專注電子技術(shù)學習與研究
51單片機100內(nèi)的加減乘除計算器C語言程序
作者:佚名   來源:本站原創(chuàng)   點擊數(shù):  更新時間:2013年11月06日   【字體:
#include <reg52.h>                   //包含文件
#define uint  unsigned int
char b[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,
          0xa1,0x86,0x8e,0x8c,0xc1,0xce,0x91,0x89,0xc7,0xff};    // 共陰極字符碼
//延時函數(shù),用于實現(xiàn)程序中的短暫延時,表示延時cnt個毫秒
void delay(unsigned int cnt)
    unsigned char i;
    while(cnt--)
        for(i=220;i>0;i--)
//鍵盤掃描程序
uchar keyboardscan(void)
      uchar sccode,recode;
      P1=0xf0;    //P1口附初值
      if((P1&0xf0)!=0xf0)//如果P1口電平不等于0xf0,表示有按鍵按下
          delay(20);    //延時20毫秒后再判斷,看是否還有按鍵按下,次步為軟件防抖
          if((P1&0xf0)!=0xf0)//繼續(xù)判斷是否有按鍵按下
              sccode=0xfe;  //進行逐行判斷
              while((sccode&0x10)!=0)
                  P1=sccode;
                  if((P1&0xf0)!=0xf0)
                      recode=(P1&0xf0|0x0f);
                      switch((~sccode)+(~recode))
                      {   // 下面是鍵盤的編碼識別
                          case 0x11:    return(1);    break;
                          case 0x21:  return(2);    break;
                          case 0x41:    return(3);     break;
                          case 0x81:    return(11);  break;//返回對應的鍵值0~15
                          case 0x12:    return(4);    break;
                          case 0x22:  return(5);    break;
                          case 0x42:  return(6);    break;
                          case 0x82:    return(12);   break;
                          case 0x14:    return(7);    break;
                          case 0x24:  return(8);    break;
                          case 0x44:  return(9);   break;
                          case 0x84:    return(13);  break;
                          case 0x18:    return(10);   break;
                          case 0x28:    return(15);   break;
                          case 0x48:  return(16);   break;
                          case 0x88:    return(14);  break;
                          default:break;
                sccode = (sccode<<1)|0x01;
     return(0xff); //如果沒有按鍵按下,則返回0xff
void output(uchar number)
P0=b[number/10];
P2=b[number%10];
int yunsuan(uchar a,uchar b,uchar c)
    switch(c)
        case 1:return(a/b);break;
        case 2:return(a*b);break;
        case 3:return(a-b);break;
        case 4:return(a+b);break;
void main(void)                 //主函數(shù)
    unsigned char n1,n2,key,index,a;
    n1=n2=index=0;
    P0=P2=b[0];
        key = keyboardscan();//鍵盤掃描,看是否有按鍵按下
        if(key != 0xff)//如果有按鍵按下,則key不再是0xff了,顯示該按鍵鍵值
            if(key<10)
                if(!index) n1=key%10;
                else n2=key%10;
                output(key%10);
            else if(key==15)
                n1=n2=index=0;
                output(0);
            else if(key==16)
                if(!index) output(n1);
                    a=yunsuan(n1,n2,index);
                    a=a%100;
                    output(a);
                    n1=a;
                    n2=index=0;
                if(index==0||n2==0) index=key-10;
                    a=a%100;
                    output(a);
                    n1=a;
                    n2=0;
                    index=key-10;
