當(dāng)前位置:單片機(jī)教程網(wǎng) >> MCU設(shè)計實例 >> 瀏覽文章
uC/FS詳解(開發(fā)文檔)
作者:佚名   來源:本站原創(chuàng)   點擊數(shù):  更新時間:2014年08月18日   【字體:
1: uC/FS簡介
   µC/FS is a FAT file system which can be used on any media, for which you can
provide basic hardware access functions. . µC/FS is a high performance library that has been optimized for speed, versatility and memory footprint.
   文件配置表(英文:File Allocation Table,首字母縮略字:FAT)是一種由微軟發(fā)明的并帶有部分專
件系統(tǒng)。FAT文件系統(tǒng)考慮當(dāng)時計算機(jī)效能有限,所以未被復(fù)雜化,因而被幾乎所有個人計算機(jī)的操作系統(tǒng)支持。這特性使它成為理想的軟盤和記憶卡文件系統(tǒng),也適合用作不同操作系統(tǒng)中的數(shù)據(jù)交流。但FAT有一個嚴(yán)重的缺點:當(dāng)文件被刪除并且在同一位置被寫入新數(shù)據(jù),他們的片段通常是分散的,減慢了讀寫速度。磁盤碎片重整是一種解決方法,但必須經(jīng)常重組來保持FAT文件系統(tǒng)的效率。 FAT文件系統(tǒng)遵行已用了多年的軟件方法來進(jìn)行規(guī)范。它在1977年由比爾·蓋茨和馬斯·麥當(dāng)勞為了管理磁盤而發(fā)明。
2: uC/FS特點
µC/FS is written in ANSI C and can be used on virtually any CPU. Some
features of µC/FS are:
·  MS-DOS/MS-Windows compatible FAT12 and FAT16 support.
·  Multiple device driver support. You can use different device drivers with µC/FS, which allows           you to access different types of hardware with the file system at the same time. 【在該文件系統(tǒng)中可同時支持多個設(shè)備驅(qū)動】
·  Multiple media support. A device driver does allow you to access different medias at the same            time.
·  OS support. µC/FS can easily be integrated into any OS. In that way you can make file operations        in a multithreaded environment.
·  ANSI C stdio.h like API for user applications. An application using standard C I/O library can             easily be ported to use µC/FS.
·  Very simple device driver structure. µC/FS device drivers need only very basic functions for                 reading and writing blocks. Therefore it is very simple to support your custom hardware.
·  Generic device driver for SmartMedia cards, which can easily be used with any kind of card                  reader hardware.
·  Generic device driver for MultitMedia & SD cards using SPI mode, which can be easily integrated.
3: uC/FS結(jié)構(gòu)
   µC/FS 由不同的分層構(gòu)成。
上面的圖是FATFS,但與UC/FS的是一樣的
   1:API層【類似于linux的VFS層】
      The API layer is the interface between µC/FS and the user application. It does contain a library of ANSI C oriented file functions, such as  FS_FOpen, FS_FWrite etc. The API layer does transfer these calls to the file system layer. Currently there is only a FAT file system layer available for µC/FS, but the API layer can deal with different file system layers at the same time. So it is possible to use FAT and any other file system at the same time with µC/FS.
    API層是µC/FS 提供給用戶使用的接口層(fs_api.h),API層將各種調(diào)用傳輸?shù)?/span>file system layer(文件系統(tǒng)層),目前對µC/FS(文件管理實現(xiàn)機(jī)制)來說 只有一個 FAT文件系統(tǒng)層被使用,API層可以處理不同的文件系統(tǒng)層,因此µC/FS可同時支持多種文件系統(tǒng)(API層類似于linux中的虛擬文件系統(tǒng)VFS,他的功能是提供給童用戶標(biāo)準(zhǔn)的系統(tǒng)調(diào)用接口,VFS層下面才是具體實際的文件系統(tǒng)層,有FAT、EXT2等等,這個根據(jù)硬件的情況(格式化時使用什么文件系統(tǒng))來調(diào)用具體的文件系統(tǒng))。
   2:File System Layer 文件系統(tǒng)層【這層與linux是一樣的,是具體的管理文件所用的文件系統(tǒng)】
   The file system layer translates file operations to logical block operations. After such a translation, the file system calls the logical block layer and specifies the corresponding device driver for a device.
