程序說明:這是一個用51單片機(jī)驅(qū)動DS1302時間模塊+DS18B20溫度傳感器模塊+12864液晶顯示完整程序設(shè)計(jì)實(shí)例,有四個鍵盤KEY0 到KEY3,key0是修改時間的 首先是秒到分到時到年到月到日到星期 key1是加1 key2是減一 在修改時間狀態(tài)再按一下key3的時候就出去并修改時間日期,在平時狀態(tài)按著key3再按著key2 就會打開lcd 的燈 單單是只按key3那就是把燈關(guān)了。
文件一:DS1302驅(qū)動.c
#include<reg52.h>
//ds1302
sbit sclk=P0^3;
sbit io=P0^4;
sbit rst=P0^5;
sbit acc0=ACC^0;
sbit acc1=ACC^1;
sbit acc2=ACC^2;
sbit acc3=ACC^3;
sbit acc4=ACC^4;
sbit acc5=ACC^5;
sbit acc6=ACC^6;
sbit acc7=ACC^7;
delay()
unsigned char i;
i=10;
i=10;
i=10;
i=10;
i=10;
i=10;
i=10;}
w_1302(unsigned char dat,unsigned char shu){//寫一個八位的數(shù)去DS1302 //上升效 ;;;選寫地址再寫數(shù)據(jù)
ACC=dat;//地址
sclk=0;
rst=1;//
io=acc0;///
sclk=0;
delay();
sclk=1;
io=acc1;
sclk=0;
delay();
sclk=1;
io=acc2;
sclk=0;
delay();
sclk=1;
io=acc3;
sclk=0;
delay();
sclk=1;
io=acc4;
sclk=0;
delay();
sclk=1;
io=acc5;
sclk=0;
delay();
sclk=1;
io=acc6;
sclk=0;
delay();
sclk=1;
io=acc7;
sclk=0;
delay();
sclk=1;///
//sclk=0;
ACC=shu; //數(shù)據(jù)
io=acc0;///
sclk=0;
delay();
sclk=1;
io=acc1;
sclk=0;
delay();
sclk=1;
io=acc2;
sclk=0;
delay();
sclk=1;
io=acc3;
sclk=0;
delay();
sclk=1;
io=acc4;
sclk=0;
delay();
sclk=1;
io=acc5;
sclk=0;
delay();
sclk=1;
io=acc6;
sclk=0;
delay();
sclk=1;
io=acc7;
sclk=0;
delay();
sclk=1;///
rst=0;
sclk=0;
} ///寫完畢
unsigned char r_1302(unsigned char ADD){
sclk=0;
rst=1;
ACC=ADD; //地址
io=acc0;///
sclk=0;
delay();
sclk=1;
io=acc1;
sclk=0;
delay();
sclk=1;
io=acc2;
sclk=0;
delay();
sclk=1;
io=acc3;
sclk=0;
delay();
sclk=1;
io=acc4;
sclk=0;
delay();
sclk=1;
io=acc5;
sclk=0;
delay();
sclk=1;
io=acc6;
sclk=0;
delay();
sclk=1;
io=acc7;
sclk=0;/////
delay();
sclk=1;
delay();
sclk=0;
acc0=io;
delay();
sclk=1;
delay();
sclk=0;
acc1=io;
delay();
sclk=1;
delay();
sclk=0;
acc2=io;
delay();
sclk=1;
delay();
sclk=0;
acc3=io;
delay();
sclk=1;
delay();
sclk=0;
acc4=io;
delay();
sclk=1;
delay();
sclk=0;
acc5=io;
delay();
sclk=1;
delay();
sclk=0;
acc6=io;
delay();
sclk=1;
delay();
sclk=0;
acc7=io;
delay();
rst=0;
sclk=0;
return(ACC);
ds1302_c()
w_1302(0x80,0x80);
w_1302(0x8e,0x00);
w_1302(0x80,0x50); //;秒
w_1302(0x82,0x06); // 分=0
w_1302(0x84,0x01); //時 =0
w_1302(0x86,0x22); //
w_1302(0x88,0x11);//
w_1302(0x8a,0x04);//
