專注電子技術(shù)學習與研究
單片機電子音響設計
作者:佚名   來源:本站原創(chuàng)   點擊數(shù):  更新時間:2007年06月28日   【字體:
匯編程序 之單片機電子音響設計控制程序
   <!--StartFragment-->  VARIABLES DECLARATION      ;
;SYS_OPTION EQU 2FH
CONST_1 EQU 05H
; bit[7]=0  the program use for M62429
; =1  the program use for PT2322
; Variable for IR Receiver ---->>>>
IR_COUNTER EQU 00H
IR_DATA2 EQU 01H ; IR_DATA2 is received befor IR_DATA1
IR_DATA1 EQU 02H
BIT_FLAG EQU 20H
SIGN_F BIT BIT_FLAG.0
CONTINUE_F BIT BIT_FLAG.1
IRDATA_SPEED EQU 03H ; Adjust the speed of ir receiver
IRDATA_HOLD EQU 04H ; if timer-out, then clr IR data
; Variable for LED display ----->>>>
COUNTER_1     EQU 06H
COUNTER_2     EQU 07H
DISPLAY_COMA    EQU 47H
DISPLAY_COMB    EQU 48H
;DISPLAY_COMC    EQU 49H
DISPLAY_COM0 EQU 08H ; one
DISPLAY_COM1 EQU 09H ; ten
DISPLAY_COM2 EQU 0AH ; LED display
;   bit[7]=XXXX bit=Subwoof bit[5]=Surround bit[4]=Center
;   bit[3]=Front bit[2]=Volume bit[1]=Mute bit[0]=ON/St-by
;PORT_EXT EQU 0BH ; for 74ALS373
; bit[7]=power bit=Mute bit[5]=By pass bit[4:3]=DVD/CD/TAPE
; bit[5:3]=111  DVD (Bypass on)
;   =010  CD (bypass off)
;   =001  TYPE (bypass off)
; if bit[2]=1 :send data to IC1 (FL & FR)
; if bit[1]=1 :send data to IC2 (CEN & SUB)
; if bit[0]=1 :send data to IC3 (SL & SR)
COM0_FLAG BIT BIT_FLAG.2
COM1_FLAG BIT BIT_FLAG.3
; Variable for transmitte data to M62429P ---->>>>
; M62429 data format: (xx xxxxxxx xx  :total 11 bits)
; bit[1:0]=11,
; bit[8:2]=Volume,
; bit[9]=0:send to both channel at a time  =1:send a channel data at a time
; bit[10]=0:send data to 1st channel    =1:send data to 2nd channel
; the data bit[10] will send out first
VOL_MAS     EQU 2CH
VOL_FL EQU 4AH
VOL_FR EQU 4BH
VOL_CEN EQU 4CH
VOL_SUB EQU 4DH
VOL_SL EQU 4EH
VOL_SR EQU 4FH
DVD_CD_F BIT BIT_FLAG.5 ; =0 DVD
MUTE_ENABLE BIT BIT_FLAG.6 ; =1 MUTE
MODE_FLAG EQU 32H
; bit[4]= the key flag for "SUB"
; bit[3]= the key flag for "CEN"
; bit[2]= the key flag for "SURRL"
; bit[1]= the key flag for "FRONT"
; bit[0]= the key flag for "VOL"
; Variable for transmitte data to pt2322 & PT2323 ---->>>>
SEND__D1 EQU 30H
SEND__D2 EQU 31H
SEND_FLAG EQU 21H ; share with M62429
;for PT2322:
; bit[7:4]  Roll flag for byte send
; bit[3:0]  Counter the times of DATA_SEND
;for M62429:
; bit[0]= bit[9] of m62429p
; bit[1]= No used
; bit[2]= bit[10] of m62429
; bit[4:3]= No used
; bit[7:5] Roll flag for send data to m62429
REPLACE_VAR EQU 22H ; share with M62429
; the value will ( >=40 & <=123 ) for M62429 data send
ADDR_FLAG BIT BIT_FLAG.4 ; 0:Send to PT2322  1:Send to PT2323
; --------------Var for PT2322-----------
; PT2322 Chip Address: 88H
; PT2322 COMMAND: 0xH,8xH:No function
; 1xH:Front_L 2xH:Front_R 3xH:Center 4xH:Rear_L 5xH:Rear_R
; 6xH:Subwoof 7xH:Fun_Sel 9xH:Bass AxH:Middle BxH:Treble
; CxH:Input_SW DxH:VOL_L ExH:VOL_H FxH:sys_reset
;VOLUME EQU 40H
; Main volume (-79dB to 0dB step 1dB)