   文件系統(tǒng)層將文件操作轉(zhuǎn)換為邏輯塊操作,之后,具體的文件系統(tǒng)調(diào)用邏輯塊層函數(shù)并指定設(shè)備相應(yīng)的驅(qū)動;【linux中,文件系統(tǒng)將各種系統(tǒng)調(diào)用轉(zhuǎn)換為各種IO請求(系統(tǒng)請求即是對底層相應(yīng)的扇區(qū)、柱面、等操作),IO請求被放到對應(yīng)設(shè)備的IO請求隊列中去,再由一個系統(tǒng)內(nèi)核線程一直讀取請求隊列中的請求,沒有請求時就睡眠,拿到請求就通過設(shè)備驅(qū)動實現(xiàn)具體的操作】
    uC_FS\FSL\fat\ 下面就是FAT文件系統(tǒng)的各個文件。
   3:Logical Block Layer 邏輯塊
   the main purpose of the logical block layer is to synchronize accesses to a device driver and to have an easy interface for the file system layer.  The logical block layer does call a device driver to make a block operation.
   邏輯塊層的主要目的是同步訪問設(shè)備驅(qū)動與文件系統(tǒng)的簡易接口,邏輯塊層調(diào)用設(shè)備驅(qū)動來實現(xiàn)設(shè)備的塊操作。
   4: Device Driver Layer 設(shè)備驅(qū)動層
   Device drivers are low level routines that are used to access your hardware.
The structure of the device driver is simple to allow easy integration of your own
hardware.
  設(shè)備驅(qū)動是一些訪問硬件的底層操作,µC/FS的設(shè)備驅(qū)動的架構(gòu)很簡單,不像linux架構(gòu)非常復(fù)雜。
4: uC/FS的使用
   下面的流程是參考uC/FS用戶手冊上的例程來寫的,可以參考。
   1:調(diào)用FS_Init()初始化文件系統(tǒng),在使用uC/FS的任何功能函數(shù)之前須要首先調(diào)用該函數(shù)進(jìn)行初始        化;
   2:進(jìn)入MainTask()
           1:調(diào)用FS_IoCtl()【格式化:使硬件按指定的文件系統(tǒng)來管理文件】
              This call is used to format your RAM disk in order to be able to write data to                     it. Formatting your RAM disk should not cause any problem.
           2:調(diào)用應(yīng)用程序中的函數(shù)_write_file()【非uc/fs的函數(shù)】
                 _write_file()中又依次調(diào)用: FS_FOpen(), FS_FWrite(),FS_FClose()
              FS_FOpen():在這個例程中FS_FOpen()創(chuàng)建了一個叫default.txt的文件,如果創(chuàng)建成功,函數(shù)                           將返回一個FS_FILE結(jié)構(gòu)體的指針,如果出錯將返回0
              FS_FWrite():文件創(chuàng)建成功之后,將一串字符串寫入該文件中,如果寫入時出錯,例程中調(diào)                              FS_FError()處理錯誤。
              FS_FClose():關(guān)閉上面打開的文件,返回主任務(wù)中
    【大致過程就是如上過程】
     讀: FS_FOpen()->FS_FRead()->FS_FClose()
   3:不使用uC/FS文件管理系統(tǒng)時調(diào)用FS_Exit().
5: uC/FS加入到工程中
   1:Create a simple project without µC/FS
      We recommend, that you create a small “hello world” program for your system. That project should already use your OS and there should be a way to display text on a screen or serial port.
   2: Add your µC/FS configuration
      In order to configure  µC/FS for your system, you should create a new sub-directory in µC/FS’s config directory and copy the files  fs_conf.h  and fs_port.h from one of the other sub-directories to your directory. For the following chapters, we assume that you have created a directory FS\CONFIG\myconfig. Usually, the only file  you have to modify is fs_conf.h. For an easy startup, we recommend, that you disable all drivers except the RAM disk driver. Please check out the chapter “Configuration of µC/FS” for detailed information about the configuration.
   3Add µC/FS generic source code
     Add all source files in the following directories:
        FS\API: µC/FS提供給用戶的接口函數(shù)
        FS\FSL: 具體的文件系統(tǒng)層
        FS\LBL: 邏輯塊層
        FS\OS :
        FS\DEVICE\RAM
     and their sub-directories to your project.
   4Configure the search path[為開發(fā)環(huán)境添加所以代碼的路徑]
        FS\API
        FS\CONFIG\myconfig
        FS\LBL
        FS\OS
   5Add generic sample code
       For a quick and easy test of your µC/FS integration, you should use the code
       found in FS\sample\main.c.
6: uC/FS配置
 1:fs_conf.h
     This is the main configuration file for the file system. You define which drivers you want to use and, the configurations for these drivers.
