工 程:ST7920驅(qū)動(dòng)的12864液晶的3線串行驅(qū)動(dòng)模式
創(chuàng)建日期:2007年9月16日
創(chuàng) 建 人:朱海峰
郵 箱:ntzhf100@163.com QQ:543376422
引腳定義:RS(CS)=====>PB5
RW(SID)====>PB6
EN(SCLK)===>PB7
PSB為硬件控制,接高電平為8位或4位的并行模式,接低電平為串行模式
本例程使用3線串行模式
#include <iom128v.h>
#include <macros.h>
#define nop() NOP()
#define xtal 8
#define CS PB5
#define SID PB6
#define SCLK PB7
#define Set_CS() DDRB |= (1<<CS);PORTB |= (1<<CS)
#define Set_SID() DDRB |= (1<<SID);PORTB |= (1<<SID)
#define Set_SCLK() DDRB |= (1<<SCLK);PORTB |= (1<<SCLK)
#define Clr_CS() DDRB |= (1<<CS);PORTB &=~(1<<CS)
#define Clr_SID() DDRB |= (1<<SID);PORTB &=~(1<<SID)
#define Clr_SCLK() DDRB |= (1<<SCLK);PORTB &=~(1<<SCLK)
//函數(shù)聲明
void Delay(uint ms); //延時(shí)子程序
void W_1byte(uchar RW, uchar RS, uchar W_data);
void Write_8bits(uint W_bits);
void LCD_Init(void);
void Char_Set_XY(uchar x, uchar y, uchar *p);
void Set_Draw(void);
//設(shè)定哪一行,從那一個(gè)位置開始到那一個(gè)位置結(jié)束使用反白
//x=液晶屏上漢字的位置(1~8);end_x=漢字結(jié)束的地址(1~8);y=1~4行
//clear=1:清除反白;clear=0:設(shè)置反白;
void Set_White(uchar x,uchar y,uchar end_x,uchar clear);
void Draw_Pic(uchar x, uchar y, const uchar *Draw);
const uchar PIC1[64][16]={
/*-- 調(diào)入了一幅圖像:C:\Documents and Settings\Administrator\桌面\atmel.bmp --*/
/*-- 寬度x高度=128x64 --*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0x00,0x00,
0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0x00,0x00,
0x00,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0x00,0x00,
0x00,0x00,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0x00,0x00,
0x00,0x00,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0x00,0x00,
0x00,0x00,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0x00,0x00,
0x00,0x00,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x00,0x00,
0x00,0x00,0x00,0x07,0xFC,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x3F,0xE7,0xFC,0xFF,0xFF,0xFF,0xE0,0xFF,0xFF,0xCF,0xF8,0x00,0x00,0x00,
0x00,0x00,0x3F,0xE7,0xFC,0xFF,0xFF,0xFF,0xF0,0xFF,0xFF,0xCF,0xF8,0x00,0x00,0x00,
0x00,0x00,0x7F,0xE7,0xFC,0xFF,0xFF,0xFF,0xF8,0xFF,0xFF,0xCF,0xF8,0x00,0x00,0x00,
0x00,0x00,0x7F,0xE7,0xFC,0xFF,0xFF,0xFF,0xFC,0xFF,0xFF,0xCF,0xF8,0x00,0x00,0x00,
0x00,0x00,0xFF,0xE7,0xFC,0xFF,0xBF,0xEF,0xFC,0xFF,0xFF,0xCF,0xF8,0x00,0x00,0x00,
