RF1100SE單片機(jī)C8051F310程序
作者:huqin   來源:本站原創(chuàng)   點(diǎn)擊數(shù):  更新時(shí)間:2013年11月17日   【字體:
#include <c8051f310.h>
#include <stdio.h>
#include <math.h>
#include <Intrins.h>
#include <absacc.h>
#define BUSY SPI0CFG&0x80//SPI接口檢測(cè)
code uchar PaTabel[]={0x60,0x60,0x60,0x60,0x60,0x60,0x60,0x60};//配置功率
uchar send_buf[8]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};
 //要發(fā)送的有效數(shù)據(jù),其中第一個(gè)為數(shù)據(jù)的長(zhǎng)度
uchar rx_buf[8]={0}; //接收的數(shù)據(jù)緩存
//引腳定義*********************************************************************************
#define CSN_HIGH CSN=1
#define CSN_LOW CSN=0
sbit GDO0 =P0^6;
sbit CSN =P0^3;
sbit MISO =P0^1; //為了檢測(cè)是否穩(wěn)定
sbit c=P0^7;
#define WRITE_BURST      0x40 //連續(xù)寫入多個(gè)字節(jié),即為突發(fā)訪問
#define READ_SINGLE      0x80 //讀一個(gè)字節(jié)
#define READ_BURST       0xC0 //連續(xù)讀多個(gè)字節(jié)
#define BYTES_IN_RXFIFO     0x7F   //接收緩沖區(qū)的有效字節(jié)數(shù)
#define CRC_OK              0x80  //CRC校驗(yàn)通過位標(biāo)志
//RF1100SE寄存器地址
#define IOCFG2   0x00
#define IOCFG1   0x01
#define IOCFG0   0x02
#define FIFOTHR  0x03
#define SYNC1    0x04
#define SYNC0    0x05
#define PKTLEN   0x06
#define PKTCTRL1 0x07
#define PKTCTRL0 0x08
#define ADDR     0x09
#define CHANNR   0x0a
#define FSCTRL1  0x0b
#define FSCTRL0  0x0c
#define FREQ2    0x0d
#define FREQ1    0x0e
#define FREQ0    0x0f
//配置寄存器
#define MDMCFG4  0x10
#define MDMCFG3  0x11
#define MDMCFG2  0x12
#define MDMCFG1  0x13
#define MDMCFG0  0x14
#define DEVIATN  0x15
#define MCSM2    0x16
#define MCSM1    0x17
#define MCSM0    0x18
#define FOCCFG   0x19
#define BSCFG    0x1a
#define AGCTRL2  0x1b
#define AGCTRL1  0x1c
#define AGCTRL0  0x1d
#define WOREVT1  0x1e
#define WOREVT0  0x1f
#define WORCTRL  0x20
#define FREND1   0x21
#define FREND0   0x22
#define FSCAL3   0x23
#define FSCAL2   0x24
#define FSCAL1   0x25
#define FSCAL0   0x26
#define RCCTRL1  0x27
#define RCCTRL0  0x28
#define FSTEST   0x29
#define PTEST    0x2a
#define AGCTEST  0x2b
#define TEST2    0x2c
#define TEST1    0x2d
#define TEST0    0x2e
//狀態(tài)寄存器
#define PARTNUM  0x30
#define VERSION  0x31
#define FREQEST  0x32
#define LQI      0x33
#define RSSI     0x34
#define MARCSTATE 0x35
#define WORTIME1  0x36
#define WORTIME0  0x37
#define PKTSTATUS 0x38
