這是兩塊C51芯片控制的程序 第一塊是鬧鐘計(jì)時(shí)器:
代碼:
#include <at89x51.h> unsigned char a[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f}; unsigned char b[6]={0x7e,0x7d,0x7b,0x77,0x6f,0x5f}; unsigned char c[6]={5,5,9,5,8,0}; unsigned char d[6]={0,0,0,0,9,0}; unsigned char i,f,r,j=0x0f,k=0,x=0; unsigned char s=55,m=59,h=8; unsigned char ns=0,nm=0,nh=9; void main(void) {TMOD=0x01; TH0=15536/256; TL0=15536%256; EA=0x01; ET0=0x01; TR0=0x01; while(1) {if(P1_3==0){j=~j;while(P1_3==0);} switch(j) { case 0xf0: for(x=0;x<6;x++) {P3=b[x]; P2=a[d[x]]; for(i=0;i<255;i++) ; switch(P1) { case 0xfe:ns=ns+1;if(ns==60) {ns=0;} while(P1_0==0);break; case 0xfd:nm=nm+1;if(nm==60) {nm=0;} while(P1_1==0);break; case 0xfb:nh=nh+1;if(nh==24) {nh=0;} while(P1_2==0);break; } } break; case 0x0f: for(x=0;x<6;x++) { P3=b[x]; P2=a[c[x]]; for(i=0;i<255;i++); switch(P1) { case 0xfe:s=s+1;if(s==60) {s=0;} while(P1_0==0);break; case 0xfd:m=m+1;if(m==60) {m=0;} while(P1_1==0);break; case 0xfb:h=h+1;if(h==24) {h=0;} while(P1_2==0);break; } } break; } } } void zd(void) interrupt 1 {TH0=0x01; TL0=0x01; k=k+1; if(k==20) {k=0;s=s+1; if(s==60) {s=0;m=m+1; if(m==60) {m=0;h=h+1; if(h==24) {h=0;} } } } if(s==ns&&m==nm&&h==nh) {P3_7=~P3_7; for(f=0;f<80;f++) { for(i=0;i<255;i++); for(r=0;r<255;r++); } } c[0]=s%10;c[1]=s/10; c[2]=m%10;c[3]=m/10; c[4]=h%10;c[5]=h/10; d[0]=ns%10;d[1]=ns/10; d[2]=nm%10;d[3]=nm/10; d[4]=nh%10;d[5]=nh/10; } 第二塊是加延時(shí)的LED燈程序: 代碼: #include<at89x51.h> #define uchar unsigned char #define uint unsigned int uchar code Pattern_P0[]= { 0xfc,0xf9,0xf3,0xe7,0xcf,0x9f,0x3f,0x7f,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff, 0xe7,0xdb,0xbd,0x7e,0xbd,0xdb,0xe7,0xff,0xe7,0xc3,0x81,0x00,0x81,0xc3,0xe7,0xff, 0xaa,0x55,0x18,0xff,0xf0,0x0f,0x00,0xff,0xf8,0xf1,0xe3,0xc7,0x8f,0x1f,0x3f,0x7f, 0x7f,0x3f,0x1f,0x8f,0xc7,0xe3,0xf1,0xf8,0xff,0x00,0x00,0xff,0xff,0x0f,0xf0,0xff, 0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff, 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe, 0xfe,0xfe,0xf8,0xf0,0xe0,0xc0,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0xc0,0xe0,0xf0,0xf8,0xfc,0xfe, 0x00,0xff,0x00,0xff,0x00,0xff,0x00,0xff }; uchar code Pattern_P2[]= { 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0xfc,0xf9,0xf3,0xe7,0xcf,0x9f,0x3f,0xff, 0xe7,0xdb,0xbd,0x7e,0xbd,0xdb,0xe7,0xff,0xe7,0xc3,0x81,0x00,0x81,0xc3,0xe7,0xff, 0xaa,0x55,0x18,0xff,0xf0,0x0f,0x00,0xff,0xf8,0xf1,0xe3,0xc7,0x8f,0x1f,0x3f,0x7f, 0x7f,0x3f,0x1f,0x8f,0xc7,0xe3,0xf1,0xf8,0xff,0x00,0x00,0xff,0xff,0x0f,0xf0,0xff, 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f, 0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff, 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0xfc,0xf8,0xf0,0xe0,0xc0,0x80,0x00, 0x00,0x80,0xc0,0xc0,0xf0,0xf8,0xfc,0xfe,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff, 0x00,0xff,0x00,0xff,0x00,0xff,0x00,0xff }; //延時(shí) void Delay(uint x) { uchar i; while(x--) { for(i=0;i<120;i++); } } //主程序 void main() { uchar i; while(1) {//從數(shù)組中讀取數(shù)據(jù)送至P0和P2口顯示 P2=0x00; while(P1_0==~P1_0){ for(i=0;i<136;i++) { P0=Pattern_P0[i]; P2=Pattern_P2[i]; Delay(100); }}}}