0x00,0x00,0xFF,0xE7,0xFC,0xFF,0xBF,0xE7,0xFC,0xFF,0xFF,0xCF,0xF8,0x00,0x00,0x00,
0x00,0x01,0xFF,0xE7,0xFC,0xFF,0xBF,0xE7,0xFC,0xFF,0xFF,0xCF,0xF8,0x00,0x00,0x00,
0x00,0x03,0xFF,0xE7,0xFC,0xFF,0xBF,0xE7,0xFC,0xFF,0xFF,0xCF,0xF8,0x00,0x00,0x00,
0x00,0x07,0xFF,0xE7,0xFC,0xFF,0xBF,0xE7,0xFC,0xFC,0x00,0x0F,0xF8,0x00,0x00,0x00,
0x00,0x07,0xFF,0xE7,0xFC,0xFF,0xBF,0xE7,0xFC,0xFF,0xFF,0xCF,0xF8,0x00,0x00,0x00,
0x00,0x0F,0xFF,0xE7,0xFC,0xFF,0xBF,0xE7,0xFC,0xFF,0xFF,0xCF,0xF8,0x00,0x00,0x00,
0x00,0x1F,0xFF,0xE7,0xFC,0xFF,0xBF,0xE7,0xFC,0xFF,0xFF,0xCF,0xF8,0x00,0x00,0x00,
0x00,0x3F,0xFF,0xE7,0xFC,0xFF,0xBF,0xE7,0xFC,0xFF,0xFF,0xCF,0xF8,0x00,0x00,0x00,
0x00,0x7F,0xFF,0xE7,0xFC,0xFF,0xBF,0xE7,0xFC,0xFF,0xFF,0xCF,0xF8,0x00,0x00,0x00,
0x00,0xFF,0xFF,0xE7,0xFC,0xFF,0xBF,0xE7,0xFC,0xFF,0xFF,0xCF,0xF8,0x00,0x00,0x00,
0x00,0xFF,0xFF,0xE7,0xFC,0xFF,0xBF,0xE7,0xFC,0xFC,0x00,0x0F,0xF8,0x00,0x00,0x00,
0x01,0xFF,0xBF,0xE7,0xFC,0xFF,0xBF,0xE7,0xFC,0xFE,0x00,0x0F,0xF8,0x00,0x00,0x00,
0x01,0xFF,0x3F,0xE7,0xFC,0xFF,0xBF,0xE7,0xFC,0xFF,0xFF,0xCF,0xFF,0xF8,0x00,0x00,
0x03,0xFF,0x3F,0xE7,0xFC,0xFF,0xBF,0xE7,0xFC,0xFF,0xFF,0xCF,0xFF,0xF8,0x00,0x00,
0x03,0xFE,0x3F,0xE7,0xFC,0xFF,0xBF,0xE7,0xFC,0xFF,0xFF,0xCF,0xFF,0xF0,0x00,0x00,
0x07,0xFE,0x3F,0xE7,0xFC,0xFF,0xBF,0xE7,0xFC,0xFF,0xFF,0xCF,0xFF,0xF0,0x00,0x00,
0x07,0xFF,0x3F,0xE7,0xFC,0xFF,0xBF,0xE7,0xFC,0xFF,0xFF,0xCF,0xFF,0xE0,0x00,0x00,
0x0F,0xFF,0x3F,0xE7,0xFC,0xFF,0xBF,0xE7,0xFC,0xFF,0xFF,0xCF,0xFF,0xE0,0x00,0x00,
0x0F,0xFF,0x3F,0xE7,0xFC,0xFF,0xBF,0xE7,0xFC,0xFF,0xFF,0xCF,0xFF,0xC0,0x00,0x00,
0x1F,0xFF,0x3F,0xE7,0xFC,0xFF,0xBF,0xE7,0xFC,0xFF,0xFF,0xCF,0xFF,0xC0,0x00,0x00,
0x1F,0xFF,0x3F,0xE7,0xFC,0xFF,0x1F,0xE7,0xFC,0xFF,0xFF,0xCF,0xFF,0x80,0x00,0x00,
0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x3E,0x00,0x00,
0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x63,0x00,0x00,
0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0xFD,0x00,0x00,
0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0xB6,0x80,0x00,
0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0xBE,0x80,0x00,
0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0xB6,0x80,0x00,
0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0xF7,0x00,0x00,
0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0x63,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3C,0x00,0x00,