#define VCOVCDAC  0x39
#define TXBYTES   0x3a
#define RXBYTES   0x3b
#define PATABLE   0x3e
#define TX_FIFO   0x3f
#define RX_FIFO   0x3f
//控制命令寄存器
#define SRES     0x30//重啟芯片
#define SFSTXON  0x31//開啟和校準(zhǔn)頻率合成器
#define SXOFF    0x32//關(guān)閉晶體振蕩器
#define SCAL     0x33//校準(zhǔn)頻率合成器并關(guān)斷
#define SRX      0x34//啟用RX
#define STX      0x35//空閑狀態(tài)時(shí)啟用TX
#define SIDLE    0x36//離開RX/TX關(guān)斷頻率合成器并離開電磁波激活模式
#define SAFC     0x37//運(yùn)行頻率合成器的AFC調(diào)節(jié)
#define SWOR     0x38//運(yùn)行自動(dòng)RX選舉序列
#define SPWD     0x39//當(dāng)CSn為高時(shí)進(jìn)入功率降低模式
#define SFRX     0x3a//沖洗RX_FIFO緩沖
#define SFTX     0x3b//沖洗TX_FIFO緩沖
#define SWORRST  0x3c//重新設(shè)置真實(shí)時(shí)間時(shí)鐘
#define SNOP     0x3d//附加:軟件擴(kuò)充為兩個(gè)字節(jié)
//函數(shù)聲明*********************************************************************************
void sysclk(void);
void pio(void);
void SPI(void);
void Interrupt_int(void);
void delay(uint i);
void dat_int(void);
uchar SPI_RW(uchar byte);        //用SPI讀寫一字節(jié)的數(shù)據(jù)
void SPI_WR_Strobe(uchar strobe);    //寫入濾波命令
void POWER_UP_RESET_CC1100(void);    //上電復(fù)位
uchar SPI_RW_Reg(uchar reg,uchar value);  //向寄存器寫一字節(jié)的數(shù)據(jù),同時(shí)返回狀態(tài)字
uchar SPI_Read_Reg(uchar reg);     //從寄存器讀一字節(jié)的數(shù)據(jù)
uchar SPI_Read_Buf(uchar reg,uchar *pBuf,uchar bytes); //從reg連續(xù)讀出bytes字節(jié)的數(shù)據(jù)
uchar SPI_RW_Buf(uchar reg,uchar *pBuf,uchar bytes); //向reg連續(xù)寫入bytes字節(jié)的數(shù)據(jù)
uchar RF1100CE_RxPacket(uchar *rx_buf,uchar *length); //接收函數(shù)
void  RF1100CE_TxPacket(uchar *tx_buf,uchar size);  //發(fā)送函數(shù)
void RF1100CE_Config(void);        //RF1100CE的配置函數(shù)
void main(void)   //主程序
{uchar sta=0;
 PCA0MD &= ~0x40;// 關(guān)閉看門狗
 pio();
 sysclk();
 dat_int();
 SPI();   //SPI0DAT是SPI的數(shù)據(jù)寄存器
 Interrupt_int();
 EA=0;
 POWER_UP_RESET_CC1100();
    RF1100CE_Config();     //RF1100CE的配置函數(shù)
 SPI_RW_Buf(PATABLE,PaTabel,8); //對(duì)設(shè)備進(jìn)行功率配置
 delay(6000);
  RF1100CE_TxPacket(send_buf,8);  //發(fā)送函數(shù)
 c=1;
delay(100);
  if(sta&0xff)
  CSN_LOW;
   SPI_RW(SFTX); //清除發(fā)送寄存器的值
    CSN_HIGH;
void dat_int(void)
CSN_LOW;
_nop_();
CSN_HIGH;
c=0;
void sysclk(void)    //內(nèi)部晶振
   OSCICL=0xb3; // 0xb3
   OSCICN=0xc2; //二分頻
   CLKSEL=0x00;
//延時(shí)子函數(shù)10us
