1;
P3 = 0xfd;
temp = P3;
temp &= 0xf0;
if(temp != 0xf0)
delay(5);
temp = P3;
temp &= 0xf0;
if(temp != 0xf0)
{ //按鍵檢測
temp = P3;
fm = 0;
switch(temp)
case 0xed: key = 5 * 5 *5;
break;
case 0xdd: key = 6 * 6 *6;
break;
case 0xbd: key = 7 * 7 *7;
break;
case 0x7d: key = 8 * 8 *8;
break;
default:
break;
//按鍵釋放
while(temp != 0xf0)
temp = P3;
temp &= 0xf0;
delay(5);
while(temp != 0xf0)
temp = P3;
temp &= 0xf0;
fm = 1;
P3 = 0xfb;
temp = P3;
temp &= 0xf0;
if(temp != 0xf0)
delay(5);
temp = P3;
temp &= 0xf0;
if(temp != 0xf0)
{ //按鍵檢測
temp = P3;
fm = 0;
switch(temp)
case 0xeb: key = 9 * 9 *9;
break;
case 0xdb: key = 10 * 10 *10;
break;
case 0xbb: key = 11 * 11 *11;
break;
case 0x7b: key = 12 * 12 *12;
break;
default:
break;
//按鍵釋放
while(temp != 0xf0)
temp = P3;
temp &= 0xf0;
delay(5);
while(temp != 0xf0)
temp = P3;
temp &= 0xf0;
fm = 1;
P3 = 0xf7;
temp = P3;
temp &= 0xf0;
if(temp != 0xf0)
delay(5);
temp = P3;
temp &= 0xf0;
if(temp != 0xf0)
{ //按鍵檢測
temp = P3;
fm = 0;
switch(temp)
case 0xe7: key = 13 * 13 *13;
break;
case 0xd7: key = 14 * 14 *14;
break;
case 0xb7: key = 15 * 15 *15;
break;
case 0x77: key = 16 * 16 *16;
break;
default:
break;
//按鍵釋放
while(temp != 0xf0)
temp = P3;
temp &= 0xf0;
delay(5);
while(temp != 0xf0)
temp = P3;
temp &= 0xf0;
fm = 1;
