51單片機(jī)矩陣鍵盤檢測源代碼(按鍵數(shù)碼管顯示0-F)
作者:寒竹子   來源:本站原創(chuàng)   點(diǎn)擊數(shù):  更新時(shí)間:2014年03月23日   【字體:
本程序所用的原理圖下載: 點(diǎn)這里 ,單片機(jī)芯片使用的stc89c52;找到相應(yīng)部分即可.這是一整個(gè)單片機(jī)開發(fā)板的電路圖其他的忽略.
hex文件及其工程文件下載:http://www.torrancerestoration.com/f/juzhen.rar  以下是通過測試的源代碼:
*功能:使用矩陣按鍵使得按鍵按下時(shí)數(shù)碼管上顯示各自對(duì)應(yīng)的數(shù)字(0 ~ F);
*日期:2013-05-03-17:51;
*作者:徐冉
*特別說明:本程序代碼已經(jīng)通過調(diào)試,僅供學(xué)習(xí)使用;
/***********AT89C52-RC 單片機(jī)51hei 實(shí)驗(yàn)板***********/
/*****************51hei-開發(fā)板*********************/
#include <reg52.h>
typedef unsigned int uint;
typedef unsigned char uchar;
sbit wela = P2^7;
sbit dula = P2^6;
sbit FM = P2^3;
uchar code table[] = {
    0x3F,  //"0"
                0x06,  //"1"
                0x5B,  //"2"
                0x4F,  //"3"
                0x66,  //"4"
                0x6D,  //"5"
                0x7D,  //"6"
                0x07,  //"7"
                0x7F,  //"8"
                0x6F,  //"9"
                0x77,  //"A"
                0x7C,  //"B"
                0x39,  //"C"
                0x5E,  //"D"
                0x79,  //"E"
                0x71,  //"F"
                0x76,  //"H"
                0x38,  //"L"
                0x37,  //"n"
                0x3E,  //"u"
                0x73,  //"P"
                0x5C,  //"o"
                0x40,  //"-"
                0x00,  //熄滅
                0x00  //自定義
uchar key, temp;
void display(uchar num);
void Marix_keyscan();
void delay(uint xms);
 dula = 1;
 P0 = 0x00;
 dula = 0;
 wela = 1;
 P0 = 0xea;
 wela = 0;
  Marix_keyscan();
  display(key);
 dula = 1;
 P0 = table[num];
 dula = 0;
 uint i, j;
 for(i = xms; i > 0; i--)
   for(j = 125; j > 0; j--);
 P3 = 0xfe;
 temp = P3;
 temp &= 0xf0;
 if(temp != 0xf0)
  delay(5);
  temp = P3;
  temp &= 0xf0;
  if(temp != 0xf0)
   FM = 0;
   temp = P3;
   switch(temp)
    case 0xee: key = 0;
    break;
    case 0xde: key = 1;
    break;
    case 0xbe: key = 2;
    break;
    case 0x7e: key = 3;
    break;
    default:
    break;
   while(temp != 0xf0)
    temp = P3;
    temp &= 0xf0;
   delay(5);
   while(temp != 0xf0)
    temp = P3;
    temp &= 0xf0;
   FM = 1;
 P3 = 0xfd;
 temp = P3;
 temp &= 0xf0;
 if(temp != 0xf0)
  delay(5);
  temp = P3;
  temp &= 0xf0;
  if(temp != 0xf0)
   FM = 0;
   temp = P3;
   switch(temp)
    case 0xed:key = 4;
    break;
    case 0xdd:key = 5;
    break;
    case 0xbd:key = 6;
    break;
    case 0x7d:key = 7;
    break;
    default:
    break;
   while(temp != 0xf0)
    temp = P3;
    temp &= 0xf0;
   delay(5);
   while(temp != 0xf0)
    temp = P3;
    temp &= 0xf0;
   FM = 1;
 P3 = 0xfb;
 temp = P3;
 temp &= 0xf0;
 if(temp != 0xf0)
  delay(5);
  temp = P3;
  temp &= 0xf0;
  if(temp != 0xf0)
   FM = 0;
   temp = P3;
   switch(temp)
     case 0xeb: key = 8;
    break;
    case 0xdb: key = 9;
    break;
    case 0xbb: key = 10;
    break;
    case 0x7b: key = 11;
    break;
    default:
    break;
   while(temp != 0xf0)
    temp = P3;
    temp &= 0xf0;
   delay(5);
   while(temp != 0xf0)
    temp = P3;
    temp &= 0xf0;
   FM = 1;
 P3 = 0xf7;
 temp = P3;
 temp &= 0xf0;
 if(temp != 0xf0)
  delay(5);
  temp = P3;
  temp &= 0xf0;
  if(temp != 0xf0)
   FM = 0;
   temp = P3;
   switch(temp)
    case 0xe7: key = 12;
    break;
       case 0xd7: key = 13;
    break;
    case 0xb7: key = 14;
    break;
    case 0x77: key = 15;
    break;
    default:
    break;
   while(temp != 0xf0)
    temp = P3;
    temp &= 0xf0;
   delay(5);
      while(temp != 0xf0)
    temp = P3;
    temp &= 0xf0;
   FM = 1;
