最近做的項(xiàng)目中涉及了IIC總線的運(yùn)用
IIC總線的運(yùn)用范圍十分廣泛
寫下博客記錄
IIC總線延時(shí) 大于4.7us
#define Decoded_iic_delay() \
Decoded_iic_DELAY_TMP=Decoded_iic_DELAY_VALUE;\
while(--Decoded_iic_DELAY_TMP);\
初始化
void Decoded_iic_init()
Decoded_iic_SCL=1;
Decoded_iic_delay();
Decoded_iic_SDA=1;
開始信號(hào)
void Decoded_iic_start()
Decoded_iic_SDA=1;
//Myputchar(Decoded_iic_SDA);
Decoded_iic_SCL=1;
//Myputchar(Decoded_iic_SCL);
Decoded_iic_SDA=0;
Decoded_iic_SCL=0;
寫時(shí)序
void Decoded_iic_write(uchar dat)
uchar idata t=8;
while(t--)
Decoded_iic_SDA=(bit)(dat&0x80);
dat<<=1;
Decoded_iic_SCL=1;
Decoded_iic_SCL=0;
讀時(shí)序
uchar Decoded_iic_read()
uchar dat=0;
uchar t=8;
//Myputchar(dat);
Decoded_iic_SDA=1;讀之前SDA拉高
while(t--)
Decoded_iic_SCL=1;
dat <<= 1;一定要先移位后讀 如果先讀后移位會(huì)擠掉最高位
if(Decoded_iic_SDA)
dat |= 0x01;
Decoded_iic_SCL=0;
return dat;
獲取ACK
bit Decoded_iic_getack()
bit ack;
Decoded_iic_SDA=1;SDA為高釋放總線
Decoded_iic_SCL=1;
ack=Decoded_iic_SDA;
Decoded_iic_SCL=0;
return ack;
發(fā)送ACK
void Decoded_iic_putack(bit ack)
Decoded_iic_SDA=ack;
Decoded_iic_SCL=1;
Decoded_iic_SCL=0;
結(jié)束信號(hào)
void Decoded_iic_stop()
uint t=Decoded_iic_WAIT_VALUE;
Decoded_iic_SDA=0;
Decoded_iic_SCL=1;
Decoded_iic_SDA=1;
while(t--);
綜合發(fā)送
bit Decoded_iic_puts(unsigned char SlaveAddr,uchar *dat,unsigned int Length)
if ( Length == 0 ) return 0;
Decoded_iic_start();
Decoded_iic_write(SlaveAddr);發(fā)送地址
if ( Decoded_iic_getack() )
Decoded_iic_stop();
return 1;
發(fā)送數(shù)據(jù)
do
Decoded_iic_write(*dat++);
//Myputchar('c');
break;
} while ( --Length != 0 );
Decoded_iic_stop();
if ( Length == 0 )
//Myputchar('a');
return 0;
//Myputchar('b');
return 1;
綜合接收數(shù)據(jù)
bit Decoded_iic_gets(unsigned char SlaveAddr,uchar *dat,unsigned int Length)
if(!Length)
return 0;
Decoded_iic_write(SlaveAddr+1);發(fā)送地址+1 +1是讀的意思
if(Decoded_iic_getack())
Decoded_iic_stop();
return 1;
for (;;)
*dat++ = Decoded_iic_read();
if ( --Length == 0 )
Decoded_iic_putack(1);發(fā)送非ACK
break;
Decoded_iic_putack(0);發(fā)送ACK
//接收完畢,停止I2C總線,并返回結(jié)果
Decoded_iic_stop();
return 0;