const uchar PIC2[64][16]={
/*-- 調(diào)入了一幅圖像:C:\Documents and Settings\Administrator\桌面\AVR.BMP --*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3C,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x43,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xBD,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x27,
0x00,0x00,0x1F,0xFF,0x83,0xFF,0xE0,0x00,0x00,0xFF,0xF8,0x3F,0xFF,0xFF,0x01,0x3C,
0x00,0x00,0x3F,0xFF,0x81,0xFF,0xF0,0x00,0x01,0xFF,0xF0,0x7F,0xFF,0xFF,0xC1,0x3E,
0x00,0x00,0x3F,0xFF,0xC1,0xFF,0xF0,0x00,0x01,0xFF,0xF0,0x7F,0xFF,0xFF,0xE0,0xA7,
0x00,0x00,0x3F,0xFF,0xC1,0xFF,0xF0,0x00,0x03,0xFF,0xE0,0x7F,0xFF,0xFF,0xF0,0xE7,
0x00,0x00,0x7F,0xFF,0xE0,0xFF,0xF8,0x00,0x03,0xFF,0xE0,0xFF,0xFF,0xFF,0xF8,0x7E,
0x00,0x00,0x7F,0xFF,0xE0,0xFF,0xF8,0x00,0x03,0xFF,0xE0,0xFF,0xFF,0xFF,0xF8,0x00,
0x00,0x00,0x7F,0xFF,0xE0,0x7F,0xFC,0x00,0x07,0xFF,0xC1,0xFF,0xFF,0xFF,0xFC,0x00,
0x00,0x00,0xFF,0xFF,0xF0,0x7F,0xFC,0x00,0x07,0xFF,0xC1,0xFF,0xFF,0xFF,0xFC,0x00,
0x00,0x00,0xFF,0xFF,0xF0,0x7F,0xFE,0x00,0x0F,0xFF,0x83,0xFF,0xFF,0xFF,0xFE,0x00,
0x00,0x01,0xFF,0xFF,0xF8,0x3F,0xFE,0x00,0x0F,0xFF,0x83,0xFF,0xE0,0x7F,0xFE,0x00,
0x00,0x01,0xFF,0xFF,0xF8,0x3F,0xFE,0x00,0x1F,0xFF,0x07,0xFF,0xC0,0x3F,0xFE,0x00,
0x00,0x03,0xFF,0xFF,0xF8,0x3F,0xFF,0x00,0x1F,0xFF,0x07,0xFF,0xC0,0x3F,0xFE,0x00,
0x00,0x03,0xFF,0xFF,0xFC,0x1F,0xFF,0x00,0x1F,0xFE,0x07,0xFF,0xC0,0x3F,0xFE,0x00,
0x00,0x03,0xFF,0xFF,0xFC,0x1F,0xFF,0x80,0x3F,0xFE,0x0F,0xFF,0x80,0x3F,0xFE,0x00,
0x00,0x07,0xFF,0xFF,0xFE,0x0F,0xFF,0x80,0x3F,0xFE,0x0F,0xFF,0x80,0x3F,0xFE,0x00,
0x00,0x07,0xFF,0x9F,0xFE,0x0F,0xFF,0x80,0x7F,0xFC,0x1F,0xFF,0x00,0x7F,0xFE,0x00,
0x00,0x07,0xFF,0x9F,0xFF,0x07,0xFF,0xC0,0x7F,0xFC,0x1F,0xFF,0x00,0xFF,0xFC,0x00,
0x00,0x0F,0xFF,0x8F,0xFF,0x07,0xFF,0xC0,0x7F,0xF8,0x1F,0xFF,0x01,0xFF,0xFC,0x00,
0x00,0x0F,0xFF,0x0F,0xFF,0x03,0xFF,0xC0,0xFF,0xF8,0x3F,0xFF,0xFF,0xFF,0xF8,0x00,
0x00,0x0F,0xFF,0x0F,0xFF,0x83,0xFF,0xE0,0xFF,0xF8,0x3F,0xFF,0xFF,0xFF,0xF8,0x00,
0x00,0x1F,0xFF,0x07,0xFF,0x83,0xFF,0xE1,0xFF,0xF0,0x7F,0xFF,0xFF,0xFF,0xF0,0x00,
0x00,0x1F,0xFE,0x07,0xFF,0xC1,0xFF,0xF1,0xFF,0xF0,0x7F,0xFF,0xFF,0xFF,0xE0,0x00,
0x00,0x3F,0xFE,0x07,0xFF,0xC1,0xFF,0xF3,0xFF,0xE0,0x7F,0xFF,0xFF,0xFF,0xC0,0x00,
