仿真圖:
仿真文件和完整源碼的下載地址:http://www.torrancerestoration.com/bbs/dpj-20600-1.html
源代碼:
#include<reg51.h>
#include<intrins.h>
#include <string.h>
#include <stdio.h>
sbit RS= P2^0 ; //液晶顯示引腳定義
sbit RW= P2^1 ;
sbit EN= P2^2 ;
uint t=0,dian=0;
uchar LCD_LINE_ONE[16]={"tp1: "}; //定義顯示屏幕
uchar LCD_LINE_TWO[16]={"tp2: "};
//uchar LCD_LINE_THR[16]={" "};
int Tm;
int fushu=0 ;
sbit DQ= P3^3;
static unsigned char get_serial[]={ //獲取的八個(gè)DS18B20內(nèi)部RAM64位序列號
224, 0,0,0, 184, 197, 50, 40,
215, 0,0,0, 184, 197, 51, 40
// 82, 0,0,0, 184, 197, 52, 40
// 101, 0,0,0, 184, 197, 53,40,
//60, 0,0,0, 184, 197, 54,40,
//11, 0,0,0, 184, 197, 55,40,
//47, 0,0,0, 184, 197, 56,40,
//185, 0,0,0, 184, 197, 49,40,
void delay( ms ) //用于液晶顯示的延時(shí)函數(shù)
int i ;
while(ms--)
for(i=0 ;i<5 ;i++ ) ;
uchar Read_LCD_State() //讀取液晶顯示的狀態(tài)
uchar state;
RS=0;RW=1;EN=1;delay(1);
state=P0;
EN = 0;delay(1);
return state;
void LCD_Busy_Wait() //如果忙則等待函數(shù)
while((Read_LCD_State()&0x80)==0x80);
delay(5);
void Write_LCD_Zhilin(uchar zl) //液晶顯示寫指令函數(shù)
LCD_Busy_Wait();
RS=0;RW=0;
EN=0;
P0=zl;
EN=1;
delay(1);
EN=0;
void Write_LCD_shuju(uchar date) //液晶顯示寫數(shù)據(jù)函數(shù)
LCD_Busy_Wait();
RS=1;RW=0;
EN=0;
P0=date;
EN=1;
delay(1);
EN=0;
void LCD_INIT() //液晶顯示初始化
Write_LCD_Zhilin(0x38); // 顯示模式設(shè)置
delay(1);
Write_LCD_Zhilin(0x01); // 顯示清屏
delay(1);
Write_LCD_Zhilin(0x06); // 光標(biāo)移動(dòng)設(shè)置
delay(1);
Write_LCD_Zhilin(0x0c); // 開及光標(biāo)設(shè)置
delay(1);
void Display_LCD_String(uchar p,uchar *s) //液晶顯示寫入函數(shù)
uchar i;
Write_LCD_Zhilin(p|0x80) ; //寫地址高位為一
//Write_LCD_Zhilin(0x40|0x80) ;
for(i=0;i<16;i++)
Write_LCD_shuju(s[i]);
delay(1);
void delays(int us) //用于DS18B20的延時(shí)函數(shù)
{ int s;
for ( s=0; s<us; s++);
void rst(void) //DS18B20初始化
DQ = 1;
delays(2);
DQ = 0;
delays(30); //精確延時(shí) 480~960us
DQ = 1;
delays(8);
void write(unsigned char ku) //DS18B20寫函數(shù)
int i=0;
for (i=0;i<8;i++)
DQ=0;
DQ =ku&0x01;
delays(3);
DQ=1;
ku>>=1;
void match_rom(unsigned char *rom) //DS18B20匹配ROM函數(shù)
unsigned char i;
rst(); //初始化
write(0x55); //匹配ROM
for(i=8;i>0;i--)
write(*(rom+i-1));
unsigned int read(void) //DS18B20讀函數(shù),每次讀16位
int i=0;
unsigned int u=0;
for (i=0;i<16;i++)
DQ=0;
u>>=1;
DQ=1;
if(DQ) u|=0x8000;
delays(4);
return (u);
int read0(unsigned char *seria) //讀取對應(yīng)溫度值并轉(zhuǎn)換函數(shù)
int temperature ;
unsigned int tp;
unsigned int lsb;
rst(); //初始化
write(0xCC); //跳過RAM
write(0x44); //溫度轉(zhuǎn)換
rst(); //再次初始化
write(0xCC);
match_rom(seria); //匹配ROM函數(shù)調(diào)用
write(0xBE); //讀取存儲器指令
tp=read(); //讀取溫度值
if((tp&0xf800)==0xf800) //判斷正負(fù)數(shù)
fushu=1 ;
tp=~tp+1 ;
lsb=(unsigned int)(tp*6.25);
dian=lsb%100; //取小數(shù)部分
temperature=lsb/100;
fushu=0;
dian=lsb%100;
return(temperature);
uint i ;
LCD_INIT();
EA=0 ; //使用DS18B20禁止任何中斷
for(i=0;i<2;i++)
Tm=read0(get_serial+i*8);
if(i==0) //判斷是第幾個(gè)的數(shù)據(jù)
if(fushu==0) //判斷是否加負(fù)號
sprintf(LCD_LINE_ONE+5," %d", Tm);
if(fushu==1)
sprintf(LCD_LINE_ONE+5,"-%d", Tm);
sprintf(LCD_LINE_ONE+10,".%d",dian); //加入小數(shù)部分
Display_LCD_String(0x00,LCD_LINE_ONE);
if(i==1)
if(fushu==0)
sprintf(LCD_LINE_TWO+5," %d", Tm);
if(fushu==1)
sprintf(LCD_LINE_TWO+5,"-%d", Tm);
sprintf(LCD_LINE_TWO+10,".%d",dian);
Display_LCD_String(0x40,LCD_LINE_TWO);