void delay(uint i)
  while(i--);
uchar SPI_RW(uchar byte)   //用SPI讀寫一字節(jié)的數(shù)據(jù)
  uchar rbyte;
  SPI0DAT=byte;
 while(!SPIF);
  rbyte=SPI0DAT;
  SPIF=0;
  return rbyte;
void SPI_WR_Strobe(uchar strobe) //寫入濾波命令
    CSN_LOW;
    while (MISO);
    SPI_RW(strobe);
 while(MISO);
    CSN_HIGH;
void POWER_UP_RESET_CC1100(void) //上電復(fù)位
 CSN = 1;
 delay(10);
 CSN = 0;
 delay(10);
 CSN = 1;
 delay(500);
 SPI_WR_Strobe(SRES);     //復(fù)位CC1100
uchar SPI_RW_Reg(uchar reg,uchar value) //向寄存器寫一字節(jié)的數(shù)據(jù),同時(shí)返回狀態(tài)字
  uchar status;
  CSN_LOW;
  while(MISO);
  SPI0DAT=reg;
  while(!SPIF);
  status=SPI0DAT;
  SPIF=0;
  SPI0DAT=value;
  while(!SPIF);
  SPIF=0;
  CSN_HIGH;
  return(status);
uchar SPI_Read_Reg(uchar reg)  //從寄存器讀出一字節(jié)的數(shù)據(jù)
  uchar byte;
  CSN_LOW;
   while (MISO);
    SPI0DAT=reg|READ_SINGLE ;
   while(!SPIF);
  SPIF=0;
  SPI0DAT=0x00;
   while(!SPIF);
  byte=SPI0DAT;
  SPIF=0;
  CSN_HIGH;
  return byte;
uchar SPI_Read_Buf(uchar reg,uchar *pBuf,uchar bytes) //從reg讀出bytes字節(jié)的數(shù)據(jù)
  uchar status,byte_ctr;
  CSN_LOW;
 while (MISO);
   status=SPI_RW(reg|READ_BURST);
   for(byte_ctr=0;byte_ctr<bytes;byte_ctr++)
     pBuf[byte_ctr]=SPI_RW(0);
  CSN_HIGH;
  return status;
uchar SPI_RW_Buf(uchar reg,uchar *pBuf,uchar bytes)  //向reg寫入bytes字節(jié)的數(shù)據(jù)
  CSN_LOW;
 while (MISO);
 status=SPI_RW(reg|WRITE_BURST);
     SPI_RW(pBuf[byte_ctr]);
  CSN_HIGH;
  return status;
//接收函數(shù),接收返回1表示有數(shù)據(jù)收到
  uchar status[2];
  uchar packetLength;
  uchar i=(*length)*4;  // 具體多少要根據(jù)datarate和length來決定
 SPI_WR_Strobe(SRX);  //進(jìn)入接收模式指令
 delay(10);
 while (GDO0)
  delay(10);
  --i;
  if(i<1)
    return 0;
 if(SPI_Read_Reg(RXBYTES+READ_BURST) & BYTES_IN_RXFIFO) //如果接的字節(jié)數(shù)不為0
        packetLength = SPI_Read_Reg(RX_FIFO);//讀出第一個(gè)字節(jié),此字節(jié)為該幀數(shù)據(jù)長(zhǎng)度
        if (packetLength <= *length)   //如果所要的有效數(shù)據(jù)長(zhǎng)度小于等于接收到的數(shù)據(jù)包的長(zhǎng)度
            SPI_Read_Buf(RX_FIFO, rx_buf, packetLength); //讀出所有接收到的數(shù)據(jù)
            *length = packetLength;    //把接收數(shù)據(jù)長(zhǎng)度的修改為當(dāng)前數(shù)據(jù)的長(zhǎng)度
            SPI_Read_Buf(RX_FIFO, status, 2);  //讀出CRC校驗(yàn)位
   SPI_WR_Strobe(SFRX);    //清洗接收緩沖區(qū)
