輕松搞定獨(dú)立鍵盤控制與4*4行列式矩陣鍵盤掃描
作者:佚名   來源:本站原創(chuàng)   點(diǎn)擊數(shù):  更新時(shí)間:2012年04月06日   【字體:
電路圖很簡單就不畫了,電路的接法是p1口接矩陣鍵盤,p3口接獨(dú)立鍵盤,8個(gè)led燈接在p0口上的.
 #include<reg52.h>
 #define on 0
 #define off 1
 sbit led1=P0^0;
 sbit led2=P0^1;
 sbit led3=P0^2;
 sbit led4=P0^3;
 sbit led5=P0^4;
 sbit led6=P0^5;
 sbit led7=P0^6;
 sbit led8=P0^7;
 sbit key1=P3^0;
 sbit key2=P3^1;
 sbit key3=P3^2;
 sbit key4=P3^3;
 sbit key5=P3^4;
 sbit key6=P3^5;
 sbit key7=P3^6;
 sbit key8=P3^7;
 void delay_ms(uchar time)
  uchar i,j;
  for(i=time;i>0;i--)
   for(j=85;j>0;j++)
 uchar scan_key()
  //uchar i,j;
  //P3=0xff;
  if((P3&0xff)!=0xff)
   delay_ms(30);
   if((P3&0xff)!=0xff)
    if(key1==0)
    return(1);
    if(key2==0)
    return(2);
    if(key3==0)
    return(3);
    if(key4==0)
    return(4);
    if(key5==0)
    return(5);
    if(key6==0)
    return(6);
    if(key7==0)
    return(7);
    if(key8==0)
    return(8);
  return 0;
 void main(void)
  uchar key_value;
  key_value=scan_key();
  switch(key_value)
   case 1:led1=on;break;
  case 2:led2=on;break;
  case 3:led3=on;break;
  case 4:led4=on;break;
  case 5:led5=on;break;
  case 6:led6=on;break;
  case 7:led7=on;break;
  case 8:led8=on;break;
  default:P0=0xff;
4*4行列式矩陣鍵盤
 #include<reg52.h>
 sbit led1 =P0^0  ;
 sbit led2 =P0^1  ;
 sbit led3 =P0^2  ;
 sbit led4 =P0^3  ;
 sbit led5 =P0^4  ;
 sbit led6 =P0^5  ;
 sbit led7 =P0^6  ;
 sbit led8 =P0^7  ;
 #define on 0
 #define off 1
 void delay_ms(uint time)
  uint i,j;
  for(i=time;i>0;i--)
  for(j=112;j>0;j--)
 //d/*
 uchar s_scan(void)
  uchar scan_code,temp;
  P1=0xf0;
  if((P1&0xf0)!=0x0f)
   delay_ms(30);
   if((P1&0xf0)!=0xf0)
    scan_code=0xfe;
    while((scan_code&0x10)!=0)
     P1=scan_code;
     if((P1&0xf0)!=0xf0)
      temp=(P1&0xf0)|0x0f;
      while((P1&0xf0)!=0xf0)
      return ((~scan_code)+(~temp));
      scan_code=(scan_code<<1)|0x01;
  return 0;
 uchar s_scan(void)
  uchar scanh,scanl;
  P1=0xf0;
  if((P1&0xf0)!=0xf0)
   P1=0xf0;
   delay_ms(30);
   if((P1&0xf0)!=0xf0)
     P1=0xfe ;
     //P1=scanh;
    if((P1&0xf0)!=0xf0)
     P1&=0xf0;
     if(P1==0xe0)
     return(1);
     if(P1==0xd0)
     return(2);
     if(P1==0xb0)
     return(3);
     if(P1==0x70)
     return(4);
      P1=0xfd;
    if((P1&0xf0)!=0xf0)
     P1&=0xf0;
     if(P1==0xe0)
     return(5);
     if(P1==0xd0)
     return(6);
     if(P1==0xb0)
     return(7);
     if(P1==0x70)
     return(8);
     P1=0xfb;
    if((P1&0xf0)!=0xf0)
     P1&=0xf0;
     if(P1==0xe0)
     return(9);
     if(P1==0xd0)
     return(10);
     if(P1==0xb0)
     return(11);
     if(P1==0x70)
     return(12);
      P1=0xf7;
    if((P1&0xf0)!=0xf0)
     P1&=0xf0;
     if(P1==0xe0)
     return(13);
     if(P1==0xd0)
     return(14);
     if(P1==0xb0)
     return(15);
     if(P1==0x70)
     return(16);
  return 0;
 void main(void)
  uchar key_code;
   key_code=s_scan();
   if(key_code)
   P0=key_code;
   delay_ms(300);
   led1=~led1;
   delay_ms(300);
   switch(key_code)
    default:P0=0xff;