      【用戶手冊中列出了一個配置樣本】,包括下面的各個配置項目
    1:OS support
      You can specify whether you are using uC/OS-II, embOS, Windows or no OS support at all.  Please set  FS_OS_UCOS_II,  FS_OS_EMBOS, FS_OS_WINDOWS to 1, respectively. For no OS support at all, set all of them to 0. If you need support for an additional OS, you will have to provide functions described in the chapter “OS integration”.
    2:Time/Date support
      If you want to be able to add date and times to your files, you will need to set
FS_OS_TIME_SUPPORT  to 1.
    3:File System Layer Support
      µC/FS can support different file system at the same time. You can enable them by setting FS_USE_XXX_FSL, where XXX is the name of the file system layer. The current version of µC/FS only supports the FAT file system, so you will need to set FS_USE_FAT_FSL to 1.
   4:Device Driver Support and configuration
I      RAM Disk:
      FS_USE_RAMDISK_DRIVER
 to  1
       Windows Driver:    FS_USE_WINDRIVE_DRIVER to 1
       Smart Media Card(SMCs):
                          FS_USE_SMC_DRIVER  to 1
       MultiMedia card:
             µC/FS can support  MultiMedia & SD cards. You can enable the driver by setting FS_USE_MMC_DRIVER to 1. In order to use it, you will have to provide low-level I/O functions for your card reader hardware. Please take a look at the chapter “MultiMedia & SD card device driver” for details.
      CompactFlash card & IDE:FS_USE_IDE_DRIVER to 1
 2:fs_port.h【一般是與CPU相關(guān)的數(shù)據(jù)類型】
      Usually this file only requires minor modifications, if you are using a very specific CPU. Please also check the type declarations in this file to ensure that they fit with your target processor and compiler.
6: API函數(shù)說明
  FS_IoCtl:執(zhí)行命令(SD卡等可以通過電腦格式化)
  x = FS_IoCtl("ram:",FS_CMD_FORMAT_MEDIA,FS_MEDIA_RAM_16KB,0);
  Directory functions
  int FS_CloseDir(FS_DIR *dirp);
  int FS_MkDir(const char *dirname);
  FS_DIR *FS_OpenDir(const char *dirname);
  struct FS_DIRENT *FS_ReadDir(FS_DIR *dirp);
  void FS_RewindDir(FS_DIR *dirp);
  int FS_RmDir(const char *dirname);
7: 設(shè)備驅(qū)動Device drivers
  µC/FS可以與任何種類的硬件配合工作;µC/FS需要配備與硬件設(shè)備對應(yīng)的設(shè)備驅(qū)動程序,這些設(shè)備驅(qū)動程序包含 基本的訪問硬件的I/O函數(shù) 以及 一張全局表,這張表中存放各個函數(shù)的指針!韭(lián)想到LINUX中系統(tǒng)調(diào)用的系統(tǒng)調(diào)用號】
  要使你的µC/FS支持特定的硬件設(shè)備,你必須寫好該設(shè)備的驅(qū)動,本節(jié)告訴你需要實現(xiàn)哪些函數(shù)以及怎么樣將驅(qū)動整合到µC/FS中去。
   【下面是ramdisk的設(shè)備驅(qū)動函數(shù)表的例子:設(shè)備驅(qū)動函數(shù)表中的各個函數(shù),在PDF中已給出具體的代碼,其他的設(shè)備,如MMC&SD也是類似的,需要提供這相關(guān)的幾個函數(shù),名字可以不同,在功能函數(shù)的次序要一樣】
  In this chapter, you will find a detailed description of the device driver functions required by µC/FS. Please note that the names used for these functions are not really relevant for  µC/FS because the file system accesses those functions through a function table.
  因為是通過一張全局表來管理各個設(shè)備驅(qū)動函數(shù),所以各設(shè)備驅(qū)動函數(shù)的名稱與µC/FS沒有太多的關(guān)聯(lián)性。
  _FS_DevIoCtl():Execute special command on device.
     static int _FS_DevIoCtl(FS_u32 id, FS_i32 cmd, FS_i32 aux,void *buffer);
                             Parameter  Meaning
                             id         Number of media (0…N)
                             cmd        Command
                             aux        Parameter for command
                             buffer     Pointer to data required by command
     該函數(shù)被用來完成一些設(shè)備驅(qū)動中特殊的命令,對uc/FS來說目前需要支持的這類特殊命令有:FS_CMD_FLUSH_CACHE,這個命令用來告訴設(shè)備的緩沖邏輯 所有的緩沖必須清零,如果你的設(shè)備沒有緩沖邏輯,該函數(shù)不需要做任何事情。
  _FS_DevRead():Read block from media
      static int _FS_DevRead(FS_u32 id, FS_u32 block, void *buffer);
                             block   Block number to be read from the media
                             buffer  Data buffer to which the data is transferred
   The function should transfer 0x0200 (i.e. 512) bytes, which is the default value for an MS-DOS/MS-Windows compatible FAT file systems. µC/FS can support any block size but, if you use the FAT file system layer, you have to use this default block size.