w_1302(0x8b,0x07);//
w_1302(0x8e,0x80);
w_1302(0x90,0xa6);
w_1302(0x80,0x00);
main(){
rst=0;
ds1302_c();
for(;;){
P2=r_1302(0x81);
文件2:完全版 有關(guān)燈鍵.c
#include<reg52.h>
sbit di = P2^7; ////////定義引腳
sbit rw = P2^6;
sbit e = P2^5;
sbit cs1 = P2^4;
sbit cs2 = P2^1;
sbit lcd_d = P2^0;
sbit key0 = P2^3;
sbit key1 = P2^2;
sbit key2 = P1^0;
sbit key3 = P1^1;
sbit P07 = P0^7;
sbit P06 = P0^6;
sbit P05 = P0^5;
sbit P04 = P0^4;
sbit P03 = P0^3;
//ds1302
sbit sclk=P1^4;
sbit io=P1^3;
sbit rst=P1^2;
sbit acc0=ACC^0;
sbit acc1=ACC^1;
sbit acc2=ACC^2;
sbit acc3=ACC^3;
sbit acc4=ACC^4;
sbit acc5=ACC^5;
sbit acc6=ACC^6;
sbit acc7=ACC^7;
typedef unsigned char byte;
typedef unsigned int word;
sbit KEY=P3^7;//根據(jù)實(shí)際情況定義端口ds1820
unsigned char key_time=0; //全局變量
//////////////////////////////////溫度
//ds18b20數(shù)字溫度傳感器模塊程序
void delay1(word useconds)
for(;useconds>0;useconds--);
//復(fù)位
byte ow_reset(void)
byte presence;
KEY = 0; //pull DQ line low
delay1(29); // leave it low for 480us
KEY = 1; // allow line to return high
delay1(3); // wait for presence
presence = KEY; // get presence signal
delay1(25); // wait for end of timeslot
return(presence); // presence signal returned
} // 0=presence, 1 = no part
//從 1-wire 總線上讀取一個字節(jié)
byte read_byte(void)
byte i;
byte value = 0;
for (i=8;i>0;i--)
value>>=1;
KEY = 0; // pull DQ low to start timeslot
KEY = 1; // then return high
delay1(1); //for (i=0; i<3; i++);
if(KEY)value|=0x80;
delay1(6); // wait for rest of timeslot
return(value);
//向 1-WIRE 總線上寫一個字節(jié)
void write_byte(char val)
byte i;
for (i=8; i>0; i--) // writes byte, one bit at a time
KEY = val&0x01;
delay1(5); // hold value for remainder of timeslot
KEY = 1;
val=val/2;
delay1(5);
//讀取溫度
float wendu(void)
float tem;
union{
byte c[2];
int x;
}temp;
ow_reset();
write_byte(0xCC); // Skip ROM
write_byte(0xBE); // Read Scratch Pad
temp.c[1]=read_byte(); //lsd
temp.c[0]=read_byte(); //msd
ow_reset();
write_byte(0xCC); //Skip ROM
write_byte(0x44); // Start Conversion
tem=0.0;
if(temp.x & 0x01) tem+=0.0625;temp.x>>=1;
if(temp.x & 0x01) tem+=0.125;temp.x>>=1;
if(temp.x & 0x01) tem+=0.25;temp.x>>=1;
if(temp.x & 0x01) tem+=0.5;temp.x>>=1;
tem+=temp.x;