0x00,0x3F,0xFE,0x03,0xFF,0xC0,0xFF,0xFB,0xFF,0xE0,0xFF,0xFF,0xFF,0xFF,0x80,0x00,
0x00,0x7F,0xFC,0x03,0xFF,0xE0,0xFF,0xFB,0xFF,0xC0,0xFF,0xFF,0xFF,0xFF,0x00,0x00,
0x00,0x7F,0xFC,0x03,0xFF,0xE0,0x7F,0xFF,0xFF,0xC1,0xFF,0xFF,0xFF,0xFC,0x00,0x00,
0x00,0x7F,0xF8,0x01,0xFF,0xF0,0x7F,0xFF,0xFF,0x81,0xFF,0xFF,0xFF,0xE0,0x00,0x00,
0x00,0xFF,0xFF,0xFF,0xFF,0xF8,0x3F,0xFF,0xFF,0x83,0xFF,0xFF,0xFF,0xC0,0x00,0x00,
0x00,0xFF,0xFF,0xFF,0xFF,0xF8,0x3F,0xFF,0xFF,0x83,0xFF,0xF3,0xFF,0xC0,0x00,0x00,
0x00,0xFF,0xFF,0xFF,0xFF,0xF8,0x3F,0xFF,0xFF,0x03,0xFF,0xE3,0xFF,0xE0,0x00,0x00,
0x01,0xFF,0xFF,0xFF,0xFF,0xFC,0x1F,0xFF,0xFF,0x07,0xFF,0xE3,0xFF,0xE0,0x00,0x00,
0x01,0xFF,0xFF,0xFF,0xFF,0xFC,0x1F,0xFF,0xFE,0x07,0xFF,0xC3,0xFF,0xE0,0x00,0x00,
0x03,0xFF,0xFF,0xFF,0xFF,0xFE,0x1F,0xFF,0xFE,0x0F,0xFF,0xC1,0xFF,0xF0,0x00,0x00,
0x03,0xFF,0xFF,0xFF,0xFF,0xFE,0x0F,0xFF,0xFE,0x0F,0xFF,0x81,0xFF,0xF0,0x00,0x00,
0x03,0xFF,0xFF,0xFF,0xFF,0xFE,0x0F,0xFF,0xFC,0x0F,0xFF,0x81,0xFF,0xF8,0x00,0x00,
0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0x07,0xFF,0xFC,0x1F,0xFF,0x81,0xFF,0xF8,0x00,0x00,
0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0x07,0xFF,0xF8,0x3F,0xFF,0x00,0xFF,0xF8,0x00,0x00,
0x0F,0xFF,0xC0,0x00,0x1F,0xFF,0x83,0xFF,0xF8,0x3F,0xFF,0x00,0xFF,0xF8,0x00,0x00,
0x0F,0xFF,0x80,0x00,0x0F,0xFF,0x83,0xFF,0xF0,0x3F,0xFE,0x00,0xFF,0xFC,0x00,0x00,
0x0F,0xFF,0x80,0x00,0x0F,0xFF,0xC3,0xFF,0xF0,0x7F,0xFE,0x00,0x7F,0xFC,0x00,0x00,
0x1F,0xFF,0x00,0x00,0x0F,0xFF,0xC1,0xFF,0xF0,0x7F,0xFC,0x00,0x7F,0xFC,0x00,0x00,
0x1F,0xFF,0x00,0x00,0x07,0xFF,0xC1,0xFF,0xE0,0x7F,0xFC,0x00,0x7F,0xFE,0x00,0x00,
0x1F,0xFF,0x00,0x00,0x07,0xFF,0xE0,0xFF,0xE0,0xFF,0xF8,0x00,0x7F,0xFE,0x00,0x00,
0x3F,0xFE,0x00,0x00,0x03,0xFF,0xE0,0xFF,0xC0,0xFF,0xF8,0x00,0x3F,0xFE,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
uchar i = 0;
PORTB = 0XFF; //
DDRB = 0XFF; //PB口全部設(shè)為輸出模式
Clr_CS();
Clr_SID();
Clr_SCLK();
LCD_Init();
Delay(50);
LCD_Init(); //初始化兩邊是關(guān)鍵,否則液晶上電重起將不能顯示
nop();
nop();
Delay(500);
Char_Set_XY(0,0,"ST7920_3_wires");
Char_Set_XY(2,1,"反白練習(xí)");
Char_Set_XY(0,2,"可以單字反白或不");
Char_Set_XY(3,3,"反白");
Delay(2000);
Delay(2000);
Set_Draw();
Delay(100);
Set_White(1,1,7,0); //第1行,第1個(gè)漢字位置到第8漢字位置反白
Set_White(3,2,6,0); //第2行,第3個(gè)漢字位置到第6漢字位置反白