   函數(shù)應(yīng)該傳送0x0200(512)個字節(jié),這個是兼容FAT文件系統(tǒng)的MS-DOS/MS-Windows系統(tǒng)的默認(rèn)值,µC/FS能支持任何大小的塊,但是如果你的文件系統(tǒng)層使用FAT,那么你必須使用這個默認(rèn)的塊大小。
  _FS_DevStatus():Return current status of your device.
     static int _FS_DevStatus(FS_u32 id); id  Number of media (0…N)
   The main purpose of this function is to detect a media change. All µC/FS file operation calls this function to check, if the device can be accessed.
  該函數(shù)的主要目的是檢測一個介質(zhì)的改變。如果一個設(shè)備能夠被訪問,所有的µC/FS 文件操作都調(diào)用這個函數(shù)進(jìn)行檢測,
   The function returns 0 if the device can be accessed. If the media has changed (e.g. a card removed or replaced) and the device can be accessed, the return value has to be FS_LBL_MEDIACHANGED. Any value < 0 is interpreted as an error.
  _FS_DevWrite():Write block to media
      static int _FS_DevWrite(FS_u32 id, FS_u32 block,void *buffer);
                              block   Block number to be written on media
                              buffer  Pointer to data for transfer to the media.
  Device driver function table
   To use a device driver with µC/FS, a global function table is required, which
holds pointers to the device driver functions.  Each entry in the table contains
five values as shown in the example below.
     const FS__device_type FS__ramdevice_driver = {
       "RAMDISK device",
       _FS_DevStatus,
       _FS_DevRead,
       _FS_DevWrite,
       _FS_DevIoCtl
    If you want to use your own device driver, you have to tell µC/FS, which device
name you would like to use for your device and which  File System Layer
(currently only FAT is supported) you want to use.
    You do this by setting appropriate value for FS_DEVINFO in your FS_conf.h ,
which is used to initialize µC/FS’s global device information table.
   如果你想要使用自己的設(shè)備驅(qū)動,你必須要告訴μC/FS,你的設(shè)備使用的是哪一個設(shè)備名稱以及使用哪一個文件系統(tǒng)來管理(目前只支持FAT)。
   可以將 FS_conf.h中的FS_DEVINFO 設(shè)置一個合適的值來完成上面的動作,FS_DEVINFO被用來初始化μC/FS的全局設(shè)備信息表。
 【上面是ramdisk的設(shè)備驅(qū)動函數(shù)表的例子,_FS_DevStatus, _FS_DevRead, _FS_DevWrite,
 _FS_DevIoCtl,就是ramdisk所需的底層驅(qū)動函數(shù)
  這里如果是MMC&SD存儲設(shè)備,下面是源碼。
#ifndef FS_DEVINFO
 #if FS_USE_SMC_DRIVER
   #define FS_DEVINFO_DEVSMC
      {"smc",&FS__fat_functable,&FS__smcdevice_driver,FS_CACHEINFO_SMC_DRIVER 0 },
 #else
 #endif
 #if FS_USE_MMC_DRIVER
   #define FS_DEVINFO_DEVMMC
     {"mmc", &FS__fat_functable,&FS__mmcdevice_driver, FS_CACHEINFO_MMC_DRIVER 0 },
 #else
 #endif
 #endif
從源碼中可以看出,如果沒有定義
FS_DEVINFO宏,且如果沒有定義
 FS_DEVINFO_DEVSMC,系統(tǒng)會自動以FS_DEVINFO_DEVSMC,即采用系統(tǒng)默認(rèn)的設(shè)備驅(qū)動。
我們可以在fs_conf.h中配置
FS_USE_MMC_DRIVER = 1;再定義
#define FS_DEVINFO \
        "mmc",    &FS__fat_functable, &FS__mmcdevice_driver, 0,
FS_USE_MMC_DRIVER = 1,即使沒有定義
 FS_DEVINFO,系統(tǒng)也會有一個默認(rèn)的定義。
FS__fat_functable:這個表不用填充,因為這里面的函數(shù)在API層已經(jīng)實現(xiàn),且系統(tǒng)已經(jīng)設(shè)置好。用戶只需更改FS__mmcdevice_driver里面的各個函數(shù)即可。
【這里支持多個設(shè)備"smc"和"mydev"
        "smc",    &FS__fat_functable, &FS__smcdevice_driver, 0, \
        "mydev",  &FS__fat_functable, &FS__mydevice_driver , 0
【如果不指定,系統(tǒng)將使用默認(rèn)值】
   The first parameter is a device name, which you want to use for  µC/FS’s API
calls.