;FRONT_REAR EQU 41H
; Front & Rear volume (-15dB to 0dB step 1dB)
;CENTER_SUB EQU 42H
; Center & Subwoof volume (-15dB to 0dB step 1dB)
;TREBLE_BAS EQU 43H
; Treble & Bass adjust (-14dB to +14dB step 2dB)
;FUNSEL_MID EQU 44H
; Function select(Mute,3D,Tone,X),Middle tone adjust (-14dB to +14dB step 2dB)
; --------------Var for PT2323-------------
; PT2323 Chip Address: 94H
; PT2323 COMMAND:
; CxH:Input Switch FxH:Mute for any channel
; D0H/D1H:Surround en/dis 90H:Mixed Channel ON
;INPUT_SW EQU 45H
; bit[3:0]=0111  6-Ch Input
;    1000  Input Stereo Group 4
;    1001  Input Stereo Group 3
;    1010  Input Stereo Group 2
;    1011  Input Stereo Group 1
;MUTE_2323 EQU 46H
; bit[3:0]=0000  FL Mute DIS =0001  FL Mute EN
;   =0010  FR Mute DIS =0011  FR Mute EN
;   =0100  CT Mute DIS =0101  CT Mute EN
;   =0110  SUB Mute DIS =0111  SUB Mute EN
;   =1000  SL Mute DIS =1001  SL Mute EN
;   =1010  SR Mute DIS =1011  SR Mute EN
;   =1110  All Mute DIS =1111  All Mute EN
KEY_FLAG EQU 23H
; bit[7]= a key action need to process
; bit= a key action is processing
; bit[5]= the key flag for "POWER" key
; bit[4]= the key flag for "MUTE" key
; bit[3]= the key flag for "MODE" key
; bit[2]= the key flag for "CHANNEL" key
; bit[1]= the key flag for "UP" key
; bit[0]= the key flag for "DOWN" key
KEY_POWER EQU 24H
KEY_MUTE EQU 25H
KEY_CHANNEL EQU 26H
KEY_MODE EQU 27H
KEY_UP EQU 28H
KEY_DOWN EQU 29H
MODE_1      EQU 51H
DELAY_A     EQU 2DH
DELAY_B     EQU 2EH
DELAY_H EQU 2BH
DELAY_L EQU 2AH
;      PROGRAM STARTS      ;
ORG 0000H ; INITIAL RESET
JMP START
ORG 0003H ; INT0
PUSH ACC
PUSH PSW
JMP IR_RECEIVE
ORG 000BH ; TIMER0
PUSH ACC
PUSH PSW
JMP IR_RECEIVE2
ORG 0013H ; INT1
PUSH ACC
PUSH PSW
JMP SCAN_KEY
ORG 001BH ; TIMER1
PUSH ACC
PUSH PSW
JMP LED_DISPLAY
ORG 0023H ; S_PORT
PUSH ACC
PUSH PSW
JMP INT_RETURN
INT_RETURN:
POP PSW
POP ACC
RETI
;      PROGRAM STARTS      ;
ORG 030H
START:
MOV KEY_FLAG,#00
MOV KEY_POWER,#00
MOV KEY_MUTE,#00
MOV KEY_CHANNEL,#00
MOV KEY_MODE,#00
MOV KEY_UP,#00
MOV KEY_DOWN,#00
; MOV SYS_OPTION,#00
MOV IR_COUNTER,#00
MOV IR_DATA1,#0FFH
MOV IR_DATA2,#0FFH
MOV IRDATA_SPEED,#00
MOV BIT_FLAG,#00
MOV DISPLAY_COM0,#00
MOV DISPLAY_COM1,#00
MOV DISPLAY_COM2,#0FBH
;   MOV DISPLAY_COMC,#00
; MOV PORT_EXT,#0B8H
SETB DVD_CD_F
CLR MUTE_ENABLE
MOV MODE_FLAG,#00
START2:
; A, B, PSW, SP, DPTR, P0, P1, P2, P3, IP, IE, TMOD, TCON,
; TH0, TL0, TH1, TL1, SCON, SBUF, PCON
; MOV SCON,#00H ; SM0,SM1,SM2,REN, TB8,RB8,TI,RI
; MOV PCON,#00H ; SMOD,X,X,X, X,X,Idle,PD
; ANL PSW,#0E7H ; CY,AC,F0,RS1, RS0,OV,X,P
; MOV TH0,#00H
; MOV TL0,#00H
; MOV TMOD,#11H ; GATE,C/T,M1,M0(Tm1), GATE,C/T,M1,M0(Tm0)
; MOV TCON,#10H ; TF1,TR1,TF0,TR0, IE1,IT1,IE0,IT0
; MOV IE,#84H ; EA,X,X,ES, ET1,EX1,ET0,EX0
; MOV IP,#00H ; X,X,X,PS, PT1,PX1,PT0,PX0
MOV SP,#6AH
MOV PSW,#00
MOV IP,#1FH
MOV TMOD,#11H
MOV TH1,#0EDH
MOV TL1,#078H
MOV TCON,#45H ; enable timer1 counter
