#include "msp430G2553.h"
int tab[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
int temp;
//毫秒延遲函數(shù)
void delay(int ms)
int i;
while(ms--)
for(i=0;i<120;i++);
//納米延遲函數(shù)
void delayns(int ns)
while(ns--);
void display(temp)//現(xiàn)實(shí)位置P2.0=SH;P2.1=ST;P2,2=DS
int k,temp1,temp2;
for(k=7;k>=0;k--)
temp1=1<<k;
temp2=temp & temp1;
if(temp2==temp1)
P2OUT |=BIT2;
P2OUT &=~BIT2;
P2OUT &=~BIT0;
delayns(10);
P2OUT |=BIT0;
P2OUT &=~BIT1;
delayns(10);
P2OUT |=BIT1;
int main( void )
// Stop watchdog timer to prevent time out reset
WDTCTL = WDTPW + WDTHOLD;
P2DIR |=0x07;
int m,time,temp;
m=P1IN;
//顯示
temp=tab[(2*m)%10];//個(gè)位
display(temp);
temp=tab[(2*m)/10];//十位
display(temp);
//脈寬
if(m<=9) time +=10;
if(m>15) time -=30;
P2OUT |=BIT3;
delay(time);
P2OUT &=~BIT3;
delay(20);
#include"reg51.h"
int temp;
//毫秒延遲函數(shù)
void delay(int ms)
int i;
while(ms--)
for(i=0;i<120;i++);
//納米延遲函數(shù)
while(ns--);
int k,temp1,temp2;
for(k=7;k>=0;k--)
temp1=1<<k;
temp2=temp & temp1;
if(temp2==temp1)
P2OUT |=BIT2;
P2OUT &=~BIT2;
P2OUT &=~BIT0;
delayns(10);
P2OUT |=BIT0;
P2OUT &=~BIT1;
delayns(10);
P2OUT |=BIT1;
int main( void )
P2DIR |=0x07;
int m,time,temp;
m=P1IN;
//顯示
display(temp);
display(temp);
//脈寬
if(m<=9) time +=10;
if(m>15) time -=30;
P2OUT |=BIT3;
delay(time);
P2OUT &=~BIT3;
delay(20);
#include"reg51.h"
sbit DS_595= P1^0;
sbit CT_595= P1^1;
sbit CH_595= P1^2;
int temp;
void delay(int ms)
int i;
while(ms--)
for(i=0;i<120;i++);
while(ns--);
void WR_595(void)
int k,temp1,temp2;
for(k=7;k>=0;k--)
temp1=1<<k;
temp2=temp & temp1;
if(temp2==temp1)
DS_595=1;
DS_595=0;
CH_595=0;
delayns(10);
CH_595=1;
int m;
for(m=0;m<10000;m++)
temp=tab[m/1000];
WR_595();
CT_595=0;
delayns(10);
CT_595=1;
temp=tab[(m%1000)/100];
WR_595();
CT_595=0;
delayns(10);
CT_595=1;
temp=tab[((m%1000)%100)/10];
WR_595();
CT_595=0;
delayns(10);
CT_595=1;
temp=tab[((m%1000)%100)%10];
WR_595();
CT_595=0;
delayns(10);
CT_595=1;
delay(200);
串行通信時(shí)鐘程序
串行通信時(shí)鐘程序
#include"reg51.h"
sbit DS_595= P1^0;
sbit CT_595= P1^1;
sbit CH_595= P1^2;
sbit POT =P1^3;
int temp;
void delay(int ms)
int i;
while(ms--)