Set_White(1,3,8,0); //第3行,第1個(gè)漢字位置到第8漢字位置反白
Set_White(4,4,5,0); //第4行,第4個(gè)漢字位置到第5漢字位置反白
Delay(2000);
Delay(2000);
Set_White(4,1,4,1); //第1行,第4個(gè)漢字位置等取消反白
Set_White(5,2,5,1); //第2行,第5個(gè)漢字位置等取消反白
Set_White(6,3,6,1); //第3行,第6個(gè)漢字位置等取消反白
Set_White(4,4,4,1); //第4行,第4個(gè)漢字位置等取消反白
Delay(2000);
Delay(2000);
Set_White(1,1,1,1); //
Set_White(3,2,3,1); //
Set_White(2,3,2,1); //
Set_White(5,4,5,1); //
Delay(2000);
Delay(2000);
Set_White(1,1,8,1); //第1行,第1個(gè)漢字位置到第8漢字位置取消反白
Set_White(1,2,8,1); //第2行,第1個(gè)漢字位置到第8漢字位置取消反白
Set_White(1,3,8,1); //第3行,第1個(gè)漢字位置到第8漢字位置取消反白
Set_White(1,4,8,1); //第4行,第1個(gè)漢字位置到第8漢字位置取消反白
Delay(2000);
Delay(2000);
W_1byte(0,0,0x30); //基本指令集,,繪圖顯示OFF
W_1byte(0,0,0x01); //清除顯示
Set_Draw();
Delay(100);
Draw_Pic(0,0,*PIC1); //先替換液晶內(nèi)部RAM中的數(shù)據(jù),再開顯示
W_1byte(0,0,0x36); //8BIT控制界面,擴(kuò)充指令集,,繪圖顯示ON
Delay(5000);
W_1byte(0,0,0x34); //繪圖顯示OFF,主要解決畫圖時(shí)拖尾的現(xiàn)象,即先
//替換好液晶內(nèi)部RAM中的數(shù)據(jù)在開顯示。
Draw_Pic(0,0,*PIC2);
W_1byte(0,0,0x36); //8BIT控制界面,擴(kuò)充指令集,繪圖顯示ON
Delay(5000);
//畫完圖后要顯示文字要重新設(shè)置成普通模式
void LCD_Init(void)
uchar cmd;
cmd=0x30; //功能設(shè)置 8位數(shù)據(jù),基本指令
W_1byte(0,0,cmd);
Delay(2);
cmd=0x0C; //顯示狀態(tài) ON,游標(biāo)OFF,反白OFF
W_1byte(0,0,cmd); //寫指令
Delay(2);
cmd=0x01; //清除顯示
Delay(2);
cmd=0x02; //地址歸位
Delay(2);
cmd=0x80; //設(shè)置DDRAM地址
Delay(2); //延時(shí)
函 數(shù) 名:W_1byte
入口參數(shù):RW、RS、W_data
出口參數(shù):無
建立日期:2007年3月3日
修改日期:
函數(shù)作用:寫一個(gè)字節(jié)的數(shù)據(jù)到12864液晶,包括指令和數(shù)據(jù)
說 明:RW=1,從液晶讀數(shù)據(jù)到MCU;RW=0,寫一個(gè)數(shù)據(jù)到液晶;
(一般RW都設(shè)為0,即只向液晶寫數(shù)據(jù),不讀數(shù)據(jù))
RS=1,寫入的是數(shù)據(jù);RS=0,寫入的是指令;
一般模式:RW=0,RS=1;寫數(shù)據(jù)
RW=0,RS=0;寫指令
uint H_data,L_data,S_ID = 0xf8; //11111RWRS0
if(RW == 0)
S_ID &=~ 0x04;
else //if(RW==1)
S_ID |= 0X04;
if(RS == 0)
S_ID &=~ 0x02;
else //if(RS==1)
S_ID |= 0X02;
H_data = W_data;
H_data &= 0xf0; //屏蔽低4位的數(shù)據(jù)
L_data = W_data; //xxxx0000格式
L_data &= 0x0f; //屏蔽高4位的數(shù)據(jù)
L_data <<= 4; //xxxx0000格式
Set_CS();
Write_8bits(S_ID); //發(fā)送S_ID
Write_8bits(H_data); //發(fā)送H_data
Write_8bits(L_data); //發(fā)送L_data
Clr_CS();
函 數(shù) 名:Write_8bits
入口參數(shù):W_bits
出口參數(shù):無
建立日期:2007年3月3日
修改日期:
函數(shù)作用:負(fù)責(zé)串行輸出8個(gè)bit位
說 明:
uint i,Temp_data;
