實(shí)現(xiàn)LED點(diǎn)陣左右移動(dòng)的程序
作者:佚名   來(lái)源:不詳   點(diǎn)擊數(shù):  更新時(shí)間:2014年08月17日   【字體:
#include<reg52.h>
unsigned char code tab[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};//定義掃描列
unsigned char code digittab[]={
0x00,0x00,0x00,0x00,0x00,0x00,0x3e,0x41,0x41,0x41,0x3e,0x00, //0
0x00,0x00,0x00,0x00,0x21,0x7f,0x01,0x00, //1
0x00,0x00,0x27,0x45,0x45,0x45,0x39,0x00, //2
0x00,0x00,0x22,0x49,0x49,0x49,0x36,0x00, //3
0x00,0x00,0x0c,0x14,0x24,0x7f,0x04,0x00, //4
0x00,0x00,0x72,0x51,0x51,0x51,0x4e,0x00, //5
0x00,0x00,0x3e,0x49,0x49,0x49,0x26,0x00, //6
0x00,0x00,0x40,0x40,0x40,0x4f,0x70,0x00, //7
0x00,0x00,0x36,0x49,0x49,0x49,0x36,0x00, //8
0x00,0x00,0x32,0x49,0x49,0x49,0x3e,0x00, //9
0x00,0x00,0x7F,0x48,0x48,0x30,0x00,0x00, //P
0x00,0x00,0x7F,0x48,0x4C,0x73,0x00,0x00, //R
0x00,0x00,0x7F,0x49,0x49,0x49,0x00,0x00, //E
0x00,0x00,0x3E,0x41,0x41,0x62,0x00,0x00, //C
0x00,0x00,0x7F,0x08,0x08,0x7F,0x00,0x00, //H
0x00,0x00,0x00,0xFF,0xFF,0x00,0x00,0x00, //I
0x00,0x7F,0x10,0x08,0x04,0x7F,0x00,0x00, //N
0x7C,0x48,0x48,0xFF,0x48,0x48,0x7C,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00 //中
};//要顯示的字符
void delay(int t)
 int i;
 for(i=1;i<=t;i++);
}//延時(shí)函數(shù)
void main(void)
 int a,b,c;
  for(a=0;a<144;a++)  //所有要顯示的列數(shù)
    for(b=0;b<50;b++)//控制移動(dòng)速度
    P2=0xfe;      ///最右邊的列先顯示,程序定義向左移動(dòng)
    for(c=0;c<8;c++)//稍加修改可以變成向右移動(dòng)
    {                //例中P2接LED點(diǎn)陣陽(yáng)極,P0接陰極
     P0=digittab[a+c];//同時(shí)顯示8列
     delay(100);
     P0=0x00;   //禁止掃描列變換時(shí),其它列亮!
     P2=P2<<1|P2>>7;
注:對(duì)本程序稍加修改可以變成LED8段數(shù)碼管左右移動(dòng)程序。