for(i=0;i<120;i++);
while(ns--);
void WR_595(void)
int k,temp1,temp2;
for(k=7;k>=0;k--)
temp1=1<<k;
temp2=temp & temp1;
if(temp2==temp1)
DS_595=1;
DS_595=0;
CH_595=0;
delayns(10);
CH_595=1;
int hour,min,sec;
sec++;
if(sec==60)
sec=0;
min++;
if(min==60)
min=0;hour++;
if(hour==24)hour=0;
temp=tab[hour/10];
WR_595();
CT_595=0;
delayns(2);
CT_595=1;
temp=tab[hour%10];//245959
WR_595();
CT_595=0;
delayns(2);
CT_595=1;
temp=tab[min/10];//5900
WR_595();
CT_595=0;
delayns(2);
CT_595=1;
temp=tab[min%10];
WR_595();
CT_595=0;
delayns(2);
CT_595=1;
temp=tab[sec/10];
WR_595();
CT_595=0;
delayns(2);
CT_595=1;
temp=tab[sec%10];
WR_595();
CT_595=0;
delayns(2);
CT_595=1;
delay(300);
POT=~POT;
delay(300);
POT=~POT;
74HC595芯片是一種串入并出的芯片,在電子顯示屏制作當(dāng)中有廣泛的應(yīng)用。
74HC595是8位串行輸入/輸出或者并行輸出移位寄存器,具有高阻、關(guān)、斷狀態(tài)。
三態(tài)。特點(diǎn) 8位串行輸入 8位串行或并行輸出 存儲(chǔ)狀態(tài)寄存器,三種狀態(tài) 輸出寄存器可以直接清除 100MHz的移位頻率 輸出能力 并行輸出,總線驅(qū)動(dòng) 串行輸出;
標(biāo)準(zhǔn) 中等規(guī)模集成電路應(yīng)用 串行到并行的數(shù)據(jù)轉(zhuǎn)換 Remote control holding register. 描述 595是告訴的硅結(jié)構(gòu)的CMOS器件, 兼容低電壓TTL電路,遵守JEDEC標(biāo)準(zhǔn)。
595是具有8位移位寄存器和一個(gè)存儲(chǔ)器,三態(tài)輸出功能。 移位寄存器和存儲(chǔ)器是分別的時(shí)鐘。數(shù)據(jù)在SCHcp的上升沿輸入,在STcp的上升沿進(jìn)入的存儲(chǔ)寄存器中去。如果兩個(gè)時(shí)鐘連在一起,則移位寄存器總是比存儲(chǔ)寄存器早一個(gè)脈沖。 移位寄存器有一個(gè)串行移位輸入(Ds),和一個(gè)串行輸出(Q7’),和一個(gè)異步的低電平復(fù)位,存儲(chǔ)寄存器有一個(gè)并行8位的,具備三態(tài)的總線輸出,當(dāng)使能OE時(shí)(為低電平),存儲(chǔ)寄存器的數(shù)據(jù)輸出到總線。
CPD決定動(dòng)態(tài)的能耗, PD=CPD×VCC×f1+∑(CL×VCC2×f0) F1=輸入頻率,CL=輸出電容 f0=輸出頻率(MHz) Vcc=電源電壓 引腳說(shuō)明符號(hào)引腳描述
內(nèi)部結(jié)構(gòu)
結(jié)合引腳說(shuō)明就能很快理解 595的工作情況
74HC595引腳圖,管腳圖
______________________
QB--|1 16|--Vcc
QC--|2 15|--QA
QD--|3 14|--SI(DS)
QE--|4 13|--/G(/OE)
QF--|5 12|--RCK(ST_CP)
QG--|6 11|--SRCK(SH_CP)
QH--|7 10|--/SRCLR(/MR)
GND- |8 9|--QH'
________________________
74595的數(shù)據(jù)端:
QA--QH: 八位并行輸出端,可以直接控制數(shù)碼管的8個(gè)段。
QH': 級(jí)聯(lián)輸出端。我將它接下一個(gè)595的SI端。
SI: 串行數(shù)據(jù)輸入端。
74595的控制端說(shuō)明:
/SRCLR(10腳): 低點(diǎn)平時(shí)將移位寄存器的數(shù)據(jù)清零。通常我將它接Vcc。
SRCK(11腳):上升沿時(shí)數(shù)據(jù)寄存器的數(shù)據(jù)移位。QA-->QB-->QC-->...-->QH;下降沿移位寄存器數(shù)據(jù)不變。(脈沖寬度:5V時(shí),大于幾十納秒就行了。我通常都選微秒級(jí))
