用430的32768Hz晶振寫的時鐘,加了按鍵的喲
作者:我行天下   來源:本站原創(chuàng)   點擊數(shù):  更新時間:2014年03月30日   【字體:
#include <MSP430x14x.h>
typedef unsigned char uchar;
typedef unsigned int  uint;
//typedef也是一種宏定義類型,其書寫方式和#define相反
/*******液晶端口初始化*******/
#define out P3DIR|=BIT0+BIT1+BIT2//把P3_012三個口設(shè)為輸出
#define lcd_enset P3OUT|=BIT2
#define lcd_enclear P3OUT&=~BIT2
#define lcd_rw1 P3OUT|=BIT1
#define lcd_rw0 P3OUT&=~BIT1
#define lcd_rs1 P3OUT|=BIT0
#define lcd_rs0 P3OUT&=~BIT0
#define keyin (P1IN & 0x0f)
 uchar temp,keynum=0;
int shi=23,fen=59,miao=55;//此處用char型會在按鍵調(diào)整減數(shù)到0時出錯
/*延時子程序*/
//調(diào)用8個時鐘周期,返回6個,循環(huán)4個
//總周期個數(shù)為: 8+6+4*n=14+4*n 個時鐘周期
//默認800k時鐘,所以周期為1.25us 公式修正:17.5+5*n=定時時間
void delay(unsigned int x)//延時
 unsigned int i;
 i=x;
 for(;i>0;i--) ;
/******LCD寫指令程序***********/
void write_com(unsigned char com)
{ out;
  P4DIR=0XFF;
  P4OUT=com;
  lcd_rw0;
  lcd_rs0;
  _NOP();
  lcd_enclear;
  delay(10);
  lcd_enset;
  delay(10);
  lcd_enclear;
/***********LCD寫數(shù)據(jù)**************/
void write_data(unsigned char dat)
{   out;
   P4DIR=0XFF;
   P4OUT=dat;
   lcd_rw0;
   lcd_rs1;
   _NOP();
   _NOP();
   lcd_enclear;
   delay(10);
   lcd_enset;
   delay(10);
   lcd_enclear;
/*****寫時分秒********/
void write_sfm(uchar add,uchar dat)
  uchar a,b;
  a=dat/10;
  b=dat%10;
  write_com(0x80+0x40+add);
  write_data(a+0x30);
  write_data(b+0x30);
/*********lcd初始化,寫lcd功能與方式控制********/
void lcd_init()
{  out;
   write_com(0x38);
   delay(20);
   write_com(0x0f);
   delay(20);
   write_com(0x06);
   delay(20);
   write_com(0x0c);
   delay(20);
   write_com(0x01);
   delay(20);
void Clock(void)
miao++;
  if(miao==60)
          miao=0;
          fen++;
            if(fen==60)
               fen=0;
               shi++;
                if(shi==24)
                    shi=0;
                 write_sfm(2,shi);
         write_sfm(5,fen);
write_sfm(8,miao);
void keyscan()
 if(keyin!=0x0f)
           delay(5);            //延時消抖
            if(keyin != 0x0f)   //再次檢測按鍵狀態(tài)
             temp=keyin;
             while(keyin != 0x0f);  //等待按鍵被放開
               if(temp==0x0e)
                 keynum++;
                  switch(keynum)
                    case 1:
                         _DINT();
                       // CCTL0 &=~ CCIE; //兩種停止時鐘的方法效果一樣
                        write_com(0x80+0x40+9);
                        write_com(0x0f);//光標(biāo)開始閃
                        break;
                    case 2:
                          write_com(0x80+0x40+6);break;
                    case 3:
                          write_com(0x80+0x40+3);break;
                    case 4:
                         keynum=0;
                         write_com(0x0c);//開顯示,光標(biāo)不顯示
                       _EINT();
                        //  CCTL0|=CCIE; //使用相應(yīng)打開時鐘的方法
                      break;
              if(temp==0x0d)
                 // while(keyin != 0x0d);  //等待按鍵被放開
                switch(keynum)
                   case 1:
                     miao++;
                     if(miao==60)miao=0;
                     write_sfm(8,miao);
                     break;
                    case 2:
                     fen++;
                     if(fen==60)fen=0;
                     write_sfm(5,fen);
                     break;
                    case 3:
                     shi++;
                     if(shi==24)shi=0;
                     write_sfm(2,shi);
                     break;
            if(temp==0x0b)
                switch(keynum)
                   case 1:
                     miao--;
                     if(miao==-1)miao=59;
                     write_sfm(8,miao);
                     break;
                    case 2:
                     fen--;
                     if(fen==-1)fen=59;
                     write_sfm(5,fen);
                     break;
                    case 3:
                     shi--;
                     if(shi==-1)shi=23;
                     write_sfm(2,shi);
                     break;
int main( void )
{ P6DIR|=BIT3;
  P6OUT|=BIT3;
  //上兩句是打開1602的背光電源
  WDTCTL = WDTPW + WDTHOLD;
       lcd_init();
       delay(500);
    write_com(0x80+0x40+4);
    write_data(':');
    write_com(0x80+0x40+7);
    write_data(':');
    write_sfm(2,shi);
    write_sfm(5,fen);
    write_sfm(8,miao);
     CCR0 = 32768 - 1;//設(shè)置定時器A的中斷時間為1S
    TACTL = TASSEL_1 + MC_1; //計數(shù)時鐘ACLK, 增計數(shù)模式
    CCTL0 |= CCIE; //使能CCR0比較中斷
    _EINT();//打開全局中斷
     P1DIR = 0xf0;  //設(shè)置P1.0~P.3為輸入狀態(tài)
   // P1DIR = BIT7;  //設(shè)置P1.0~P.3為輸入狀態(tài),P1.7為輸出
   // P1OUT = 0;
  //以上兩句是在沒有獨立按鍵情況下把P1_7拉低成為地線
        keyscan();
      //本程序如果加低功耗模式會使按鍵功能失效
函數(shù)名稱:TimerA_ISR
功    能:定時器A的中斷服務(wù)函數(shù)
#pragma vector=TIMERA0_VECTOR
__interrupt void TimerA_ISR(void)
    Clock();
//到此時鐘加按鍵完成