return tem;
void cs1_lcd(){ ////////選擇左邊
bit a=1;
cs1=a;
cs2=!a;
void cs2_lcd(){ ////////選擇右邊
bit a=1;
cs1=!a;
cs2=a;
void busy_lcd(){//////判斷忙
bit a=1;
di=!a;
rw=a;
e=a;
while(P07==a);
w_lcd(unsigned b){ ///寫a到12864
bit a=1;
busy_lcd();
rw =!a;
di =a;
P0=b;
e=a;
e=!a;
void dis_lcd(){//打開顯示選擇第一行顯示
bit a=1;
busy_lcd();
rw=!a;
di=!a;
P0=0x3f;
e=a;
e=!a;
P0=0xc0;
e=a;
e=!a;
y_lcd(unsigned a){///由A確定y軸
bit b=1;
busy_lcd();
rw=!b;
di=!b;
P0=a;
P07=b;
P06=!b;
P05=b;
P04=b;
P03=b;
e=b;
e=!b;
x_lcd(unsigned a){//由a確定X軸
bit b=1;
busy_lcd();
rw=!b;
di=!b;
P0=a;
P07=!b;
P06=b;
e=b;
e=!b;
void clr_lcd(){///清屏
bit a=0;
unsigned x,y,date,i;
cs1_lcd();
date=0x00;
for(i=0;i<2;i++){
for(y=0;y<8;y++)
for(x=0;x<64;x++){
x_lcd(x);
y_lcd(y);
w_lcd(date);
cs2_lcd();}
unsigned char code shu[18][16]={///0到9數(shù)字
{0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x0F,0x10,0x20,0x20,0x10,0x0F,0x00},//0
{0x00,0x10,0x10,0xF8,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00},//1
{0x00,0x70,0x08,0x08,0x08,0x88,0x70,0x00,0x00,0x30,0x28,0x24,0x22,0x21,0x30,0x00},//2
{0x00,0x30,0x08,0x88,0x88,0x48,0x30,0x00,0x00,0x18,0x20,0x20,0x20,0x11,0x0E,0x00},//3
{0x00,0x00,0xC0,0x20,0x10,0xF8,0x00,0x00,0x00,0x07,0x04,0x24,0x24,0x3F,0x24,0x00},///4
{0x00,0xF8,0x08,0x88,0x88,0x08,0x08,0x00,0x00,0x19,0x21,0x20,0x20,0x11,0x0E,0x00},//5
{0x00,0xE0,0x10,0x88,0x88,0x18,0x00,0x00,0x00,0x0F,0x11,0x20,0x20,0x11,0x0E,0x00},//6
{0x00,0x38,0x08,0x08,0xC8,0x38,0x08,0x00,0x00,0x00,0x00,0x3F,0x00,0x00,0x00,0x00},//7
{0x00,0x70,0x88,0x08,0x08,0x88,0x70,0x00,0x00,0x1C,0x22,0x21,0x21,0x22,0x1C,0x00},//8
{0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x00,0x31,0x22,0x22,0x11,0x0F,0x00},//9
{0x00,0x00,0x00,0xC0,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x30,0x00,0x00,0x00},// :
{0x00,0x00,0x00,0x00,0x80,0x60,0x18,0x04,0x00,0x60,0x18,0x06,0x01,0x00,0x00,0x00},// /
unsigned char code shu1[9][32]={///
{0x02,0x42,0x42,0xFE,0x42,0x42,0xFE,0x02,0x02,0xFA,0x02,0x02,0xFE,0x00,0x00,0x00,0x08,0x08,0x08,0x07,0x84,0x44,0x23,0x18,0x06,0x01,0x3E,0x40,0x43,0x40,0x78,0x00},//現(xiàn)12
{0x00,0x04,0x04,0xC4,0x64,0x9C,0x87,0x84,0x84,0xE4,0x84,0x84,0x84,0x84,0x04,0x00,0x04,0x02,0x01,0x7F,0x00,0x20,0x20,0x20,0x20,0x3F,0x20,0x20,0x20,0x20,0x20,0x00},//在 13
