msp430G2553單片機(jī)的時(shí)鐘選擇和分頻程序如下:
#include "msp430G2553.h"
#define unchar unsigned char
uint Fre;
int main( void )
// Stop watchdog timer to prevent time out reset
WDTCTL = WDTPW + WDTHOLD;
BCSCTL2 |=SELM_1+DIVM_0;
P1DIR &=~BIT3;
P1REN |=BIT3;
P1OUT |=BIT3;
P1DIR |=BIT0;
P1IE |=BIT3;
P1IES &=~BIT3;
_EINT();
P1OUT ^=BIT0;
__delay_cycles(1000000);
#pragma vector=PORT1_VECTOR
__interrupt void PORTP13(void)
uint temp,pushkey=0;
pushkey=BIT3 & (~P1DIR);
__delay_cycles(100000);
temp=P1IN;
if((~temp) & BIT3==pushkey)
Fre++;
if(Fre>3) Fre=0;
switch(Fre)
case 0: DCOCTL=CALDCO_1MHZ;BCSCTL1 = CALBC1_1MHZ;break;
case 1: DCOCTL=CALDCO_8MHZ;BCSCTL1 = CALBC1_8MHZ;break;
case 2: DCOCTL=CALDCO_12MHZ;BCSCTL1 = CALBC1_12MHZ;break;
case 3: DCOCTL=CALDCO_16MHZ;BCSCTL1 = CALBC1_16MHZ;break;
default:break;
P1IFG &=~BIT3;