MOV IE,#0BH ; enable TM0 & TM1 & INT0 interrupt
MOV P3,#0BCH ; 1011 1100
MOV P1,#0FFH
MOV KEY_FLAG,#40H
  CALL DELAY_300MM
    MOV  SEND__D1,#0C0H
    MOV  SEND__D2,#0C0H
    CALL SEND_CV2653
MOV VOL_SL,#39
MOV VOL_SR,#39
MOV VOL_FL,#39
MOV VOL_FR,#39
MOV VOL_CEN,#39
MOV VOL_SUB,#39
MOV VOL_MAS,#39
    JMP DPR2653_VOLUME_HI
MAIN_END:
    nop
nop
nop
; MOV SEND__D1,COUNTER_1
; CALL SEND_CV2653
; ORL     PCON,#02H
JB KEY_FLAG.7,KEY_PROCESS
SJMP MAIN_END
;INIT2322_TAB:
; DB 94,94,94,88,88,88,88,88,88,88,88,88,88,88,88,88
; DB 0FEH,0C8H,0D0H,0C7H,074H,037H,067H,017H
; DB 027H,047H,057H,0E4H,0D8H,0BFH,0AFH,09FH
   Scan keypad part ;
KEY_PROCESS:
CLR IE.7
CLR KEY_FLAG.7
SETB KEY_FLAG.6
JB KEY_FLAG.5,KEY_PROCESS_POWER
JB KEY_FLAG.4,KEY_PROCESS_MUTE
JB KEY_FLAG.3,KEY_PROCESS_MODE
JB KEY_FLAG.2,KEY_PROCESS_CHANNEL1
JB KEY_FLAG.1,KEY_PROCESS_UP1
JB KEY_FLAG.0,KEY_PROCESS_DOWN1
JMP KEY_PROCESS_END
KEY_PROCESS_UP1:
JMP KEY_PROCESS_UP
KEY_PROCESS_CHANNEL1:
JMP KEY_PROCESS_CHANNEL
KEY_PROCESS_DOWN1:
JMP KEY_PROCESS_DOWN
KEY_PROCESS_POWER:
; JMP DPR2653_FRONT_H
JMP KEY_PROCESS_END
KEY_PROCESS_MUTE:
JMP DPR2653_MUTE
KEY_PROCESS_ENDA:
JMP KEY_PROCESS_END
KEY_PROCESS_MODE:
JB BIT_FLAG.6, KEY_PROCESS_ENDA ;MUTE
INC MODE_FLAG
MOV ACC,MODE_FLAG
CLR C
ANL A,#07H
JZ KEY_PROCESS_MODE_VOL
SUBB A,#01
JZ KEY_PROCESS_MODE_FRONT
SUBB A,#01
JZ KEY_PROCESS_MODE_CEN
SUBB A,#01
JZ KEY_PROCESS_MODE_SURR
SUBB A,#01
JZ KEY_PROCESS_MODE_SW
MOV MODE_FLAG,#00
KEY_PROCESS_MODE_VOL:
ORL DISPLAY_COM2,#7EH ; lit off other LED
ANL DISPLAY_COM2,#0FDH ; lit on Valume_LED
MOV A,VOL_MAS
DEC A
MOV VOL_MAS,A
JMP DPR2653_VOLUME_H3
JMP KEY_PROCESS_END
KEY_PROCESS_MODE_FRONT:
ANL DISPLAY_COM2,#0FBH ; lit on Front_LED
MOV A,VOL_FL
DEC A
MOV VOL_FL,A
JMP DPR2653_FRONT_H1
JMP KEY_PROCESS_END
KEY_PROCESS_MODE_CEN:
ANL DISPLAY_COM2,#0F7H ; lit on Center_LED
MOV A,VOL_CEN
DEC A
MOV VOL_CEN,A
JMP DPR2653_CENTER_H1
JMP KEY_PROCESS_END
KEY_PROCESS_MODE_SURR:
ANL DISPLAY_COM2,#0EFH ; lit on Rear_LED
MOV A,VOL_SL
DEC A
MOV VOL_SL,A
JMP DPR2653_REAR_H1
JMP KEY_PROCESS_END
KEY_PROCESS_MODE_SW:
ANL DISPLAY_COM2,#0DFH ; lit on SUBWF_LED
MOV A,VOL_SUB
DEC A
MOV VOL_SUB,A
JMP DPR2653_SUBWF_H1
JMP KEY_PROCESS_END
KEY_PROCESS_CHANNEL:
JMP DPR2653_DVD_CD
KEY_PROCESS_UP:
MOV DPTR,#KEY_PROUP_TAB
MOV ACC,MODE_FLAG
ANL A,#07H
RL A
JMP @A+DPTR
KEY_PROUP_TAB:
AJMP DPR2653_VOLUME_H
AJMP DPR2653_FRONT_H
AJMP DPR2653_CENTER_H
AJMP DPR2653_REAR_H
AJMP DPR2653_SUBWF_H
AJMP KEY_PROCESS_END
KEY_PROCESS_DOWN:
MOV DPTR,#KEY_PRODOWN_TAB
MOV ACC,MODE_FLAG
ANL A,#07H
RL A
JMP @A+DPTR
KEY_PRODOWN_TAB:
AJMP DPR2653_VOLUME_L
AJMP DPR2653_FRONT_L
AJMP DPR2653_CENTER_L
AJMP DPR2653_REAR_L
AJMP DPR2653_SUBWF_L
KEY_PROCESS_END:
; CLR KEY_FLAG.6
MOV KEY_FLAG,#00
SETB IE.7
JMP MAIN_END
SCAN_KEY:
SCAN_RETURN:
POP PSW
POP ACC
RETI
; LED Display and Common Counter part ;
LED_DISPLAY:
MOV TH1,#0EDH ; CYC = 66.7Hz (5msinterrupt)
MOV TL1,#078H
ORL TCON,#40H
JNB DELAY_H.7,LED_DISPLAY2
MOV ACC,DELAY_L
JNZ DOWN_COUNT2
MOV ACC,DELAY_H
ANL ACC,#0FH
JNZ DOWN_COUNT1
CALL DPR2653_VOLUME_H4
DOWN_COUNT1:
DEC DELAY_H
DOWN_COUNT2:
DEC DELAY_L
LED_DISPLAY2:
MOV C,COM0_FLAG
JNC DISP_ONE
MOV C,COM1_FLAG
JC DISP_LED
JMP DISP_TEN
DISP_LED:
SCANKEY_UP:
JB P3.3,SCANKEY_UPA
INC KEY_UP
JB KEY_UP.5,SCANKEY_UP0
JB KEY_UP.6,SCANKEY_CHANNEL
JB KEY_UP.3,SCANKEY_UP3
JB KEY_UP.7,SCANKEY_CHANNEL
JB KEY_UP.2,SCANKEY_UP2
SJMP SCANKEY_CHANNEL
SCANKEY_UP0:
ANL KEY_UP,#80H
SJMP SCANKEY_UP3
SCANKEY_UP2:
SETB KEY_UP.6
SETB KEY_UP.7
SCANKEY_UP3:
ANL KEY_UP,#0F0H
SETB KEY_FLAG.1
SETB KEY_FLAG.7
SCANKEY_UPA:
MOV KEY_UP,#00
SCANKEY_CHANNEL:
JB P3.4,SCANKEY_CHANNELA
JB KEY_CHANNEL.7,DISP_LED_2
INC KEY_CHANNEL
JNB KEY_CHANNEL.2,DISP_LED_2
ANL KEY_CHANNEL,#0F0H
SETB KEY_CHANNEL.7
SETB KEY_FLAG.2
SETB KEY_FLAG.7
SJMP DISP_LED_2
SCANKEY_CHANNELA:
MOV KEY_CHANNEL,#00
DISP_LED_2:
ORL P3,#0A0H
ORL P1,#080H ; Clear off all the display
CLR COM0_FLAG
ORL DISPLAY_COM2,#80H
MOV P1,DISPLAY_COM2
ANL P1,#7FH
AJMP DISPLAY_RTN
DISP_ONE:
SCANKEY_DOWN:
JB P3.3,SCANKEY_DOWNA
INC KEY_DOWN
JB KEY_DOWN.5,SCANKEY_DOWN1
JB KEY_DOWN.6,SCANKEY_MODE
JB KEY_DOWN.3,SCANKEY_DOWN3
JB KEY_DOWN.7,SCANKEY_MODE
JB KEY_DOWN.2,SCANKEY_DOWN2
SJMP SCANKEY_MODE
SCANKEY_DOWN1:
ANL KEY_DOWN,#80H
SJMP SCANKEY_DOWN3
SCANKEY_DOWN2:
SETB KEY_DOWN.6
SETB KEY_DOWN.7
SCANKEY_DOWN3:
ANL KEY_DOWN,#0F0H
SETB KEY_FLAG.0
SETB KEY_FLAG.7
SJMP SCANKEY_MODE
SCANKEY_DOWNA:
MOV KEY_DOWN,#00
SCANKEY_MODE:
JB P3.4,SCANKEY_MODEA
JB KEY_MODE.7,DISP_ONE_2
INC KEY_MODE
JNB KEY_MODE.2,DISP_ONE_2
ANL KEY_MODE,#0F0H
SETB KEY_MODE.7
SETB KEY_FLAG.3
SETB KEY_FLAG.7
SJMP DISP_ONE_2
SCANKEY_MODEA:
MOV KEY_MODE,#00
DISP_ONE_2:
ORL P3,#0A0H
SETB COM0_FLAG
CLR COM1_FLAG
MOV DPTR,#LED_TABLE
MOV ACC,DISPLAY_COM0
MOVC A,@A+DPTR
ORL A,#80H
MOV P1,ACC
ANL P3,#0DFH
AJMP DISPLAY_RTN
DISP_TEN:
SCANKEY_POWER:
JB P3.3,SCANKEY_POWERA
JB KEY_POWER.7,SCANKEY_MUTE
INC KEY_POWER
JNB KEY_POWER.2,SCANKEY_MUTE
ANL KEY_POWER,#0F0H
SETB KEY_POWER.7
SETB KEY_FLAG.5
SETB KEY_FLAG.7
SJMP SCANKEY_MUTE
SCANKEY_POWERA:
MOV KEY_POWER,#00
SCANKEY_MUTE:
JB P3.4,SCANKEY_MUTEA
JB KEY_MUTE.7,DISP_TEN_2
INC KEY_MUTE
JNB KEY_MUTE.2,DISP_TEN_2
ANL KEY_MUTE,#0F0H
SETB KEY_MUTE.7
SETB KEY_FLAG.4
SETB KEY_FLAG.7
SJMP DISP_TEN_2
SCANKEY_MUTEA:
MOV KEY_MUTE,#00
DISP_TEN_2:
ORL P3,#0A0H
SETB COM1_FLAG
MOV DPTR,#LED_TABLE
MOV ACC,DISPLAY_COM1
MOVC A,@A+DPTR
ORL A,#80H
MOV P1,ACC
ANL P3,#7FH
DISPLAY_RTN:
CALL COUNTER
POP PSW
POP ACC
RETI
LED_TABLE:
DB 10001000B,11011011B,10100010B,10010010B
DB 11010001B,10010100B,10000100B,11011010B
DB 10000000B,10010000B,11110111B
COUNTER:
INC IRDATA_HOLD
MOV ACC,IRDATA_HOLD
JNB ACC.7,COUNTER2 ; if no data received within 0.32s
MOV IRDATA_HOLD,#00
MOV ACC,IR_COUNTER
JNZ COUNTER2