{0x00,0xFC,0x44,0x44,0x44,0xFC,0x10,0x90,0x10,0x10,0x10,0xFF,0x10,0x10,0x10,0x00,0x00,0x07,0x04,0x04,0x04,0x07,0x00,0x00,0x03,0x40,0x80,0x7F,0x00,0x00,0x00,0x00},//時 14
{0x00,0xF8,0x01,0x06,0x00,0xF0,0x92,0x92,0x92,0x92,0xF2,0x02,0x02,0xFE,0x00,0x00,0x00,0xFF,0x00,0x00,0x00,0x07,0x04,0x04,0x04,0x04,0x07,0x40,0x80,0x7F,0x00,0x00},//間 15
{0x00,0x00,0x00,0xBE,0x2A,0x2A,0x2A,0xEA,0x2A,0x2A,0x2A,0x2A,0x3E,0x00,0x00,0x00,0x00,0x48,0x46,0x41,0x49,0x49,0x49,0x7F,0x49,0x49,0x49,0x49,0x49,0x41,0x40,0x00},//星 16
{0x00,0x04,0xFF,0x54,0x54,0x54,0xFF,0x04,0x00,0xFE,0x22,0x22,0x22,0xFE,0x00,0x00,0x42,0x22,0x1B,0x02,0x02,0x0A,0x33,0x62,0x18,0x07,0x02,0x22,0x42,0x3F,0x00,0x00},//期 17
{0x10,0x21,0x86,0x70,0x00,0x7E,0x4A,0x4A,0x4A,0x4A,0x4A,0x7E,0x00,0x00,0x00,0x00,0x02,0xFE,0x01,0x40,0x7F,0x41,0x41,0x7F,0x41,0x41,0x7F,0x41,0x41,0x7F,0x40,0x00},//溫18
{0x00,0x00,0xFC,0x04,0x24,0x24,0xFC,0xA5,0xA6,0xA4,0xFC,0x24,0x24,0x24,0x04,0x00,0x80,0x60,0x1F,0x80,0x80,0x42,0x46,0x2A,0x12,0x12,0x2A,0x26,0x42,0xC0,0x40,0x00},//度19
unsigned char time1[7]={0x30,0x00,0x16,8,7,2,8};//分別是秒,分,時,日,月,星期,年 次子程序出自http://www.torrancerestoration.com hkcd斑竹,已通過測試無誤。
delay()
unsigned char i;
i=10;
i=10;
i=10;
i=10;
i=10;
i=10;
i=10;}
ACC=dat;//地址
sclk=0;
rst=1;//
io=acc0;///
sclk=0;
delay();
sclk=1;
io=acc1;
sclk=0;
delay();
sclk=1;
io=acc2;
sclk=0;
delay();
sclk=1;
io=acc3;
sclk=0;
delay();
sclk=1;
io=acc4;
sclk=0;
delay();
sclk=1;
io=acc5;
sclk=0;
delay();
sclk=1;
io=acc6;
sclk=0;
delay();
sclk=1;
io=acc7;
sclk=0;
delay();
sclk=1;///
//sclk=0;
io=acc0;///
sclk=0;
delay();
sclk=1;
io=acc1;
sclk=0;
delay();
sclk=1;
io=acc2;
sclk=0;
delay();
sclk=1;
io=acc3;
sclk=0;
delay();
sclk=1;
io=acc4;
sclk=0;
delay();
sclk=1;
io=acc5;
sclk=0;
delay();
sclk=1;
io=acc6;
sclk=0;
delay();
sclk=1;
io=acc7;
sclk=0;
delay();
sclk=1;///
rst=0;
sclk=0;
} ///寫完畢
sclk=0;
rst=1;
ACC=ADD; //地址
io=acc0;///
sclk=0;
delay();
sclk=1;
io=acc1;
sclk=0;
delay();
sclk=1;
io=acc2;
sclk=0;
delay();
sclk=1;
io=acc3;
sclk=0;
delay();
sclk=1;
io=acc4;
sclk=0;
delay();
sclk=1;
io=acc5;
sclk=0;
delay();
sclk=1;
io=acc6;
sclk=0;
delay();
sclk=1;
io=acc7;
