當(dāng)前位置:單片機(jī)教程網(wǎng) >> MCU設(shè)計實例 >> 瀏覽文章
單片機(jī)驅(qū)動16*16點(diǎn)陣LED漢字顯示c51程序
作者:佚名   來源:本站原創(chuàng)   點(diǎn)擊數(shù):  更新時間:2008年10月13日   【字體:
//******* 單片機(jī)驅(qū)動16*16點(diǎn)陣LED漢字顯示c51程序  *******
//******* 作者:http://www.torrancerestoration.com  *******
//晶振12MHz
//P1.0~P1.3接74154行掃描
//P3.0、P3.1接74164串轉(zhuǎn)并
#include < reg51.h>
uchar int_t;
uchar i;
uchar j;
uchar count=2; //2個字
uint k=0;
void t0_int() interrupt 1
 TL0=0x18;
 TH0=0x1C;
 int_t++;
 if(int_t==2) //移動速度2ms
  int_t=0;
  k=k+2;
  if(k==count*32)
  k=0;
void delay(uint dt)//2字節(jié)
 uchar bt;//1字節(jié)
 for (;dt;dt--)
  for (bt=0;bt<255;bt++);
void serial_send(uchar dat)
 SCON=0x00;
 SBUF=~dat;
 while(1){ if(TI) {TI=0;break;} }
unsigned char code hzdot[64] = {
/*測   CB2E2 */
0x40,0x02,0x27,0xC2,0x24,0x42,0x84,0x52,0x45,0x52,0x55,0x52,0x15,0x52,0x25,0x52,
0x25,0x52,0x25,0x52,0xC5,0x52,0x41,0x02,0x42,0x82,0x42,0x42,0x44,0x4A,0x48,0x04,
/*試   CCAD4 */
0x00,0x20,0x40,0x28,0x20,0x24,0x30,0x24,0x27,0xFE,0x00,0x20,0xE0,0x20,0x27,0xE0,
0x21,0x20,0x21,0x10,0x21,0x10,0x21,0x0A,0x29,0xCA,0x36,0x06,0x20,0x02,0x00,0x00
void display()
 j=k;
 for(i=0;i<16;i++)
  P1=i;
  serial_send(hzdot[j]);
  j++;
  j++;
  if(j==count*32)
  j=0;
  delay(1);
 SCON=0x00;
 TMOD=0x01;
 IE|=0x82;
 TL0=0x18;
 TH0=0x1C;
 delay(100);
 TR0=1; //啟動T0定時器
 for(;;)
 display();