   The second parameter is a pointer to a  File System Layer function table;
currently only FAT is supported.
   The third parameter is a pointer to a Device Driver function table.
   The last parameter is reserved for future use and should be zero.
8: 各目錄介紹
在工程中添加上面的文件組:API層、FAT層、LBL層、DEV層、OS、CLIB
DEV包含的就是文件系統(tǒng)需要使用的最底層的操作硬件的接口,
這里使用文件系統(tǒng)標(biāo)準(zhǔn)的操作接口:_FS_XXX_Devxxx(....):在這幾個函數(shù)中調(diào)用具體的SD卡的操作函數(shù)來實現(xiàn)與硬件驅(qū)動的鏈接。
CLIB中包含的是文件系統(tǒng)使用的一些C標(biāo)準(zhǔn)函數(shù)。
OS組中包含的文件fs_x_ucos_ii.c中包含的就是一些函數(shù)接口,這些接口是連接操作系統(tǒng)的接口(當(dāng)然在裸機(jī)下也是這些接口),如果使用操作系統(tǒng),這些函數(shù)接口中 就是與操作系統(tǒng)相關(guān)的代碼,如果沒有操作系統(tǒng),這些接口就是很簡單的一些與系統(tǒng)無關(guān)的代碼,總之是文件系統(tǒng)是需要這些接口(有無操作系統(tǒng)接口是一樣的);
各接口函數(shù)如下:
FS_X_OS_Init:創(chuàng)建一些文件系統(tǒng)運行時需要使用的一些信號量(用來訪問資源)
FS_X_OS_Exit:刪除上面創(chuàng)建的各信號量
其他的都是配對的Lock/Unlock,也就是申請獲取一個對應(yīng)的信號量,使用后再釋放這個信號量。
就是這么簡單。
9: MultiMedia & SD card device driver
   µC/FS includes a generic driver for MultiMedia & SD cards. The driver accesses
cards using SPI mode.
   µC/FS包含一個針對MMC/SD卡的通用驅(qū)動,該驅(qū)動通過SPI模式訪問卡。
   To use the driver in your system, you will have to provide basic I/O functions for
accessing your card reader hardware. You can find samples of these routines in
the directory device\mmc_sd\hardware.
   在你的系統(tǒng)中使用該驅(qū)動時,你必須要提供基本的能訪問你的讀卡器硬件的I/O函數(shù)。你可以在“device\mmc_sd\hardware”路徑下找到例子。
   【在源代碼的目錄中官方提供了相關(guān)設(shè)備的通用底層驅(qū)動的例程】
   [下面藍(lán)色的就是官方提供的MMC&SD卡的通用驅(qū)動,但是需要你提供基本的IO訪問函數(shù)]
   [在device\xxx\hardware目錄下,存放的就是對應(yīng)的xxx設(shè)備的通用驅(qū)動,                smc_X_hw.c、smc_X_hw.h]
   FS_MMC_HW_X_BusyLedOff():Turns off busy LED of the card reade
       void FS_MMC_HW_X_BusyLedOff(FS_u32 id);
       id:ID of card reader (0…N).
   FS_MMC_HW_X_BusyLedOn():Turns on busy LED of the card reader.
       void FS_MMC_HW_X_BusyLedOn (FS_u32 id);
   FS_MMC_HW_X_ClockCard()
   FS_MMC_HW_X_SetCS()
   FS_MMC_HW_X_AdjustFOP()
   FS_MMC_HW_X_CheckOCR()
   FS_MMC_HW_X_GetFOP()
   FS_MMC_HW_X_CheckWP()
   FS_MMC_HW_X_DetectStatus()
   FS_MMC_HW_X_WaitBusy()
   FS_MMC_HW_X_ReadByte()
   FS_MMC_HW_X_ReadByteNoSync()
   FS_MMC_HW_X_ReadSingleBlock()
   FS_MMC_HW_X_WriteByte()
   FS_MMC_HW_X_WriteByteSingleBlock()