sclk=0;/////
delay();
sclk=1;
delay();
sclk=0;
acc0=io;
delay();
sclk=1;
delay();
sclk=0;
acc1=io;
delay();
sclk=1;
delay();
sclk=0;
acc2=io;
delay();
sclk=1;
delay();
sclk=0;
acc3=io;
delay();
sclk=1;
delay();
sclk=0;
acc4=io;
delay();
sclk=1;
delay();
sclk=0;
acc5=io;
delay();
sclk=1;
delay();
sclk=0;
acc6=io;
delay();
sclk=1;
delay();
sclk=0;
acc7=io;
delay();
rst=0;
sclk=0;
return(ACC);
ds1302_c()
w_1302(0x80,0x80);
w_1302(0x8e,0x00);
w_1302(0x80,time1[0]); //;秒
w_1302(0x82,time1[1]); // 分=0
w_1302(0x84,time1[2]); //時 =0
w_1302(0x86,time1[3]); // 日
w_1302(0x88,time1[4]);// 月
w_1302(0x8a,time1[5]);//星期
w_1302(0x8c,time1[6]);//年
w_1302(0x8e,0x80);
w_1302(0x90,0xb8);
w_1302(0x80,0x00);
//x_lcd(unsigned a){//由a確定X軸 //y_lcd(unsigned a){///由A確定y軸
//void dis_lcd(){//打開顯示選擇第一行顯示 //w_lcd(unsigned b){ ///寫a到12864
//void busy_lcd(){//////判斷忙 //void cs1_lcd(){ ////////選擇左邊
//void cs2_lcd(){ ////////選擇右邊
d12864_lcd(unsigned char x,y,k){
unsigned char ix,iy,i;
dis_lcd();//打開顯示
if(x>63){
x=x-64;
cs2_lcd();
else cs1_lcd();
i=0;
if(k<12){
for(iy=0;iy<2;iy++)
for(ix=0;ix<8;ix++){
y_lcd(iy+y);
x_lcd(ix+x);
w_lcd(shu[k][i]);
i++;
else{k-=12;
for(iy=0;iy<2;iy++)
for(ix=0;ix<16;ix++){
y_lcd(iy+y);
x_lcd(ix+x);
w_lcd(shu1[k][i]);
i++;
time_lcd(){
unsigned char y,k,time,add,i,we1,we2;
add=128;///////必須是小于64-8大于64
d12864_lcd(0,0,12);//: 北
d12864_lcd(16,0,13);//: 京
d12864_lcd(31,0,14);//: 時
d12864_lcd(47,0,15);//: 間
k=0x81;
y=0; //在第幾行顯示
for(i=0;i<3;i++){
time=r_1302(k);
time1[i]=time;
add=add-8;;
time=time&0x0f;
d12864_lcd(add,y,time);///秒個位
add=add-8;
time=r_1302(k);
time&=0xf0;
time>>=4;
d12864_lcd(add,y,time);//秒十位
add=add-8;;
k+=2;
d12864_lcd(40+64,y,10);//:
d12864_lcd(16+64,y,10);//: 顯示兩點(diǎn)
time1[5]=r_1302(0x8b);
d12864_lcd(64,4,16);//: 星
d12864_lcd(64+16,4,17);//: 期
r_1302(0x8b);//讀星期
d12864_lcd(64+32,4,r_1302(0x8b));//: 讀星期幾`并顯示
y=2;//在第四行顯示
add=56+16;
time=r_1302(0x87);
time1[3]=time;
d12864_lcd(add,y,time&0x0f);//: 顯示日
time=r_1302(0x87);
time&=0xf0;
time>>=4;
add-=8;
d12864_lcd(add,y,time); //顯示日的十位
add-=8;
add-=8;
time1[4]=time=r_1302(0x89);
d12864_lcd(add,y,time&0x0f);//: 顯示月
time=r_1302(0x89);
time&=0xf0;
time>>=4;
add-=8;