RCK(12腳):上升沿時(shí)移位寄存器的數(shù)據(jù)進(jìn)入數(shù)據(jù)存儲(chǔ)寄存器,下降沿時(shí)存儲(chǔ)寄存器數(shù)據(jù)不變。(通常我將RCK置為低電平,) 當(dāng)移位結(jié)束后,在RCK端產(chǎn)生一個(gè)正脈沖(5V時(shí),大于幾十納秒就行了。我通常都選微秒級(jí)),更新顯示數(shù)據(jù)。
/G(13腳): 高電平時(shí)禁止輸出(高阻態(tài))。如果單片機(jī)的引腳不緊張,用一個(gè)引腳控制它,可以方便地產(chǎn)生閃爍和熄滅效果。比通過(guò)數(shù)據(jù)端移位控制要省時(shí)省力。
注:
1)74164和74595功能相仿,都是8位串行輸入轉(zhuǎn)并行輸出移位寄存器。74164的驅(qū)動(dòng)電流(25mA)比74595(35mA)的要小,14腳封裝,體積也小一些。
2)74595的主要優(yōu)點(diǎn)是具有數(shù)據(jù)存儲(chǔ)寄存器,在移位的過(guò)程中,輸出端的數(shù)據(jù)可以保持不變。這在串行速度慢的場(chǎng)合很有用處,數(shù)碼管沒(méi)有閃爍感。
與164只有數(shù)據(jù)清零端相比,595還多有輸出端時(shí)能/禁止控制端,可以使輸出為高阻態(tài)。
3)595是串入并出帶有鎖存功能移位寄存器,它的使用方法很簡(jiǎn)單,在正常使用時(shí)SCLR為高電平, G為低電平。從SER每輸入一位數(shù)據(jù),串行輸595是串入并出帶有鎖存功能移位寄存器,它的使用方法很簡(jiǎn)單,如下面的真值表,在正常使用時(shí)SCLR為高電平, G為低電平。從SER每輸入一位數(shù)據(jù),串行輸入時(shí)鐘SCK上升沿有效一次,直到八位數(shù)據(jù)輸入完畢,輸出時(shí)鐘上升沿有效一次,此時(shí),輸入的數(shù)據(jù)就被送到了輸出端。入時(shí)鐘SCK上升沿有效一次,直到八位數(shù)據(jù)輸入完畢,輸出時(shí)鐘上升沿有效一次,此時(shí),輸入的數(shù)據(jù)就被送到了輸出端。
其實(shí),看了這么多595的資料,覺(jué)得沒(méi)什么難的,關(guān)鍵是看懂其時(shí)序圖,說(shuō)到底,就是下面三步(引用):
第一步:目的:將要準(zhǔn)備輸入的位數(shù)據(jù)移入74HC595數(shù)據(jù)輸入端上。
方法:送位數(shù)據(jù)到 P1.0。
第二步:目的:將位數(shù)據(jù)逐位移入74HC595,即數(shù)據(jù)串入
方法:P1.2產(chǎn)生一上升沿,將P1.0上的數(shù)據(jù)移入74HC595中.從低到高。
第三步:目的:并行輸出數(shù)據(jù)。即數(shù)據(jù)并出
方法:P1.1產(chǎn)生一上升沿,將由P1.0上已移入數(shù)據(jù)寄存器中的數(shù)據(jù)
送入到輸出鎖存器。
送入到輸出鎖存器。
說(shuō)明: 從上可分析:從P1.2產(chǎn)生一上升沿(移入數(shù)據(jù))和P1.1產(chǎn)生一上升沿
(輸出數(shù)據(jù))是二個(gè)獨(dú)立過(guò)程,實(shí)際應(yīng)用時(shí)互不干擾。即可輸出數(shù)據(jù)的
同時(shí)移入數(shù)據(jù)。
而具體編程方法為
如:R0中存放3FH,LED數(shù)碼管顯示“0”
;*****接口定義:
DS_595 EQU P1.0 ;串行數(shù)據(jù)輸入(595-14)
CH_595 EQU P1.2 ;移位時(shí)鐘脈沖(595-11)
CT_595 EQU P1.1 ;輸出鎖存器控制脈沖(595-12)
;*****將移位寄存器內(nèi)的數(shù)據(jù)鎖存到輸出寄存器并顯示
OUT_595:
CALL WR_595 ;調(diào)用移位寄存器接收一個(gè)字節(jié)數(shù)據(jù)子程序
CLR CT_595 ;拉低鎖存器控制脈沖
NOP
NOP
SETB CT_595 ;上升沿將數(shù)據(jù)送到輸出鎖存器,LED數(shù)碼管顯示“0”
NOP
NOP
CLR CT_595
RET
OUT_595:
NOP
NOP
NOP
NOP
CLR CT_595
RET
;*****移位寄存器接收一個(gè)字節(jié)(如3FH)數(shù)據(jù)子程序
WR_595:
MOV R4,#08H ;一個(gè)字節(jié)數(shù)據(jù)(8位)
MOV A,R0 ;R0中存放要送入的數(shù)據(jù)3FH
LOOP:
;第一步:準(zhǔn)備移入74HC595數(shù)據(jù)
