/***************時(shí)鐘采用定時(shí)中斷方式,50MS一次******完整可用,硬件實(shí)驗(yàn)通過**********************/ #include <REG51.H> #include <stdio.h> #include <intrins.h> /***********************************************************************/ #define uchar unsigned char #define uint unsigned int //common part #define HIGH 1 #define LOW 0 #define TRUE 1 #define FALSE 0 #define ZERO 0 #define MSB 0x80 #define LSB 0x01 //max7219 part #define REG_NO_OP 0x00 // 定義空操作 #define DIG_1 0x01 // 定義數(shù)碼管1 #define DIG_2 0x02 // 定義數(shù)碼管2 #define DIG_3 0x03 // 定義數(shù)碼管3 #define DIG_4 0x04 // 定義數(shù)碼管4 #define DIG_5 0x05 // 定義數(shù)碼管5 #define DIG_6 0x06 // 定義數(shù)碼管6 #define DIG_7 0x07 // 定義數(shù)碼管7 #define DIG_8 0x08 // 定義數(shù)碼管8 #define DECODE_MODE 0x09 #define INTENSITY 0x0A #define SCAN_LIMIT 0x0B #define SHUT_DOWN 0x0C #define DISPLAY_TEST 0x0F uchar deda,sec,min,hour,week=1; /***********************************************************************/ //change this part at different board sbit LOAD=P2^7; //MAX7219 Load-Data Input: rising edge pin 12 sbit DIN=P2^5; //MAX7219 Serial-Data Input: rising edge pin 1 sbit CLK=P2^6; //MAX7219 sbit TT=P1^4; sbit QQ=P3^6; sbit RR=P3^7; //function define /***********************************************************************/ void Write_Max7219_byte(unsigned char temp);//write max7219 a byte void Write_Max7219(unsigned char address,unsigned char dat);//write max7219 command and data void Init_Max7219(void);//Initize max7219 //test program display from 1~8 /***********************************************************************/ /***********************************************************************/ void Write_Max7219_byte(unsigned char temp) { unsigned char i; for (i=0;i<8;i++) { CLK=LOW; DIN=(bit)(temp&MSB); temp<<=1; CLK=HIGH; } } /***********************************************************************/ void Write_Max7219(unsigned char address,unsigned char dat) { LOAD=LOW; Write_Max7219_byte(address); Write_Max7219_byte(dat); LOAD=HIGH; } /***********************************************************************/ void Init_Max7219(void) { Write_Max7219(SHUT_DOWN, 0x01); //Normal Operation XXXXXXX1 Shutdown Mode XXXXXXXX0 Write_Max7219(DISPLAY_TEST, 0x00); //Normal Operation XXXXXXX0 Display Test Mode Write_Max7219(DECODE_MODE, 0xff); //Decode Mode Select D7~D0 1 B decode 0 No decode Write_Max7219(SCAN_LIMIT, 0x07); //SCAN LIMIT 0~7 0xX0~0xX7 Write_Max7219(INTENSITY, 0x04); Write_Max7219(DIG_4,0x02); Write_Max7219(DIG_3,0x01); Write_Max7219(DIG_6,0x07); Write_Max7219(DIG_5,0x05); Write_Max7219(DIG_7,0x01); } /*****************************************************/ void init(void) { TMOD=0x01; TH0=-(50000/256); TL0=-(50000%256); ET0=1; TR0=1; EA=1; TT=0; QQ=0; RR=0; Init_Max7219(); } /******************************************/ void time0(void) interrupt 1 { TH0=-(50000/256); TL0=-(50000%256); deda++; } /***************************************/ void conv(void) { if(deda>=20){deda=0;sec++;Write_Max7219(DIG_8,sec%10); Write_Max7219(DIG_7,sec/10); } if(sec>=60){sec=0;min++; Write_Max7219(DIG_6,min%10); Write_Max7219(DIG_5,min/10);} if(min>=60){min=0;hour++; Write_Max7219(DIG_4,hour%10); Write_Max7219(DIG_3,hour/10);} if(hour>=24){hour=0;week++; Write_Max7219(DIG_2,week%10);} if(week>7){week=1;} if(hour==3) TT=1; } /*****************************************/ void delay(uint k) { uint data i,j; for(i=0;i<k;i++){ for(j=0;j<121;j++) {;}} } /**********************************************/ uchar scan_key(void) { uchar temp; P3=0x3f; temp=P3; if(temp!=0x3f) {delay(20); temp=P3; if(temp!=0x3f) return temp; } return 0x3f; } /********************************************/ void main(void) {uchar key_flag; init(); while(1) { conv(); key_flag=scan_key(); switch(key_flag) { case 0x3b:if(++min>59)min=0; delay(300); Write_Max7219(DIG_6,min%10); Write_Max7219(DIG_5,min/10);break; case 0x37:if(++hour>23)hour=0; delay(300);Write_Max7219(DIG_4,hour%10); Write_Max7219(DIG_3,hour/10);break ; case 0x2f:if(++week>7)week=1 ; delay(300); Write_Max7219(DIG_2,week%10);break; default: break; } } }