d12864_lcd(add,y,time); //顯示月的十位
add-=8;
add-=8;
time1[6]=time=r_1302(0x8d);
d12864_lcd(add,y,time&0x0f);//: 顯示年
time=r_1302(0x8d);
time&=0xf0;
time>>=4;
add-=8;
d12864_lcd(add,y,time); //顯示年的十位
//////讀完
d12864_lcd(40+16,y,11);//:
d12864_lcd(16+16,y,11);//: 顯示兩/
add-=8;
d12864_lcd(add,y,0);//: 0
add-=8;
d12864_lcd(add,y,2);//: 2
d12864_lcd(0,4,18);//: 溫
d12864_lcd(16,4,19);//: 度
we1=wendu();
we2=we1/10;
d12864_lcd(32,4,we2);//: 2
we2=we1-we2*10;
d12864_lcd(40,4,we2);//: 顯示溫度值
cs1_lcd();
y_lcd(4);
x_lcd(50);
w_lcd(0x18);
x_lcd(51);
w_lcd(0x18);
/////////////////////////顯示時間完畢
hei_lcd(unsigned char x,y){ //全黑用來做閃標(biāo)用
char iy,ix,di,i;
di=0x00;
if(x>63){
x=x-64;
cs2_lcd();
else cs1_lcd();
i=0;
for(iy=0;iy<2;iy++){
y_lcd(iy+y);
x_lcd(ix+x);
w_lcd(di);
key_t(){ //鍵盤key1 加1 key2 減1
if(!key1){
key_time++;
delay1(20000);
while(!key1);
if(!key2){
key_time--;
delay1(20000);
while(!key2);
void delay11(word useconds)
key_t();
time_key(){
unsigned char keyd,ktime;
unsigned int year;
word kk;
keyd=0;
kk=10000;///閃動快慢
if(!key0){
for(;;){
if(!key0){
keyd=keyd+1;
delay1(500);
if(keyd>8)keyd=1;
key_time=0;//////每設(shè)牟換一個就把存設(shè)時間清0
key0=1;
while(!key0);
key0=1;
////////////////////////閃程序
if(keyd==1){//=1進(jìn)入秒閃 同時設(shè)置秒時間
key_time=(time1[0]&0x0f)+((time1[0]&0xf0)>>4)*10; //將數(shù)姐里的數(shù)度到key_time里 10進(jìn)制
hei_lcd(112,0);//x y
delay11(kk);//////閃動快慢
if(key_time>=60)key_time=0;
d12864_lcd(112,0,key_time/10);
d12864_lcd(120,0,key_time-(key_time/10)*10);
time1[0]=(((key_time/10)<<4)&0xf0)+(key_time-(key_time/10)*10); //換成BCD碼存到數(shù)組里
delay1(10000);
if(keyd==2){//=1進(jìn)入分閃 同時設(shè)置秒時間
key_time=(time1[1]&0x0f)+((time1[1]&0xf0)>>4)*10; //將數(shù)姐里的數(shù)度到key_time里 10進(jìn)制
hei_lcd(88,0);//x y
d12864_lcd(88,0,key_time/10);
d12864_lcd(96,0,key_time-(key_time/10)*10);
delay1(10000);
time1[1]=(((key_time/10)<<4)&0xf0)+(key_time-(key_time/10)*10); //換成BCD碼存到數(shù)組里
if(keyd==3){//=1進(jìn)入時閃 同時設(shè)置秒時間
key_time=(time1[2]&0x0f)+((time1[2]&0xf0)>>4)*10; //將數(shù)姐里的數(shù)度到key_time里 10進(jìn)制
hei_lcd(64,0);//x y
if(key_time>=24)key_time=0;
d12864_lcd(64,0,key_time/10);
d12864_lcd(72,0,key_time-(key_time/10)*10);
time1[2]=(key_time/10)<<4+(key_time-key_time/10);
