51單片機(jī)的七彩LED燈漸變調(diào)光調(diào)色程序
作者:文于鷹   來(lái)源:本站原創(chuàng)   點(diǎn)擊數(shù):  更新時(shí)間:2013年12月06日   【字體:
// Main.c
// Copyright (C) 2013 Shenyang JYXD.
//  WEN BO RUI
// Tool chain: KEIL Full  'c'
//#pragma CD OE DB SB       // Compilation directives
#include<reg2051.h>
#include<intrins.h>
#define uint  unsigned int
uint  Period;                 //Period刷新周期
uint  PWM;
uint  Pulse;         //脈沖個(gè)數(shù)
uchar Speed;         //速度變量
uchar count;
uint excount;
bit Gra;          //漸變/跳變總控制位
bit Gra7;          //七彩漸亮漸滅控制位
bit Gra3;          //紅綠藍(lán)漸亮漸滅控制位
bit BP;           //亮到暗,暗到亮轉(zhuǎn)換位
bit LEDdelay ;                                //LED定時(shí)到標(biāo)志位
sbit key1 = P3^1;           //花樣組合鍵1
sbit key2 = P3^0;             //花樣組合鍵2
sbit key3 = P3^5;             //速度組合鍵1
sbit key4 = P3^4;        //速度組合鍵2
uchar led1[12]={0x10,0x030,0x20,0x60,0x40,0x50,0x70,0x50,0x40,0x60,0x20,0x30};//紅、黃、綠、青、藍(lán)、粉、白、粉、藍(lán)、青、綠、黃
uchar led2[24]={0x10,0x00,0x30,0x00,0x20,0x00,0x60,0x00,0x40,0x00,0x50,0x00,
    0x70,0x00,0x50,0x00,0x40,0x00,0x60,0x00,0x20,0x00,0x30,0x00};
uchar led3[3]={0x10,0x20,0x40};     //紅、綠、藍(lán)
uchar ledcount,ledcount1;
//以下定義函數(shù)
// 1毫秒延時(shí)函數(shù)delayms();花樣及速度掃描函數(shù)keyscan();
/*void delayms(unsigned int ms)
    unsigned char i ;
    while(ms--)
        for(i = 0 ; i < 120 ; i++) ;
void Pattern1();             //花樣1函數(shù)--------->跳變無(wú)滅燈過(guò)程
void Pattern2();             //花樣2函數(shù)--------->跳變有滅燈過(guò)程
void Pattern34();
void keyscan()
 if((key4==1)&&(key3==1))  {Speed   = 20;Period = 25;}   //預(yù)設(shè)4種速度200MS
 if((key4==0)&&(key3==1))  {Speed   = 50;Period = 50;}    //500MS
 if((key4==1)&&(key3==0))  {Speed   = 100;Period = 100;}    //1S
 if((key4==0)&&(key3==0))  {Speed   = 150;Period = 200;}    //1.5S
 if((key2==1)&&(key1==1))  {ledcount1 = 0;Pattern1();}   //預(yù)設(shè)4種花樣
    if((key2==0)&&(key1==1))  {ledcount1 = 0;Pattern2();}
 if((key2==1)&&(key1==0))  {ledcount = 0;Gra3 = 1;Pattern34();}
 if((key2==0)&&(key1==0))  {ledcount = 0;Gra7 = 1;Pattern34();}
void value()
 if(Speed == 20) PWM = Pulse*8;
 if(Speed == 50) PWM = Pulse*4;         //脈沖個(gè)數(shù)
 if(Speed == 100)PWM = Pulse*2;
 if(Speed == 150)PWM = Pulse;
void Reset(void)
 unsigned char code rst[ ]={0xe4,0xc0,0xe0,0xc0,0xe0,0x32};
 (*((void (*)(void))(rst)))();
 _nop_ ();
 _nop_ ();
 _nop_ ();
 P1 = 0;
 TMOD = 0x11;             //11.0592M晶振的10ms定時(shí)初值(100分之一秒)
 TH0  = 0x0db;
 TL0  = 0x0ff;
 TH1  = 0x0ff;             //0.05ms(20000分之一秒)
 TL1  = 0x0D1;
 EA = 1;                       //開啟總中斷允許
 ET0 = 1;                     //允許T0定時(shí)器中斷
 ET1 = 1;                     //允許T1定時(shí)器中斷
 TR0 = 1;                    //開啟T0定時(shí)器
 EX0=1;               //開外部中斷0
  IT0=1;               //下降沿觸發(fā)
  keyscan();
//Pattern1() 花樣函數(shù)1-------------跳變無(wú)滅燈過(guò)程
void Pattern1()
 //keyscan();
 Gra = 0;              //跳變位=0
 if(LEDdelay)
   LEDdelay = 0;
   P1 = led1[ledcount];
   ledcount++;
   if(ledcount>11)
     ledcount = 0;
//Pattern2() 花樣函數(shù)2-------------跳變有滅燈過(guò)程
void Pattern2()
 //keyscan();
 Gra = 0;
 if(LEDdelay)
   LEDdelay = 0;
   P1 = led2[ledcount];
   ledcount++;
   if(ledcount>23)
     ledcount = 0;
//Pattern3() 花樣函數(shù)3-------------3彩漸變
/*void Pattern3()
 keyscan();
 if(Speed == 20) Period = 25;
 if(Speed == 50) Period = 50;
 if(Speed == 100)Period = 100;
 if(Speed == 150)Period = 200;
 Gra = 1;
 Gra3 = 1;
//Pattern4() 花樣函數(shù)4-------------7彩漸變
void Pattern34()
 Gra = 1;             //漸變位 = 1
// 定時(shí)器0中斷服務(wù)程序
void time0(void) interrupt 1
 TR1 =0;
 TF0 =0;
 TH0=0xdb;           //重新寫入初值
 TL0=0xff;
    if(!Gra)           //執(zhí)行跳變程序
   count ++;
   if(count > Speed)
     LEDdelay = 1;
     count = 0;
 if(Gra)
   TR1 = 1;         //開啟TR1;
   if(!BP)             //
      if(Gra7)
       P1 = led1[ledcount1];  //10ms到,亮相應(yīng)的LED
     if(Gra3)
       P1 = led3[ledcount1];  //10ms到,亮相應(yīng)的LED
     Pulse++;
     value();
     if(Pulse >= Period)
       Pulse = Period;
       BP = 1;      //一個(gè)周期完成轉(zhuǎn)換模式
   if(BP)
     if(Gra7)
     if(Gra3)
     value();
     Pulse--;       //脈沖個(gè)數(shù)
     if(Pulse == 0)
       Pulse = 0;
       BP = 0;      //一個(gè)周期完成轉(zhuǎn)換模式
       ledcount1++;
       if(Gra7)
        if(ledcount1 > 11)
          ledcount1 = 0;
         Gra7 = 0;
       if(Gra3)
        if(ledcount1 > 2)
          ledcount1 = 0;
         Gra3 = 0;
// 定時(shí)器1中斷服務(wù)程序
void timer1() interrupt 3
 PWM --;
 TH1  = 0xff;         //0.05ms(20000分之一秒)
 TL1  = 0xD1;
 if(PWM == 0)
   P1 = 0;
   TR1 = 0;
// 外部中斷0中斷服務(wù)程序 下降沿觸發(fā)
void extern0(void) interrupt 0
 IE0 = 0;    // 清標(biāo)志位
 excount++;
 if(excount>50)      // 50大約3秒
   EA = 0;
   //P1_5 = 1;
   excount = 0;
   Reset();