MOV IR_DATA2,#0FFH ; then clear the received IR data
COUNTER2:
INC COUNTER_1
MOV ACC,COUNTER_1
JNZ COUNTER_RTN
INC COUNTER_2
COUNTER_RTN:
RET
   Data Receiver part ;
IR_RECEIVE: ; interrupt from port_int1(int1)
ANL PSW,#0E7H
CALL DELAY_50US
MOV C,P3.2
JNC IR_RECEIVE01
JMP PINT_RTN
IR_RECEIVE01:
MOV ACC,IR_COUNTER
JNB ACC.6,FIRST_BIT
JB ACC.5,FIRST_DATABIT
CLR CONTINUE_F ;>>>>>>>>>>>>>>>>>>>>
INC IR_COUNTER
MOV ACC,IR_COUNTER
JB ACC.5,RECEIVE_END
ANL ACC,#3FH
XRL ACC,#10H
JZ USERCODE_CHK
DATA_RECEIVE:
ACALL DATABIT_REC
SJMP SET_TIMER1_A
USERCODE_CHK:
ACALL DATABIT_REC
MOV ACC,IR_DATA2
XRL ACC,#008H ; user code 1
JNZ RECEIVE_ABORT
MOV ACC,IR_DATA1
XRL ACC,#0F7H ; user code 2
JNZ RECEIVE_ABORT
ACALL DATA_CLR
SJMP SET_TIMER1_A
RECEIVE_END:
ACALL DATABIT_REC
MOV ACC,IR_DATA2
XRL ACC,#0FFH
XRL A,IR_DATA1
JNZ RECEIVE_ABORT
ANL TCON,#0CFH ; stop timer0 count and clr EVF
MOV IR_COUNTER,#00
MOV IRDATA_HOLD,#00
SETB CONTINUE_F ;>>>>>>>>>>>>>>>>>>>>>>>>
JMP DATA_PROCESS2 ; ---->>
FIRST_BIT:
; CLR CONTINUE_F
MOV IR_COUNTER,#00
SJMP SET_TIMER1_A
FIRST_DATABIT:
; SETB CONTINUE_F ;>>>>>>>>>>>>>>>>>>>>>>>>
ANL IR_COUNTER,#0C0H
SJMP SET_TIMER1_A
RECEIVE_ABORT:
MOV IR_COUNTER,#00
; ANL IE,#0FDH ; disable timer0 int
MOV C,CONTINUE_F
JC PINT_RTN
ACALL DATA_CLR
SJMP PINT_RTN
SET_TIMER1_A:
ANL IR_COUNTER,#7FH
CLR SIGN_F
MOV TH0,#0F8H ; F7H
MOV TL0,#040H ; 40H
ORL TCON,#10H ; enable timer0 count
; ORL IE,#02H ; enable timer0 int
PINT_RTN:
POP PSW
POP ACC
RETI
DATABIT_REC:
MOV C,SIGN_F
MOV ACC,IR_DATA1
RLC A
MOV IR_DATA1,ACC
MOV ACC,IR_DATA2
RLC A
MOV IR_DATA2,ACC
RET
DATA_CLR:
MOV IR_DATA1,#0FFH
MOV IR_DATA2,#0FFH
RET
IR_RECEIVE2: ; interrupt from timer1_int
; MOV P1,#00H
MOV ACC,IR_COUNTER
JB ACC.7,CONTINUE_CHK
JNB ACC.6,FIRSTBIT_CHECK
ORL IR_COUNTER,#80H
SETB SIGN_F
SJMP SET_TIMER1_1
CONTINUE_CHK:
MOV C,CONTINUE_F
JNC RECEIVE_ABORT
MOV A,IR_DATA2
JB ACC.2,RECEIVE_ABORT
JB ACC.0,RECEIVE_ABORT
MOV IR_COUNTER,#00
MOV IRDATA_HOLD,#00
JMP DATA_PROCESS ; ---->>
FIRSTBIT_CHECK:
INC IR_COUNTER
FIRST_CHK:
CJNE R0,#01,SECOND_CHK
MOV C,P3.2
JC RECEIVE_ABORT
SJMP SET_TIMER1_1
SECOND_CHK:
CJNE R0,#02,THIRD_CHK
MOV C,P3.2
JC RECEIVE_ABORT
SJMP SET_TIMER1_1
THIRD_CHK:
CJNE R0,#03,FOURTH_CHK
SJMP SET_TIMER1_1
FOURTH_CHK:
MOV C,P3.2
JNC RECEIVE_ABORT
MOV IR_COUNTER,#60H
CLR SIGN_F
MOV TH0,#0EEH
MOV TL0,#80H
SJMP SET_TIMER1_2
SET_TIMER1_1:
MOV TH0,#0F4H ; F7H
MOV TL0,#040H ; 40H
SET_TIMER1_2:
; ANL TCON,#7FH ; clear timer0 EVF
TIMER1_RTN:
POP PSW
POP ACC
RETI
DELAY_50US:
MOV CONST_1,#016
LOOP_50US:
NOP
DJNZ CONST_1,LOOP_50US
RET
; Data process part ;
DATA_PROCESS:
INC IRDATA_SPEED
MOV ACC,IRDATA_SPEED
JB ACC.2,DATA_PROCESS1
JMP PINT_RTN
DATA_PROCESS1:
ANL IRDATA_SPEED,#0F0H
ORL IRDATA_SPEED,#03H
JMP DATA_PROCESS3
DATA_PROCESS2:
DATA_PROCESS3:
; JNB SYS_OPTION.7,DPR_CV2653
; JMP DPR_PT2322
DPR_CV2653:
MOV ACC,IR_DATA2
JB ACC.3,DPR_CV2653_2
JB ACC.1,DPR_CV2653_1