delay1(10000);
time1[2]=(((key_time/10)<<4)&0xf0)+(key_time-(key_time/10)*10); //換成BCD碼存到數(shù)組里
if(keyd==4){//=1進(jìn)入年閃 同時設(shè)置秒時間
key_time=(time1[6]&0x0f)+((time1[6]&0xf0)>>4)*10; //將數(shù)姐里的數(shù)度到key_time里 10進(jìn)制
hei_lcd(16,2);//x y
if(key_time>99)key_time=0;
d12864_lcd(16,2,key_time/10);
d12864_lcd(24,2,key_time-(key_time/10)*10);
time1[6]=(key_time/10)<<4+(key_time-key_time/10);
delay1(10000);
time1[6]=(((key_time/10)<<4)&0xf0)+(key_time-(key_time/10)*10); //換成BCD碼存到數(shù)組里
if(keyd==5){//=1進(jìn)入月閃 同時設(shè)置秒時間
key_time=(time1[4]&0x0f)+((time1[4]&0xf0)>>4)*10; //將數(shù)姐里的數(shù)度到key_time里 10進(jìn)制
hei_lcd(40,2);//x y
if(key_time>=13)key_time=0;
d12864_lcd(40,2,key_time/10);
d12864_lcd(48,2,key_time-(key_time/10)*10);
time1[4]=(key_time/10)<<4+(key_time-key_time/10);
delay1(10000);
time1[4]=(((key_time/10)<<4)&0xf0)+(key_time-(key_time/10)*10); //換成BCD碼存到數(shù)組里
if(keyd==6){//=1進(jìn)入日閃 同時設(shè)置秒時間
key_time=(time1[3]&0x0f)+((time1[3]&0xf0)>>4)*10; //將數(shù)姐里的數(shù)度到key_time里 10進(jìn)制
year=(time1[4]&0x0f)+(((time1[4]&0xf0)>>4)*10)+2000;
switch(time1[4]){ //計(jì)算閏月
case 1: ktime=31;break;
case 3: ktime=31;break;
case 5: ktime=31;break;
case 7: ktime=31;break;
case 8: ktime=31;break;
case 10: ktime=31;break;
case 12: ktime=31;break;
case 4: ktime=30;break;
case 6: ktime=30;break;
case 9: ktime=30;break;
case 11: ktime=30;break;
case 2: if(year%4==0&&year%100!=0||year%400==0) ktime=29;
else ktime=29;break;
hei_lcd(64,2);//x y
if(key_time>ktime)key_time=0;
d12864_lcd(64,2,key_time/10);
d12864_lcd(72,2,key_time-(key_time/10)*10);
time1[3]=(key_time/10)<<4+(key_time-key_time/10);
delay1(10000);
time1[3]=(((key_time/10)<<4)&0xf0)+(key_time-(key_time/10)*10); //換成BCD碼存到數(shù)組里
if(keyd==7){//=1進(jìn)入星期閃 同時設(shè)置秒時
char iy,ix,di,i;
key_time=time1[5];
di=0x00;
cs2_lcd();
i=0;
y_lcd(iy+4);
x_lcd(ix+96);
w_lcd(di);
di=00;
if(key_time>7)key_time=0;
d12864_lcd(96,4,key_time);
time1[5]=key_time;
delay1(10000);
time1[5]=key_time; //換成BCD碼存到數(shù)組里
if(!key3)break;
ds1302_c(); ///更改時間
lcd_key(){
if(!key3){
if(!key2)lcd_d=1;
else lcd_d=0;
main(){
ds1302_c();
clr_lcd();
for(;;){
time_lcd();
time_key();
lcd_key();