for(i=0; i<8; i++)
Temp_data = W_bits;
Temp_data <<= i;
if((Temp_data&0x80)==0)
Clr_SID();
Set_SID();
nop();
Set_SCLK();
nop();
nop();
Clr_SCLK();
nop();
Clr_SID();
函 數(shù) 名:Delay
入口參數(shù):ms
出口參數(shù):無
建立日期:2007年3月3日
修改日期:
函數(shù)作用:毫秒級(jí)的延時(shí)程序,當(dāng)晶振為12Mhz時(shí),xtal=12;
說 明:
void Delay(uint ms)
uint i;
while(ms--)
for(i=1;i<(uint)(xtal*143-2);i++)
函 數(shù) 名:Char_Set_XY
入口參數(shù):x,y,*p
出口參數(shù):無
建立日期:2007年8月26日
修改日期:
函數(shù)作用:
說 明:
if(y == 0)
W_1byte(0,0,(0x80+x));
if(y == 1)
W_1byte(0,0,(0x90+x));
if(y == 2)
W_1byte(0,0,(0x88+x));
if(y == 3)
W_1byte(0,0,(0x98+x));
while(*p != 0)
W_1byte(0,1,*p++);
函 數(shù) 名:Set_Draw(
入口參數(shù):無
出口參數(shù):無
建立日期:2007年8月26日
修改日期:
函數(shù)作用:
說 明:
void Set_Draw(void)
//W_1byte(0,0,0x01); //清屏
Delay(20); //延時(shí)
//W_1byte(0,0,0x34); //8BIT控制界面,擴(kuò)充指令集,,繪圖顯示OFF
W_1byte(0,0,0x36);
函 數(shù) 名:Draw_Pic 128*64
入口參數(shù):x,y,*Draw
出口參數(shù):無
建立日期:2007年8月26日
修改日期:
函數(shù)作用:
說 明:
uchar i, j, temp_x, temp_y; //
temp_x = x; //
temp_y = y; //
temp_x |= 0x80; //
temp_y |= 0x80; //
for(i=0;i<32;i++ ) //上半屏32行
W_1byte(0,0,temp_y++); //設(shè)置繪圖區(qū)的Y地址坐標(biāo)0
W_1byte(0,0,temp_x); //設(shè)置繪圖區(qū)的X地址坐標(biāo)0
for(j=0;j<16;j++) //
W_1byte(0,1,*Draw++); //
temp_x = 0x88; //
temp_y = 0x80; //
j = 0; //
for(;i<64;i++ )
for(j=0;j<16;j++)
uchar i, j, white_x, white_y,white_end_x,clr_x,clr_y; //
white_end_x = (end_x-x+1);
white_end_x <<= 1;
if(y==1)
white_x = (0x80+x-1);
white_y = 0x80;
clr_x = 0x80;
clr_y = 0x80;
else if(y==2)
white_y = 0x90;
clr_x = 0x80;
clr_y = 0x90;
else if(y==3)
white_x = (0x88+x-1);
white_y = 0x80;
clr_x = 0x88;
clr_y = 0x80;
else if(y==4)
white_y = 0x90;
clr_x = 0x88;
clr_y = 0x90;
if(clear==0)//要反白時(shí),先將整行的液晶全部清成不反白(此處行指y)
for(i=0;i<16;i++ ) //16行
W_1byte(0,0,clr_y++); //設(shè)置繪圖區(qū)的Y地址坐標(biāo)0
W_1byte(0,0,clr_x); //設(shè)置繪圖區(qū)的X地址坐標(biāo)0
W_1byte(0,1,0x00); //清成不反白
nop();
nop();
for(i=0;i<16;i++ ) //16行,因?yàn)槭?6*16漢字
W_1byte(0,0,white_y++); //設(shè)置繪圖區(qū)的Y地址坐標(biāo)0
W_1byte(0,0,white_x); //設(shè)置繪圖區(qū)的X地址坐標(biāo)0
for(j=0;j<white_end_x;j++) //
if(clear==1)
W_1byte(0,1,0x00); //取消這一行的8個(gè)點(diǎn)的反白,液晶地址自動(dòng)加1
//(此處行指一個(gè)一個(gè)液晶點(diǎn)所組成的行)
W_1byte(0,1,0xff); //反白這一行的8個(gè)點(diǎn),液晶地址自動(dòng)加1
nop();