MOV DPTR,#DPR2653_TAB0
SJMP DPR_CV2653_A
DPR_CV2653_1:
MOV DPTR,#DPR2653_TAB1
SJMP DPR_CV2653_A
DPR_CV2653_2:
JB ACC.1,DPR_CV2653_3
MOV DPTR,#DPR2653_TAB2
SJMP DPR_CV2653_A
DPR_CV2653_3:
MOV DPTR,#DPR2653_TAB3
SJMP DPR_CV2653_A
DPR_CV2653_A:
SWAP A
ANL A,#0FH
RL A
JMP @A+DPTR
DPR2653_TAB0: ; IR_DATT2=xxxx 0000
AJMP DPR2653_REAR_H ;*********
AJMP DPR2653_SUBWF_H ;*******
AJMP DPR2653_
AJMP DPR2653_
AJMP DPR2653_
AJMP DPR2653_
AJMP DPR2653_;RECOMMEND ;
AJMP DPR2653_ ;REAR_H
AJMP DPR2653_
AJMP DPR2653_
AJMP DPR2653_REAR_L
AJMP DPR2653_SUBWF_L;******
DPR2653_TAB1: ; IR_DATT2=xxxx 0010
AJMP DPR2653_
AJMP DPR2653_
AJMP DPR2653_MUTE ;*************
AJMP DPR2653_
AJMP DPR2653_
AJMP DPR2653_
AJMP DPR2653_VOLUME_H2
AJMP DPR2653_
AJMP DPR2653_ ; 08
AJMP DPR2653_
AJMP DPR2653_
AJMP DPR2653_
AJMP DPR2653_
AJMP DPR2653_
; AJMP DPR2653_
DPR2653_TAB2: ; IR_DATT2=xxxx 1000
AJMP DPR2653_DVD
AJMP DPR2653_DVD
AJMP DPR2653_
AJMP DPR2653_
AJMP DPR2653_
AJMP DPR2653_
AJMP DPR2653_ ; 08
AJMP DPR2653_CD
AJMP DPR2653_
AJMP DPR2653_CD
AJMP DPR2653_CD
AJMP DPR2653_VOLUME_L2
; AJMP DPR2653_
DPR2653_TAB3: ; IR_DATT2=xxxx 1010
; AJMP DPR2653_DVD
; AJMP DPR2653_
; AJMP DPR2653_
; AJMP DPR2653_
; AJMP DPR2653_
; AJMP DPR2653_
; AJMP DPR2653_
; AJMP DPR2653_
; AJMP DPR2653_ ; 08
; AJMP DPR2653_
; AJMP DPR2653_
; AJMP DPR2653_
; AJMP DPR2653_
; AJMP DPR2653_
; AJMP DPR2653_
; AJMP DPR2653_
DPR2653_:
JMP PINT_RTN
DPR2653_MUTE:
CALL DATA_CLR
MOV C,MUTE_ENABLE
JC MUTE_DIS
MUTE_EN:
MOV DISPLAY_COMA,#00
MOV DISPLAY_COMB,#00
MOV DISPLAY_COMA,DISPLAY_COM0
MOV DISPLAY_COMB,DISPLAY_COM1
; MOV DISPLAY_COMC,DISPLAY_COM2
MOV DISPLAY_COM0,#00AH
MOV DISPLAY_COM1,#00AH
; MOV DISPLAY_COM2,#0FFH
SETB MUTE_ENABLE ; set Mute_pin to H
MOV SEND__D1,#0F9H
MOV SEND__D2,#00
CALL SEND_CV2653
JMP DPR2653_END
MUTE_DIS:
; MOV DISPLAY_COM2,DISPLAY_COMC
; ORL DISPLAY_COM2,#02H ; lit off Mute LED
CLR MUTE_ENABLE ; set Mute_pin to L
MOV SEND__D1,#0F8H
MOV SEND__D2,#00
MOV DISPLAY_COM0,DISPLAY_COMA
MOV DISPLAY_COM1,DISPLAY_COMB
CALL SEND_CV2653
JMP DPR2653_END
;DPR2653_RECOMMEND:
; JB BIT_FLAG.6,DPR2653_END5
; MOV DISPLAY_COM0,#06
; MOV DISPLAY_COM1,#03
; MOV CONST_1,#035
; MOV VOL_SL,#57
; MOV VOL_SR,#57
; MOV VOL_FL,#57
; MOV VOL_FR,#57
; MOV VOL_CEN,#57
; MOV VOL_SUB,#57
; MOV VOL_MAS,#57
; JMP DPR2653_VOLUME_HI
DPR2653_END5:
JMP DPR2653_END
DPR2653_DVD_CD:
MOV C,DVD_CD_F
JNC DPR2653_CD
DPR2653_DVD:
JB BIT_FLAG.6,DPR2653_END6
CALL DATA_CLR
CLR DVD_CD_F
; CLR P3.1
ANL DISPLAY_COM2,#07EH
JMP DPR2653_END
DPR2653_END6:
JMP DPR2653_END
DPR2653_CD:
DPR2653_TAPE:
JB BIT_FLAG.6,DPR2653_END6 ;檢測是否在MUTE 狀態(tài)
CALL DATA_CLR
SETB DVD_CD_F
; SETB P3.1
ORL DISPLAY_COM2,#01H
JMP DPR2653_END
DPR2653_END4:
JMP DPR2653_END
DPR2653_VOLUME_H:
DPR2653_VOLUME_H2:
JB BIT_FLAG.6,DPR2653_END4
DPR2653_VOLUME_H3:
MOV CONST_1,VOL_MAS
DPR2653_VOLUME_HI:
CALL COM2653_UP