            return (status[1] & CRC_OK);  //如果校驗(yàn)成功返回接收成功
            return 0;
  return 0;
//發(fā)送函數(shù)
    SPI_RW_Reg(TX_FIFO, size);
    SPI_RW_Buf(TX_FIFO, tx_buf, size); //寫入要發(fā)送的數(shù)據(jù)
    SPI_WR_Strobe(STX);  //進(jìn)入發(fā)送模式發(fā)送數(shù)據(jù)
    while (!GDO0);
    while (GDO0);
 SPI_WR_Strobe(SFTX); //清除發(fā)送緩沖寄存器
 SPI_WR_Strobe(SIDLE);//進(jìn)入休眠模式
void RF1100CE_Config(void)   //RF1100CE的配置函數(shù)
   CSN_HIGH;//SPI復(fù)位
    SPI_RW_Reg(FSCTRL1, 0x08);//頻率合成器控制
    SPI_RW_Reg(FSCTRL0, 0x00);
    SPI_RW_Reg(FREQ2,   0x10);//頻率控制詞匯
    SPI_RW_Reg(FREQ1,   0xa7);
    SPI_RW_Reg(FREQ0,   0x62);
    SPI_RW_Reg(MDMCFG4, 0x5b);//調(diào)制器配置
    SPI_RW_Reg(MDMCFG3, 0xf8);
    SPI_RW_Reg(MDMCFG2, 0x03);
    SPI_RW_Reg(MDMCFG1, 0x22);
    SPI_RW_Reg(MDMCFG0, 0xf8);
    SPI_RW_Reg(CHANNR,  0x00);//信道數(shù)
 SPI_RW_Reg(DEVIATN, 0x47);
 SPI_RW_Reg(FREND1,  0xb6);
 SPI_RW_Reg(FREND0,  0x10);
 SPI_RW_Reg(MCSM0,   0x18);
 SPI_RW_Reg(FOCCFG,  0x1d);
 SPI_RW_Reg(BSCFG,   0x1c);
 SPI_RW_Reg(AGCTRL2, 0xc7);
 SPI_RW_Reg(AGCTRL1, 0x00);
 SPI_RW_Reg(AGCTRL0, 0xb2);
 SPI_RW_Reg(FSCAL3,   0xea);//頻率合成器校準(zhǔn)
 SPI_RW_Reg(FSCAL2,   0x2a);
 SPI_RW_Reg(FSCAL1,   0x00);
    SPI_RW_Reg(FSCAL0,   0x11);
    SPI_RW_Reg(FSTEST,   0x59);//產(chǎn)品測(cè)試
    SPI_RW_Reg(TEST2,    0x81);//不同的測(cè)試設(shè)置
    SPI_RW_Reg(TEST1,    0x35);
    SPI_RW_Reg(TEST0,    0x09);
    SPI_RW_Reg(IOCFG2,   0x0b);
    SPI_RW_Reg(IOCFG0,   0x06);//GDO輸出腳配置
    SPI_RW_Reg(PKTCTRL1, 0x04);//數(shù)據(jù)包自動(dòng)控制,無地址檢測(cè),包含兩個(gè)狀態(tài)字節(jié)
    SPI_RW_Reg(PKTCTRL0, 0x05);//開啟CC2400支持,采用可變長(zhǎng)度數(shù)據(jù)包
    SPI_RW_Reg(ADDR,     0x00);//設(shè)置地址
    SPI_RW_Reg(PKTLEN,   0x10);//有效允許最大數(shù)據(jù)包長(zhǎng)度16個(gè)字節(jié)
void SPI(void)  //SPI初始化
 SPI0CFG=0x40; //時(shí)鐘極性為低,即剛開始時(shí)鐘要為低電平
 SPI0CN=0x01; //0000 0001最后一位是SPI使能位 SPI工作在三線主方式
 SPI0CKR=0x2f; //SPI 時(shí)鐘頻率設(shè)置為150kHz 0x6f 0x2f
void Interrupt_int(void)   //中斷設(shè)定
   IE=0x40;  //允許SPI中斷請(qǐng)求
   IP=0x00;  //SPI為低優(yōu)先級(jí)
void pio(void)   // 端口配置
 P0MDIN=0xff;  //禁止模擬輸入,0為模擬,1為數(shù)字
 P0MDOUT=0xff; //0為開漏,1為推挽(ff)
 P0SKIP=0x00;
 P1MDIN=0xff;
 P1MDOUT=0xff; //低四位用于138
 P2MDIN=0xff;  //禁止模擬輸入,0為模擬,1為數(shù)字
 P2MDOUT=0xff; //0為開漏,1為推挽(ff)
 P3MDIN=0xff;
 P3MDOUT=0xff; //低四位用于138
 XBR0=0x02;
 XBR1=0x40;
