LCD1602液晶顯示器 C51模塊化程序+電路圖
作者:huqin   來(lái)源:本站原創(chuàng)   點(diǎn)擊數(shù):  更新時(shí)間:2014年10月24日   【字體:
下面是51單片機(jī)驅(qū)動(dòng)1602液晶的電路圖:
程序一共有3個(gè)文件:
lcd.h 頭文件
#ifndef _LCD_H_
#define _LCD_H_
#include <reg51.h>
extern void lcd_init();
extern void lcd_busy();
extern void lcd_write_dat(unsigned char dat);
extern void lcd_write_com(unsigned char dat);
extern void lcd_xy(unsigned char x,unsigned char y);
#endif
 lcd.c 文件
#include "lcd.h"
//#define uchar unsigned char
//#define uint unsigend int
#define port P0
unsigned char table[]="0123456789";
unsigned char table1[]="abcdefABCDEF";
sbit rs=P2^0;
sbit rw=P2^1;
sbit e=P2^2;
  ***00000  5*7  -> 0xff
  *****0** /5*8     0x40
  *****0**    0x40  ----> I
  *****0**    0x40  ---->
  *****0**    0x40
  *****0**    0x40
  ***00000    0x1f
  添加自己的自定義字符
code unsigned char ziku[]=
0x0f,0x09,0x09,0x0f,0x09,0x09,0x0f,0x00, //漢字“日”
0x0F,0x09,0x0F,0x09,0x0F,0x09,0x11,0x00, //漢字“月”
0x01,0x02,0x03,0x05,0x09,0x03,0x00,0x00, //漢字“年”左半部
0x00,0x00,0x1e,0x08,0x08,0x1e,0x08,0x08  //漢字“年”右半部
   讀取lcd1602狀態(tài)
unsigned char lcd_read()
  unsigned char temp;
  e=0;
  port=0xff;
  rs=0;
  rw=1;
  e=1;
  temp=port;
  e=0;
  return temp;
   檢測(cè) lcd 是否忙碌
void lcd_busy()
   unsigned char temp;
   do{
   temp=lcd_read();
     }while((temp&0x80)==0x80);
      向lcd里寫(xiě)命令
lcd_busy();
 e=0;
port=dat;
 rs=0;
 rw=0;
 e=1;
 e=0;
   讀取lcd對(duì)應(yīng)地址數(shù)據(jù)
unsigned char lcd_read_dat()
  unsigned char temp;
  lcd_busy();
  e=0;
  port=0xff;
  rs=1;
  rw=1;
  e=1;
  temp=port;
  e=0;
  return temp;
       向lcd里寫(xiě)數(shù)據(jù)
lcd_busy();
 e=0;
port=dat;
 rs=1;
 rw=0;
 e=1;
 e=0;
     向lcd寫(xiě)字符串
void lcd_gets(char *dat)
 while(*dat!=0)
 lcd_write_dat(*dat);
 dat++;
      確定要寫(xiě)的位子即x y 坐標(biāo)
 switch(y)
  case 0:lcd_write_com(0x80+x);break;//第一行第X個(gè)位置
  case 1:lcd_write_com(0xc0+x);break;//0xc0==0x80+0x50 第二行第X個(gè)位置
  case 2:lcd_write_com(0x94+x);break;//
  case 3:lcd_write_com(0xd4+x);break;//4*20
 單行顯示才有5*10  其他5*8 MODE=1 5*8  MODE=0 5*10
add_custom_word(unsigned char *dat,unsigned char len,unsigned char mode)
  unsigned char n,m;
  for(n=0;n<len;n++)
  if(mode)
   lcd_write_com(0x40+8*n);
    for(m=0;m<8;m++)
     dat++;
    lcd_write_com(0x40+10*n);
    for(m=0;m<10;m++)
     dat++;
   初始化lcd
void lcd_init()
 lcd_write_com(0x01) ;//清屏
 lcd_write_com(0x03) ;
 lcd_write_com(0x3c) ;
 lcd_write_com(0x40) ;
 lcd_write_com(0x0c) ;
 add_custom_word(ziku,4,1); //初始化自定義字符
   1ms 為基本單位的延時(shí)函數(shù)
void delay(unsigned char z)
  unsigned char x,y,a;
  for(x=z;x>0;x--)
    for(y=110;y>0;y--)
   for(a=1;a>0;a--) ;
 main.c 主文件
#include<reg51.h>
#include"lcd.h"
main()
 lcd_init();
 lcd_busy();
 lcd_xy(6,0);
 lcd_write_dat('b');
 while(1);