JMP DPR2653_VOLUME_RTN_H
DPR2653_VOLUME_L:
DPR2653_VOLUME_L2:
DPR2653_VOLUME_RTN_L:
MOV CONST_1,VOL_SL
CALL COM2653_DOWN
ORL SEND__D1,#00H
ORL SEND__D2,#10H
CALL SEND_CV2653 ; RL
ANL SEND__D1,#0FH
ORL SEND__D1,#20H
ANL SEND__D2,#0FH
ORL SEND__D2,#30H
CALL SEND_CV2653 ; RR
MOV VOL_SL,CONST_1
MOV CONST_1,VOL_FL
CALL COM2653_DOWN
ANL SEND__D1,#0FH
ORL SEND__D1,#80H
ANL SEND__D2,#0FH
ORL SEND__D2,#90H
CALL SEND_CV2653 ; FL
ANL SEND__D1,#0FH
ORL SEND__D1,#40H
ANL SEND__D2,#0FH
ORL SEND__D2,#50H
CALL SEND_CV2653 ; FR
MOV VOL_FL,CONST_1
MOV CONST_1,VOL_CEN
CALL COM2653_DOWN
ANL SEND__D1,#0FH
ORL SEND__D1,#60H
ANL SEND__D2,#0FH
ORL SEND__D2,#70H
CALL SEND_CV2653 ; CEN
MOV VOL_CEN,CONST_1
MOV CONST_1,VOL_SUB
CALL COM2653_DOWN
ANL SEND__D1,#0FH
ORL SEND__D1,#0A0H
ANL SEND__D2,#0FH
ORL SEND__D2,#0B0H
CALL SEND_CV2653 ; SW
MOV VOL_SUB,CONST_1
MOV CONST_1,VOL_MAS
CALL COM2653_DOWN
MOV VOL_MAS,CONST_1
MOV MODE_FLAG,#00
JMP DPR2653_END
DPR2653_END9:
JMP DPR2653_END
DPR2653_VOLUME_RTN_H:
MOV ACC,VOL_MAS
XRL ACC,#79
JZ DPR2653_END9
MOV CONST_1,VOL_SL
CALL COM2653_UP
ORL SEND__D1,#00H
ORL SEND__D2,#10H
ANL SEND__D1,#0FH
ORL SEND__D1,#20H
ANL SEND__D2,#0FH
ORL SEND__D2,#30H
MOV VOL_SL,CONST_1
MOV CONST_1,VOL_FL
CALL COM2653_UP
ANL SEND__D1,#0FH
ORL SEND__D1,#80H
ANL SEND__D2,#0FH
ORL SEND__D2,#90H
ANL SEND__D1,#0FH
ORL SEND__D1,#40H
ANL SEND__D2,#0FH
ORL SEND__D2,#50H
MOV VOL_FL,CONST_1
MOV CONST_1,VOL_CEN
CALL COM2653_UP
ANL SEND__D1,#0FH
ORL SEND__D1,#60H
ANL SEND__D2,#0FH
ORL SEND__D2,#70H
MOV VOL_CEN,CONST_1
MOV CONST_1,VOL_SUB
CALL COM2653_UP
ANL SEND__D1,#0FH
ORL SEND__D1,#0A0H
ANL SEND__D2,#0FH
ORL SEND__D2,#0B0H
MOV VOL_SUB,CONST_1
MOV CONST_1,VOL_MAS
CALL COM2653_UP
MOV VOL_MAS,CONST_1
MOV MODE_FLAG,#00
JMP DPR2653_END
DPR2653_VOLUME_H4:
JB BIT_FLAG.6,DPR2653_VOLUME_H5 ;檢測是否在MUTE 狀態(tài)
DEC VOL_MAS
MOV CONST_1,VOL_MAS
CALL COM2653_UP
MOV VOL_MAS,CONST_1
MOV MODE_FLAG,#00
DPR2653_VOLUME_H5:
RET
DPR2653_FRONT_H:
JB BIT_FLAG.6,DPR2653_END1 ;檢測是否在MUTE 狀態(tài)
DPR2653_FRONT_H1:
MOV CONST_1,VOL_FL
CALL COM2653_UP
JMP DPR2653_FRONT_RTN
DPR2653_FRONT_L:
MOV CONST_1,VOL_FL
CALL COM2653_DOWN
DPR2653_FRONT_RTN:
MOV VOL_FL,CONST_1
MOV VOL_FR,CONST_1
ANL SEND__D1,#0FH
ORL SEND__D1,#80H
ANL SEND__D2,#0FH
ORL SEND__D2,#90H
ANL SEND__D1,#0FH
ORL SEND__D1,#40H
ANL SEND__D2,#0FH
ORL SEND__D2,#50H
MOV MODE_FLAG,#01
JMP DPR2653_END
DPR2653_END1:
JMP DPR2653_END
DPR2653_REAR_H:
DPR2653_REAR_H1:
MOV CONST_1,VOL_SL
CALL COM2653_UP
JMP DPR2653_REAR_RTN
DPR2653_REAR_L:
MOV CONST_1,VOL_SL
CALL COM2653_DOWN
DPR2653_REAR_RTN:
MOV VOL_SL,CONST_1
MOV VOL_SR,CONST_1
ANL SEND__D1,#0FH
ORL SEND__D1,#00H
ANL SEND__D2,#0FH
ORL SEND__D2,#10H
ANL SEND__D1,#0FH
ORL SEND__D1,#20H
ANL SEND__D2,#0FH
ORL SEND__D2,#30H
MOV MODE_FLAG,#03
JMP DPR2653_END
DPR2653_CENTER_H:
DPR2653_CENTER_H1:
MOV CONST_1,VOL_CEN
CALL COM2653_UP
JMP DPR2653_CENTER_RTN
