基于VHDL語言含異步清零同步計(jì)數(shù)使能12進(jìn)制加減可控制器
作者:huqin   來源:本站原創(chuàng)   點(diǎn)擊數(shù):  更新時間:2014年04月04日   【字體:
library ieee;
use ieee.std_logic_1164.all;
entity counter12_updown is
port(clr,ena,clk,updown,load: in std_logic;
     d: buffer integer range 0 to 11;
     q: buffer integer range 0 to 11;
     count:out std_logic);
end entity counter12_updown;
architecture rtl of counter12_updown is
begin
process(clk,clr)
begin
if clr='1' then q<=0;
    if clk='1' and clk'event then
    if load='1' then q<=d;
    elsif ena='1'then
    if updown='1' then
      if q=11 then q<=0;
        q<=q+1;
       end if;
         if q=0 then q<=11;
           q<=q-1;
       end if;
       end if;
       end if;
       end if;
end if;
if updown='1' then
 if q=9 then count<='1';
else count<='0';
end if;
if q=0 then
count<='1';
else count<='0';
end if;
end if;
end process;
end architecture rtl;