RLC A ;數(shù)據(jù)移位
MOV DS_595,C ;送數(shù)據(jù)到串行數(shù)據(jù)輸入端上(P1.0)
;第二步:產(chǎn)生一上升沿將數(shù)據(jù)移入74HC595
CLR CH_595 ;拉低移位時(shí)鐘
NOP
NOP
setb CH_595 ;上升沿發(fā)生移位(移入一數(shù)據(jù))
WR_595:
LOOP:
NOP
NOP
DJNZ R4,LOOP ;一個(gè)字節(jié)數(shù)據(jù)沒(méi)移完繼續(xù)
RET
RET
而其級(jí)聯(lián)的應(yīng)用
74HC595主要應(yīng)用于點(diǎn)陣屏,以16*16點(diǎn)陣為例:傳送一行共二個(gè)字節(jié)(16位)
如:發(fā)送的是06H和3FH。其方法是:
1.先送數(shù)據(jù)3FH,后送06H。
2.通過(guò)級(jí)聯(lián)串行輸入后,3FH在IC2內(nèi),06H在IC1內(nèi)。應(yīng)用如圖二
3.接著送鎖存時(shí)鐘,數(shù)據(jù)被鎖存并出現(xiàn)在IC1和IC2的并行輸出口上顯示。
編程方法:
數(shù)據(jù)在30H和31H中
;MOV 30H,#3FH
;MOV 31H,#06H
;*****接口定義:
;*****串行輸入16位數(shù)據(jù)
MOV R0,30H
CALL WR_595 ;串行輸入3FH
nop
NOP
MOV R0,31H
CALL WR_595 ;串行輸入06H
NOP
NOP
SETB CT_595 ;上升沿將數(shù)據(jù)送到輸出鎖存器,顯示
NOP
NOP
CLR CT_595
RET
MOV R0,30H
nop
NOP
MOV R0,31H
NOP
NOP
NOP
NOP
CLR CT_595
RET
MC74HC595A包括一個(gè)8位移位寄存器和一個(gè)8位D型鎖存器和三態(tài)并行輸出。移位寄存器接受串行數(shù)據(jù)并提供串行輸出。移位寄存器也提供并行數(shù)據(jù)輸出和8位鎖存器。移位寄存器和鎖存器都有獨(dú)立的時(shí)鐘輸入。這個(gè)IC還具有異步復(fù)位的功能。
#include"reg51.h"
sbit DS_595= P1^0;
sbit CT_595= P1^1;
sbit CH_595= P1^2;
int temp;
void delay(int ms)
int i;
while(ms--)
for(i=0;i<120;i++);
void WR_595(void)
int k,temp1,temp2;
for(k=7;k>=0;k--)
temp1=1<<k;
temp2=temp & temp1;
if(temp2==temp1)
DS_595=1;
DS_595=0;
CH_595=0;
delay(2);
CH_595=1;
int m;
for(m=0;m<16;m++)
temp=tab[m];
WR_595();
CT_595=0;
delay(2);
CT_595=1;
delay(2);
CT_595=0;
delay(500);
#include"reg51.h"
sbit DS_595= P1^0;
sbit CT_595= P1^1;
sbit CH_595= P1^2;
sbit AA=P1^3;
sbit BB=P1^4;
int yu[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
int temp,court,gg,ss,m,n,j;
void delay(int ms)
int i;
while(ms--)
for(i=0;i<120;i++);
void WR_595(void)
int k,temp1,temp2;
for(k=7;k>=0;k--)
temp1=1<<k;
temp2=temp & temp1;
if(temp2==temp1)
DS_595=1;
DS_595=0;
CH_595=0;
delay(2);
CH_595=1;
void display(m)
temp=yu[m];
WR_595();
CT_595=0;
delay(1);
CT_595=1;
delay(1);
for(m=0;m<1000;m++)
n=m/1000;
BB=1;AA=1;
P2=0x80;
display(n);
n=(m%1000)/100;
BB=1;AA=0; P2=0x40;
display(n);
n=((m%1000)%100)/10;
BB=0;AA=1; P2=0x20;
display(n);
n=m%10;
AA=0;BB=0; P2=0x01;
display(n);
delay(600);
