AVR的EEPROM簡(jiǎn)單實(shí)驗(yàn)
作者:佚名   來(lái)源:本站原創(chuàng)   點(diǎn)擊數(shù):  更新時(shí)間:2013年10月27日   【字體:
#include <iom16.h>
#include <intrinsics.h>
__flash uchar seg[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
__flash uchar tab[8]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
#define EEWE 1
#define EERE 0
#define EEMWE 2
#define k1 PIND_Bit4            //地址變化鍵
#define k2 PIND_Bit5            //數(shù)據(jù)變化鍵
#define k3 PIND_Bit6            //地址寫(xiě)入
#define k4 PIND_Bit7            //地址讀出
uint val;         //顯示的存儲(chǔ)數(shù)值
uchar address,data;  //存儲(chǔ)地址和數(shù)值
void delay(uint k)  //延遲函數(shù)
 uint i,j;
for(i=0;i<k;i++)
for(j=0;j<1140;j++);
void key1()
 static uchar i,j;
if(k1==0)
  if(i==0)
   j++;
   if(j>3)
    if(k1==0)
     i=1;j=0;
     address++;
 i=0;j=0;
void key2()
 static uchar i,j;
if(k2==0)
  if(i==0)
   j++;
   if(j>3)
    if(k2==0)
     i=1;j=0;
     data++;
 i=0;j=0;
void show_val(uint k)     //顯示數(shù)值函數(shù)
 static uchar i=0,j;
 uchar ss[6];
 do
  ss[i]=k%10;
  i++;
 }while(k/=10);
 for(j=0;j<i;j++)
  PORTA=seg[ss[j]];
  PORTC=tab[j];
  delay(1);
  PORTA=0xff;
  PORTC=0xff;
 i=0;
void show_address(uint k)     //顯示數(shù)值函數(shù)
 static uchar i=0,j;
 uchar ss[6];
 do
  ss[i]=k%10;
  i++;
 }while(k/=10);
 for(j=0;j<i;j++)
  PORTA=seg[ss[j]];
  PORTC=tab[j+3];
  delay(1);
  PORTA=0xff;
  PORTC=0xff;
 i=0;
void show_data(uint k)     //顯示數(shù)值函數(shù)
 static uchar i=0,j;
 uchar ss[6];
 do
  ss[i]=k%10;
  i++;
 }while(k/=10);
 for(j=0;j<i;j++)
  PORTA=seg[ss[j]];
  PORTC=tab[j+6];
  delay(1);
  PORTA=0xff;
  PORTC=0xff;
 i=0;
#include "1602.h"
void port_init()   //端口初始化
PORTA=0xff;
DDRA=0xff;
PORTB=0xff;
DDRB=0xff;
PORTC=0xff;
DDRC=0xff;
PORTD=0xff;
DDRD=0x0f;
void write_EEPROM(uchar address,uchar data)    //寫(xiě)入EEPROM函數(shù)
  while(EECR&(1<<EEWE));  //等待變成0
  EEAR=address;
  EEDR=data;
  EECR|=(1<<EEMWE);        //
  EECR|=(1<<EEWE);         //
uchar receive_EEPROM(uchar address)        //讀取EEPROM操作
  while(EECR&(1<<EEWE));   //檢查寫(xiě)操作位是否正在進(jìn)行,如果不在進(jìn)行則進(jìn)行讀取
  EEAR=address;
  EECR|=(1<<EERE);    //設(shè)置為讀狀態(tài)
  return EEDR;
void key3()
 static uchar i,j;
if(k3==0)
  if(i==0)
   j++;
   if(j>3)
    if(k3==0)
     i=1;j=0;
     write_EEPROM(address,data);
 i=0;j=0;
void key4()
 static uchar i,j;
if(k4==0)
  if(i==0)
   j++;
   if(j>3)
    if(k4==0)
     i=1;j=0;
     val=receive_EEPROM(address);
 i=0;j=0;
  port_init();
   show_val(val);               //顯示數(shù)據(jù)值
   show_address(address);        //顯示數(shù)據(jù)地址
   show_data(data);              //顯示需要寫(xiě)入的數(shù)據(jù)地址
   key1();           //改變數(shù)據(jù)地址
   key2();          //改變準(zhǔn)備寫(xiě)入的數(shù)據(jù)值
   key3();         //把數(shù)據(jù)寫(xiě)入地址中
   key4();        //讀出地址值