DPR2653_CENTER_L:
MOV CONST_1,VOL_CEN
CALL COM2653_DOWN
DPR2653_CENTER_RTN:
MOV VOL_CEN,CONST_1
ANL SEND__D1,#0FH
ORL SEND__D1,#60H
ANL SEND__D2,#0FH
ORL SEND__D2,#70H
MOV MODE_FLAG,#02
JMP DPR2653_END
DPR2653_SUBWF_H:
JB BIT_FLAG.6,DPR2653_END3 ;檢測是否在MUTE 狀態(tài)
DPR2653_SUBWF_H1:
MOV CONST_1,VOL_SUB
CALL COM2653_UP
JMP DPR2653_SUBWF_RTN
DPR2653_SUBWF_L:
MOV CONST_1,VOL_SUB
CALL COM2653_DOWN
DPR2653_SUBWF_RTN:
MOV VOL_SUB,CONST_1
; ANL SEND__D1,#0FH
ORL SEND__D1,#0A0H
; ANL SEND__D2,#0FH
ORL SEND__D2,#0B0H
MOV MODE_FLAG,#04
JMP DPR2653_END
DPR2653_END3:
JMP DPR2653_END
DPR2653_END:
MOV DELAY_H,#82H
MOV DELAY_L,#58H
JB KEY_FLAG.6,DPR2653_END2
JMP PINT_RTN
DPR2653_END2:
JMP KEY_PROCESS_END
COM2653_UP: ; subrouting
MOV ACC,CONST_1
CLR C
SUBB A,#079
JNC UP_OVERFLOW
INC CONST_1
JMP GENERATE_DISPDATA
UP_OVERFLOW:
MOV CONST_1,#079
COM2653_DOWN:
MOV ACC,CONST_1
JZ GENERATE_DISPDATA
DEC CONST_1
; JMP GENERATE_DISPDATA
GENERATE_DISPDATA:
MOV ACC,CONST_1
SWAP A
ANL A,#0FH
MOV DISPLAY_COM1,ACC
MOV ACC,CONST_1
ANL A,#0FH
ADD A,#00H ; clear C, AC
DA A
MOV DISPLAY_COM0,ACC
GENERATE_LOOPS:
JZ GENERATE_ENDS
DEC DISPLAY_COM1
ADD A,#16H
DA A
SJMP GENERATE_LOOPS
GENERATE_ENDS:
MOV REPLACE_VAR,DISPLAY_COM0 ; !!!!!
SWAP A
ANL A,#0FH
ANL DISPLAY_COM0,#0FH
; RET
GENERATE_SENDDATA:
CLR C
MOV ACC,#79H
SUBB A,REPLACE_VAR
DA A
MOV SEND__D2,ACC
SWAP A
ANL A,#0FH
MOV SEND__D1,ACC
ANL SEND__D2,#0FH
RET
; Data transmitte subroute (to 2322 & 2323) ;
SEND_CV2653:
CALL DELAY_10US
CALL DELAY_10US
ANL SEND_FLAG,#0FH
SEND_START:
SETB P3.1 ;SET "CLK" TO "H"
CALL DELAY_10US
SETB P3.0 ;SET "SDA" TO "H"
CALL DELAY_10US
CLR P3.0 ;SET "SDA" TO "L"
CALL DELAY_10US
CLR P3.1 ;SET "CLK" TO "L"
CALL DELAY_10US
INC SEND_FLAG
JB SEND_FLAG.2,SEND_END
SEND_DATA1_2:
MOV REPLACE_VAR,#88H
CALL SEND_BYTE
JB SEND_FLAG.7,SEND_CV2653
MOV REPLACE_VAR,SEND__D1
CALL SEND_BYTE
MOV ACC,SEND__D2
JZ SEND_END
SEND_DATA3:
MOV REPLACE_VAR,SEND__D2
CALL SEND_BYTE
SEND_END:
CALL DELAY_10US
CALL DELAY_10US
CALL DELAY_10US
MOV SEND_FLAG,#00
; MOV C,DVD_CD_F
; MOV P3.1,C
; CLR P3.1
RET
SEND_BYTE:
NOP
NOP
MOV A,REPLACE_VAR
RLC A
MOV REPLACE_VAR,A
JC SEND_DATA_1
SEND_DATA_0:
CLR P3.0
SJMP SEND_DATA_C
SEND_DATA_1:
SETB P3.0
NOP
SEND_DATA_C:
CALL DELAY_10US
SETB P3.1
CALL DELAY_10US
CALL DELAY_10US
CLR P3.1
; CALL DELAY_10US
MOV A,SEND_FLAG
ADD A,#10H
MOV SEND_FLAG,A
JNB SEND_FLAG.7,SEND_BYTE
CALL DELAY_10US
SETB P3.1 ;"CLK" TO "H"
CALL DELAY_10US
CALL DELAY_10US
MOV C,P3.0 ;READ P3.0 pin for ACK_chk
MOV SEND_FLAG.7,C
CLR P3.1 ; SET "CLK" TO "L"
CALL DELAY_10US
CLR P3.0 ; SET "SDA" TO "L"
; CALL DELAY_10US
RET
;指令延時程序:
DELAY_10US:
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
nop
nop
RET
DELAY_300MM:
MOV DELAY_A,#0FFH
DL2: MOV DELAY_B,#0FFH
DL1: NOP
NOP
DJNZ DELAY_B,DL1
DJNZ DELAY_A,DL2
RET
; <<---- PROGRAM END ---->> ;
; NOP
; NOP
; NOP
END
不知道您是不是看懂了上面的單片機程序電子音響的設計是很難的
