這是從網(wǎng)上找來的一個比較典型的PID處理程序,在使用單片機作為控制cpu時,請稍作簡化,具體的PID
參數(shù)必須由具體對象通過實驗確定。由于單片機的處理速度和ram資源的限制,一般不采用浮點數(shù)運算,
而將所有參數(shù)全部用整數(shù),運算到最后再除以一個2的N次方數(shù)據(jù)(相當于移位),作類似定點數(shù)運算,可
大大提高運算速度,根據(jù)控制精度的不同要求,當精度要求很高時,注意保留移位引起的“余數(shù)”,做好余
數(shù)補償。這個程序只是一般常用pid算法的基本架構(gòu),沒有包含輸入輸出處理部分。
#include <string.h>
#include <stdio.h>
PID Function
The PID (比例、積分、微分) function is used in mainly
control applications. PIDCalc performs one iteration of the PID
algorithm.
While the PID function works, main is just a dummy program showing
a typical usage.
typedef struct PID {
double SetPoint; // 設(shè)定目標 Desired Value
double Proportion; // 比例常數(shù) Proportional Const
double Integral; // 積分常數(shù) Integral Const
double Derivative; // 微分常數(shù) Derivative Const
double LastError; // Error[-1]
double PrevError; // Error[-2]
double SumError; // Sums of Errors
} PID;
PID計算部分
double PIDCalc( PID *pp, double NextPoint )
double dError,
Error;
Error = pp->SetPoint - NextPoint; // 偏差
pp->SumError += Error; // 積分
dError = pp->LastError - pp->PrevError; // 當前微分
pp->PrevError = pp->LastError;
pp->LastError = Error;
return (pp->Proportion * Error // 比例項
+ pp->Integral * pp->SumError // 積分項
+ pp->Derivative * dError // 微分項
Initialize PID Structure
void PIDInit (PID *pp)
memset ( pp,0,sizeof(PID));
Main Program
double sensor (void) // Dummy Sensor Function
return 100.0;
void actuator(double rDelta) // Dummy Actuator Function
void main(void)
PID sPID; // PID Control Structure
double rOut; // PID Response (Output)
double rIn; // PID Feedback (Input)
PIDInit ( &sPID ); // Initialize Structure
sPID.Proportion = 0.5; // Set PID Coefficients
sPID.Integral = 0.5;
sPID.Derivative = 0.0;
sPID.SetPoint = 100.0; // Set PID Setpoint
for (;;) { // Mock Up of PID Processing
rIn = sensor (); // Read Input
rOut = PIDCalc ( &sPID,rIn ); // Perform PID Interation
actuator ( rOut ); // Effect Needed Changes
