#include "msp430x54x.h"
void UCS_Init(void)
{ P5SEL |= 0x0C; // Port select XT2
UCSCTL6 &= ~ XT2OFF; // Set XT2 On
P7SEL |= 0x03; // 端口選擇外部低頻晶振XT1
UCSCTL6 &=~XT1OFF; // 使能外部晶振
UCSCTL6 |= XCAP_3; // 設(shè)置內(nèi)部負(fù)載電容
UCSCTL3 |= SELREF_2; // DCOref = REFO
UCSCTL4 |= SELA_0; // ACLK = XT1
__bis_SR_register(SCG0); // 關(guān)閉FLL控制回路
UCSCTL0 =DCO0 + DCO1 + DCO2 + DCO3 + DCO4; // 設(shè)置DCOx, MODx
UCSCTL1 = DCORSEL_5; // 設(shè)置DCO振蕩范圍
UCSCTL2 = FLLD__1 + 0X2A7; // Fdco = ( FLL_FACTOR + 1)×FLLRef = (649 + 1) * 32768 = 21.2992MHz
__bic_SR_register(SCG0); // 打開FLL控制回路
__delay_cycles(1024000);
do
UCSCTL7 &= ~(XT2OFFG + XT1LFOFFG + XT1HFOFFG + DCOFFG); // 清除 XT2,XT1,DCO 錯(cuò)誤標(biāo)志
SFRIFG1 &= ~OFIFG;
}while(SFRIFG1&OFIFG); // 檢測振蕩器錯(cuò)誤標(biāo)志
UCSCTL4 |= SELS__XT2CLK + SELM__XT2CLK + SELA__DCOCLKDIV ; // MCLK=SMCLK=晶振12Mhz DCO=21.2922Mhz
UCSCTL5 |= DIVS__1; // ACLK=32.768 ,SMCLK=XT2/1,MCLK=XT2
void main(void)
{unsigned char a,b,c;
WDTCTL = WDTPW + WDTHOLD; // Stop WDT
UCS_Init();
P3SEL = 0x30; // P3.4,5 = USCI_A0 TXD/RXD
UCA0CTL1 |= UCSWRST; // **Put state machine in reset**
UCA0CTL1 |= UCSSEL__ACLK; // SMCLK
UCA0BR0 = 184; // 12MHz 115200 (see User's Guide)
UCA0BR1 = 0; // 12MHz 115200
UCA0MCTL |= UCBRS_1 + UCBRF_0; // Modulation UCBRSx=1, UCBRFx=0
UCA0CTL1 &= ~UCSWRST; // **Initialize USCI state machine**
UCA0IE |= UCRXIE; // Enable USCI_A0 RX interrupt
P1DIR=0xff;
P1OUT=0x55;
__bis_SR_register(GIE);
//__bis_SR_register(LPM3); // Enter LPM0, interrupts enabled
//__no_operation(); // For debugger
{for(a=0;a<250;a++)
for(b=0;b<25;b++)
for(c=0;c<5;c++)
P1OUT=~P1OUT;
// UCA0TXBUF=P1OUT;
// Echo back RXed character, confirm TX buffer is ready first
#pragma vector=USCI_A0_VECTOR
__interrupt void USCI_A0_ISR(void)
switch(__even_in_range(UCA0IV,4))
case 0:break; // Vector 0 - no interrupt
case 2: // Vector 2 - RXIFG
while (!(UCA0IFG&UCTXIFG)); // USCI_A0 TX buffer ready?
UCA0TXBUF = UCA0RXBUF; // TX -> RXed character
break;
case 4:break; // Vector 4 - TXIFG
default: break;
