51乘法口訣模擬答題器
作者:佚名   來(lái)源:本站原創(chuàng)   點(diǎn)擊數(shù):  更新時(shí)間:2010年06月02日   【字體:
* LCD1602顯示                                                      *
*【版權(quán)】Copyright(C) JAS  All Rights Reserved  *
*【聲明】此程序僅用于學(xué)習(xí)與參考,引用請(qǐng)注明版權(quán)和作者信息!        *
* 描述:                                                           *
*      F--- 模擬出題控制開關(guān); C--- 輸入正確答案;                   *
*      (0-9)--- 有效數(shù)字輸入;                                      *
*      答題正確,蜂鳴器響4聲。                                     *
#include < reg51.h >
#include < intrins.h >
#define uint  unsigned int
bit  F_in=0,truer;
sbit LCD_RS = P2^0;
sbit LCD_RW = P2^1;
sbit LCD_EN = P2^2;
uchar code  cdis1[ ] = {" MULTIPLICATION "};
uchar code  cdis2[ ] = {"TABLE: 0*0=00   "};
#define delayNOP(); {_nop_();_nop_();_nop_();_nop_();};
sbit BEEP = P3^7;          //蜂鳴器驅(qū)動(dòng)線
uchar  key_buf;            //顯示緩存
uchar  temp;
uchar  key,key_num=0;                //鍵順序嗎
uchar data testdata[] = {0x00,0x00,0x00,0x00};
uchar data in_data[] = {0x01,0x02};
uchar shift ;
 延時(shí)子程序
void delay(uint ms)
   uchar t;
   while(ms--)
     for(t = 0; t < 120; t++);
/* 延時(shí) x*0.14ms                                             */
void delay0(uchar x)
   unsigned char i;
   while(x--)
     for (i = 0; i<13; i++) {}
/* 蜂鳴器響一聲                                              */
void beep()
  unsigned char i;
  for (i=0;i<180;i++)
   delay0(6);
   BEEP=!BEEP;       //BEEP取反
   BEEP=1;           //關(guān)閉蜂鳴器
   delay(250);       //延時(shí)
/*檢查L(zhǎng)CD忙狀態(tài)                                              */
/*lcd_busy為1時(shí),忙,等待。lcd-busy為0時(shí),閑,可寫指令與數(shù)據(jù)  */
bit lcd_busy()
    bit result;
    LCD_RS = 0;
    LCD_RW = 1;
    LCD_EN = 1;
    delayNOP();
    result = (bit)(P0&0x80);
    LCD_EN = 0;
    return(result);
/*寫指令數(shù)據(jù)到LCD                                                  */
/*RS=L,RW=L,E=高脈沖,D0-D7=指令碼。                             */
void lcd_wcmd(uchar cmd)
   while(lcd_busy());
    LCD_RS = 0;
    LCD_RW = 0;
    LCD_EN = 0;
    _nop_();
    _nop_();
    P0 = cmd;
    delayNOP();
    LCD_EN = 1;
    delayNOP();
    LCD_EN = 0;
/*寫顯示數(shù)據(jù)到LCD                                                  */
/*RS=H,RW=L,E=高脈沖,D0-D7=數(shù)據(jù)。                               */
void lcd_wdat(uchar dat)
   while(lcd_busy());
    LCD_RS = 1;
    LCD_RW = 0;
    LCD_EN = 0;
    P0 = dat;
    delayNOP();
    LCD_EN = 1;
    delayNOP();
    LCD_EN = 0;
/*  LCD初始化設(shè)定                                            */
void lcd_init()
    delay(15);
    lcd_wcmd(0x38);      //16*2顯示,5*7點(diǎn)陣,8位數(shù)據(jù)
    delay(5);
    lcd_wcmd(0x38);
    delay(5);
    lcd_wcmd(0x38);
    delay(5);
    lcd_wcmd(0x0c);      //顯示開,關(guān)光標(biāo)
    delay(5);
    lcd_wcmd(0x06);      //移動(dòng)光標(biāo)
    delay(5);
    lcd_wcmd(0x01);      //清除LCD的顯示內(nèi)容
    delay(5);
/*  設(shè)定顯示位置                                             */
void lcd_pos(uchar pos)
  lcd_wcmd(pos | 0x80);  //數(shù)據(jù)指針=80+地址變量
 鍵掃描子程序
void  keyscan(void)
    P1=0x0F;                 //低四位輸入
    delay(1);
 temp=P1;                 //讀P1口
    temp=temp&0x0F;
    temp=~(temp|0xF0);
    if(temp==1)
        key=0;
    else if(temp==2)
        key=1;
    else if(temp==4)
