//遙控器采用Ht6221芯片
//紅外線遙控 用外部中斷作為紅外線解碼輸入 紅外遙控器1號鍵為電風(fēng)扇啟動鍵
#include <reg51.h>
code uchar seg[]={0x28,0x7e,0xa2,0x62,0x74,0x61,0x21,0x7a,0x20,0x60}; //數(shù)碼管碼表
code uchar tab[]={0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe}; //數(shù)碼管位選
code uchar ss[]={0x10,0x03,0x01,0x06,0x09,0x1d,0x1f,0x0d,0x19,0x1b,0x11,0x15,0x17,0x12,0x16,0x4c,0x40,0x48,0x04,0x00,
0x02,0x05,0x54,0x4d,0x0a,0x1e,0x0e,0x1a,0x1c,0x14,0x0f,0x0c}; //紅外線鍵碼1--32
void delay(uint k)
while(k--);
while(k--);
void show(uint k) //顯示數(shù)值
uchar i=0,j;
uchar s[4]; //顯示最終位數(shù)
do
s[i++]=k%10; //數(shù)據(jù)分離
uchar i=0,j;
do
}while(k/=10);
for(j=0;j<i;j++)
P0=seg[s[j]];
P2=~(1<<(3-j));
delay(100);
P0=0xff;
P2=0xff;
P0=seg[s[j]];
P2=~(1<<(3-j));
delay(100);
P0=0xff;
P2=0xff;
uchar buf[4]; //存放解碼結(jié)果
sbit out=P3^2; //紅外線發(fā)射點
sbit fan=P1^0; //電扇控制位
void time0_init()
TMOD|=0x01; //設(shè)置定時器0方式
TH0=0;
TL0=0;
TR0=0;
ET0=0;
TH0=0;
TL0=0;
TR0=0;
ET0=0;
uint low_test() //測低電平時間
uint t;
TR0=1; //啟動定時器
while((out==0)&&(TH0&0x80)==0) //低電平時間不超時最多9ms
if(TH0&0x80)break; // 超時結(jié)束
TR0=0; //關(guān)閉定時器
t=TH0;
t<<=8;
t|=TL0;
TH0=0; //定時器清零
TL0=0;
return t;
uint t;
TR0=1; //啟動定時器
t=TH0;
t<<=8;
t|=TL0;
TH0=0; //定時器清零
TL0=0;
return t;
uint high_test() //測高電平時間
uint t;
TR0=1; //啟動定時器
while((out==1)&&(TH0&0x80)==0) //低電平時間不超時最多9ms
t=TH0;
t<<=8;
t|=TL0;
TH0=0;
TL0=0;
return t;
uint t;
TR0=1; //啟動定時器
t=TH0;
t<<=8;
t|=TL0;
TH0=0;
TL0=0;
return t;
uchar get_byte() //紅外線接受先接受低位數(shù)據(jù)后接受高位數(shù)據(jù)
uint t;
uchar i,dat;
for(i=0;i<8;i++)
t=low_test();
t=high_test();
dat>>=1;
if((t>1400)&&(t<1700))
dat|=0x80;
return dat;
uint t;
uchar i,dat;
for(i=0;i<8;i++)
t=low_test();
t=high_test();
dat>>=1;
dat|=0x80;
return dat;
void decode() //紅外線解碼
uint t;
if(out==0) //表示接受到紅外線信號
t=low_test();
if((t>8000)&&(t<8500)) //低電平時間在9ms左右
t=high_test();
if((t>4000)&&(t<4500)) //高電平時間在4.5ms左右
buf[0]=get_byte(); // 獲取解碼值
buf[1]=get_byte();
buf[2]=get_byte();
buf[3]=get_byte();
if(buf[2]==~buf[3]) //鍵碼校驗
again:
t=low_test();
t=high_test();
if((t-2500)<500) //測停止位時間
goto again;
uint t;
t=low_test();
t=high_test();
buf[1]=get_byte();
buf[2]=get_byte();
buf[3]=get_byte();
again:
t=low_test();
t=high_test();
goto again;
void int0() //外部中斷0設(shè)定
EA=1;
IT0=1; //外部中斷下降沿觸發(fā)
EX0=1; //外部中斷0開啟
EA=1;
EX0=1; //外部中斷0開啟
void int0_exe() interrupt 0 //外部中斷函數(shù)
decode();
decode();
uchar panduan() //鍵碼按鍵數(shù)判斷
uchar i;
for(i=0;i<32;i++)
if(buf[2]==ss[i])break;
uchar i;
for(i=0;i<32;i++)
return i+1;
return i+1;
uchar start;
time0_init();
int0();
P1=0xff;
show(panduan());
start=panduan();
if(start==1)
fan=0; //電扇啟動
fan=1; //電扇關(guān)閉
uchar start;
time0_init();
int0();
P1=0xff;
show(panduan());
start=panduan();
if(start==1)
fan=0; //電扇啟動
fan=1; //電扇關(guān)閉
