MSP430F5529的P1.7、P2.2中斷和頻率設(shè)置
作者:huqin   來源:本站原創(chuàng)   點(diǎn)擊數(shù):  更新時(shí)間:2014年08月31日   【字體:
MSP430F5529單片機(jī)的P1.7、P2.2 io口中斷和頻率設(shè)置程序:
#include "msp430F5529.h"
#define P15_H    (P1IN & BIT5);
#define P15_L   (P1OUT & (~BIT5));
int tt=0,temp,kk,i;
void delay(int ns)
  int kk;
  while(ns--)
    for(kk=0;kk<120;kk++);
//******A/D轉(zhuǎn)換函數(shù)設(shè)置*****//
void adc1()
 P1SEL |=BIT6;       //轉(zhuǎn)換模擬信號(hào)從P1.6輸入,內(nèi)部集成了轉(zhuǎn)換模塊
 ADC12CTL0 =ADC12ON  + ADC12SHT02 + ADC12MSC;
 ADC12CTL1 =ADC12SHP + ADC12CONSEQ_2;
 ADC12MCTL0=ADC12SREF_0+ADC12INCH_6;
 ADC12CTL0 |=ADC12ENC;
//////一次轉(zhuǎn)換結(jié)束后產(chǎn)生轉(zhuǎn)換中斷調(diào)用ADC中斷函數(shù)////
void MainFre24M(void)
   UCSCTL3 |=SELREF__REFOCLK;
   __bis_SR_register(SCG0);     //disable the FLL control loop
   UCSCTL0=0X0000;//            //Set lowest possible DCOx,MODxSCG0
   UCSCTL1=DCORSEL_6;           //Select DCO range 24MHz opreation
                               //DCORSEL_x,其中x可選3、4、5、6、7
   UCSCTL3=FLLD_0+731;          //Set DCO Multiplier for 24MHz
                                //(N+1)*FLLRef=Fdco
                                //(731+1)*32768=24MHz
                               //Set FLL DIV =fDCOCLK/2
   __bis_SR_register(SCG0);                 //Enable the FLL control loopSCG0
   UCSCTL4 |=SELA__DCOCLK+SELS__XT1CLK+SELM__DCOCLK;//MCLK Source select
   UCSCTL5 |=DIVPA_2;                       //ACLK output divide
   UCSCTL6 |=XT1DRIVE_3+XCAP_0;             //XT1 cap
int main(void)
   WDTCTL = WDTPW + WDTHOLD;   // Stop WDT
   MainFre24M();
   UCSCTL3=FLLD_0+731;
   UCSCTL1=DCORSEL_7;
   P1REN |=BIT7;
   P1OUT |=BIT7;
   P1IE |=BIT7;
   P1IES|=BIT7;
   P1IFG&=~BIT7;
   P2REN |=BIT2;
   P2OUT |=BIT2;
   P2IE |=BIT2;
   P2IES|=BIT2;
   P2IFG&=~BIT2;
   __enable_interrupt();
   P1DIR |= 0x3f;
   P1DS  |= 0x3f;
       UCSCTL1=DCORSEL_3;
       P1OUT |=BIT5;
       delay(1000);
       P1OUT &=~BIT5;
       delay(1000);
#pragma vector=PORT1_VECTOR
__interrupt void PORT17ISR(void)
 int i;
 UCSCTL1=DCORSEL_7;
 UCSCTL3=FLLD_7+730;
 for(i=0;i<40;i++)
       P1OUT |=BIT0;
       delay(1000);
       P1OUT &= ~BIT0;
       delay(1000);
 P1IFG &=~BIT7;
#pragma vector=PORT2_VECTOR
__interrupt void PORT22ISR(void)
 int i;
 UCSCTL1=DCORSEL_7;
 UCSCTL3=FLLD_7+730;
 for(i=0;i<40;i++)
       P1OUT |=BIT3;
       delay(1000);
       P1OUT &= ~BIT3;
       delay(1000);
 P2IFG &=~BIT2;