        key=2;
    else if(temp==8)
        key=3;
        key=16;
    P1=0xF0;                //高四位輸入
    delay(1);
 temp=P1;                //讀P1口
    temp=temp&0xF0;
    temp=~((temp>>4)|0xF0);
    if(temp==1)
        key=key+0;
    else if(temp==2)
        key=key+4;
    else if(temp==4)
        key=key+8;
    else if(temp==8)
        key=key+12;
        key=16;
     key_buf = key;              //鍵值入顯示緩存
     key_buf = key_buf & 0x0f;
 判斷鍵是否按下
 void  keydown(void)
   P1=0xF0;
 while(P1==0xf0);
   keyscan();
   beep();
  隨機(jī)出題函數(shù)
void  rubric()
   uchar  num1,num2,temp1;
   TR1=0;
   temp1=TL1;                   //取T1當(dāng)前的計(jì)數(shù)值
   temp1=~temp1;                //取反得到對(duì)應(yīng)的題號(hào)
   num2=temp1/9;                //就題目分成9組
   num2++;                      //將組號(hào)0~8轉(zhuǎn)換為被乘數(shù)1~9
   testdata[3]=num2+0x30;       //保存被乘數(shù)
   num1=temp1%9;
   num1++;                      //將組號(hào)0~8轉(zhuǎn)換為乘數(shù)1~9。
   testdata[2]=num1+0x30;       //保存乘數(shù)
   temp1=num2*num1;             //計(jì)算乘積
   testdata[1]=temp1/10+0x30;   //乘積的高位
   testdata[0]=temp1%10+0x30;   //乘積的低位
   TR1=1;
  鍵入正確答案函數(shù)
void  right()
   if(testdata[1]==0x30)
   testdata[1]=0x20;
   lcd_pos(0x4b);
   in_data[1]=testdata[1];
   in_data[0]=testdata[0];
   lcd_wdat(in_data[1]);
   lcd_wdat(in_data[0]);
  鍵入答案函數(shù)
void  key_input()
   if(testdata[1]==0x30)        //先判斷十位數(shù)是否為0
     in_data[1]=0x30;
  key_num=1;
     keydown();
  if(key_buf==0x0c)          //C 鍵顯示正確答案
    right();
       key_num=0;
     if(key_buf<10)
       key_buf=key_buf+0x30; //轉(zhuǎn)換為ASCII碼
       in_data[1]=key_buf;      //輸入乘積高位
       lcd_pos(0x4b);
       lcd_wdat(in_data[1]);    //顯示乘積高位
       lcd_wdat(0x20);
    key_num=1;
   if(key_num==1)
     keydown();
       right();
    key_num=0;
     if(key_buf<10)
       in_data[0]=key_buf;      //輸入乘積低位
       lcd_pos(0x4c);
       lcd_wdat(in_data[0]);    //顯示乘積低位
    key_num=0;
  數(shù)據(jù)比較函數(shù)
void  datacomp()
   if(testdata[1]-in_data[1]==0)    //比較乘積高位
      if(testdata[0]-in_data[0]==0) //比較乘積低位
      beep();                //計(jì)算正確蜂鳴器響3聲
   beep();
   beep();
   truer=1;               //比較正確
         F_in=0;                //可以重新出題
      else  truer=0;            //比較錯(cuò)誤
   if(truer==0)
     lcd_pos(0x4B);             //清除錯(cuò)誤答案
     lcd_wdat(0x20);
  lcd_wdat(0x3f);
  F_in=1;                    //禁止重新出題
  主函數(shù)
main()
   uchar  m;
   lcd_init();                  //初始化LCD
   lcd_pos(0x00);               //設(shè)置顯示位置為第一行
   for(m=0;m<16;m++)
   lcd_wdat(cdis1
   lcd_pos(0x40);               //設(shè)置顯示位置為第二行
   for(m=0;m<16;m++)
   lcd_wdat(cdis2
   TMOD=0x21;                 //將T1設(shè)置為8位自動(dòng)重裝工作方式。
   TH1=175;                     //對(duì)T1定時(shí)常數(shù)進(jìn)行預(yù)置。
   TL1=175;
   TR1=1;                       //啟動(dòng)T1。
     keydown();
     if(key_buf==0x0f)          //F 鍵為模擬出題開關(guān)
    rubric();
    lcd_pos(0x47);
       lcd_wdat(testdata[3]);   //顯示被乘數(shù)
       lcd_pos(0x49);
       lcd_wdat(testdata[2]);   //顯示乘數(shù)
       lcd_pos(0x4B);
       lcd_wdat(0x20);
       lcd_wdat(0x3f);          //顯示 ?
    key_buf=0x00;
    F_in=1;                  //出題目完畢標(biāo)志
     while(F_in==1)
    key_input();
       datacomp();
